Hi there,
I’m using a dockerized OH 3 for a while now, and it worked. Since I did not get any logs, I tried clearing the cache as this previously helped, and restarted OH.
After the restart, all my bindings seem to have disappeared from the bindings list though. Especially RFXCom which I’m using with a bridge thing:
things/rfx.things:
Bridge rfxcom:tcpbridge:sunflower [ host="192.168.1.30", port=10001 ] {}
I tried to reinstall it through the interface, it says ‘installing’ but nothing happens.
When checking, it doesn’t seem to be there.
The problem is, I do not have any logs…
Could anyone help me to try to solve this?
Thank you very much!
rossko57
(Rossko57)
August 11, 2021, 10:08am
2
This is major obstruction to sorting you out. There are several threads on this topic, I suggest a search of those might give you hints.
I’m going to make a guess this is OH3.0 from before the remote repository was moved. So that your system can no longer download any bindings online.
Dear all,
We have today published the openHAB patch release 3.0.2. It brings a couple of bug fixes for our stable release. You can find the details in the release notes .
Even if you might not need these fixes for your setup, we highly recommend to install this patch, since it takes care of adapting the update and download mechanisms to no longer point to Bintray, but to Artifactory. This is necessary, since Bintray services shut down on May 1st, 2021 , which means that add-ons cannot be dynamic…
Thanks a lot! Upgrading helped. I’ll debug the log issue separately.
