As Bintray was shut down 2 days ago, we are now experiencing the full impact of it - and it is more that was anticipated.
Please use this topic to report any issues that you might encounter - but please also note the posts on solutions for 2.5.x installations as well as for 3.0.x installations.
Iām currently still on openHAB 2.5 and obviously get an error from apt when I periodically check for outdated software packages on my Raspberry Pi 3B+.
Should I also remove the apt repository link to Bintray since itās apparently gone (403 Forbidden error messages), or should I remove the trusted key from /etc/apt/sources.list?
There are two errors that come up in relation to this.
openHAB errors in the logs failing to download and install any add-on.
Error from apt/yum/etc. indicating it cannot download the list of packages from bintray.
Downloading the kar file only fixes 1. To fix 2 one needs to eliminate the link to bintray from the repos used by the package manager (e.g. apt). openHABian has an option to do that for you. For those who ran an apt upgrade prior to May 1st the upgrade did this for you. However, those who failed/did not know to run an upgrade prior to May 1st will still have an entry in their sources list pointing to bintray and running apt update will generate an error.
Because you have configured OH to download addons (āremoteā setting in addons.cfg if I remember correctly). That has nothing to do with openHABian.
/var/lib/openhab2/etc directory. So, there is no /var/lib/openhab2/etc/org.ops4j.pax.url.mvn.cfg
And the only .kar files on the system are:
/usr/share/openhab2/runtime/system/org/apache/karaf/deployer/org.apache.karaf.deployer.kar
/srv/openhab2-sys/runtime/system/org/apache/karaf/deployer/org.apache.karaf.deployer.kar
o
So, it doesnāt appear the system has ever gotten the files locally.
