openHAB 3.0.2 Patch Release and the Sunset of Bintray
Dear all,
We have today published the openHAB patch release 3.0.2. It brings a couple of bug fixes for our stable release. You can find the details in the release notes.
Even if you might not need these fixes for your setup, we highly recommend to install this patch, since it takes care of adapting the update and download mechanisms to no longer point to Bintray, but to Artifactory. This is necessary, since Bintray services shut down on May 1st, 2021, which means that add-ons cannot be dynamically downloaded anymore if you stay on an older version.
If you nonetheless plan to stay on an older openHAB release, please download the add-ons KAR (or the resp. Linux package) before May 1st to make sure that you do not run into issues after that date.
Due to the work involved, we were not able to retrofit all required changes onto 2.5.x - we therefore cannot and won’t provide any further patches on that branch, 2.5.12 this staying the last one. I can only encourage everyone to move to 3.x, which is very stable and the migration is fairly easy - give it a try!
Please use this topic for any questions, comments and problems with regards to the 3.0.2 release.
Best regards,
Kai
OHv2 installing regex? (Error downloading)
Issue with JDBC addon installation
OH3 - trouble installing iCalendar binding
Error downloading MQTT for OH3?
Lost all bindings, can't install new ones, no logs?
RPI OpenHAB 3.1. but still Openhabian 2.5
Problem with the Download of transformation map with Openhab 3.0.1
MapDB fails to install on OH3.0.1
OH not starting after clean cache
Add Ons Not Installing
MQTT binding installation gets stuck
OH3 openweather binding will not install
Can't install add-ons
WLED V3.0.1 hangs during install
Homematic binding fails to install
OpenHABian Milestone upgrade fails
Effects of the sunset of Bintray
openHABian: frontail log doesn't work & 21 leads to error
Problem with repositories - can't download actions etc
Docker 2.5.12 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing
Bintray down - Is there a change to another repository?
[Solved] OH2.5.12 Error downloading mvn:org.openhab.ui.bundles/org.openhab.ui.paper/[2.5.0,2.6)
OH2.5 & OH3.0.1 / OH 3.0.0 Installation fail on Docker & Kubernetes: Artifacts not found
Unable to start OH -- please help me
The Stable (Release) Linux repositories have changed location
3.0.2 Documentation Links Broken
LightwaveRF - New LightwaveRF Binding
How to force V3.0.1 install?
Known issues on OH3 upgrade
openHAB 3.1.0 Build #2253 no Bindings will run
Updating Openhab 3 Version blw. 3.0.2 via upgrade fails with errors (reaching 93.93.128.193)
[t.core.internal.addons.AddonResource] - Exception while installing add-on: null
