using openHAB 4.1.0 Release Build on openHABian v1.8b.
I experience the following behaviour with openHAB4 since a few releases, but now it feels more rapidly that this happens:
What I do:
open openHAB in a new browser-session
I’m logged in via Cookie
I use the MainUI
I open multiple TABs (items, rules, things,…)
after some time MainUI loses the connection to openHAB
5.1 rules won’t get saved anymore
5.2 items dont’ get loaded/…
5.3 things don’t get loaded
5.4 pages won’t update
5.5 bindings can’t be searched/…
restarting the browser fixes this => started with (1)
If I open /profile, there’s a bunch of sessions, but only one for each client with either IP or FDQN on my openHAB-Server.
The error is regardles the browser, it happens in Firefox, Chrome and Edge (Chromium) the same.
Are you using HTTP or HTTPS? I remember seeing an issue or maybe a PR go by that talked about the SSE event stream isn’t always working right with HTTP. Could be related, could be completely unrelated.
It’s http for me.
and I remembered the F12-console for “network analysis”.
What appears to be the problem is MainUI losing authorization, as the XMLHttpRequest (e.g. /rest/items?metadata=semantics) throw an 401 if that happens. Funnily enough, if I use the F12-console, it seems(?) to be “self-repairing”, as after an 401 i can more often seem to call through in other MainUI categories…? The previous 401 changes to a 200 after a click again…
In programming we jokingly call that a Heisenbug.. It might be worth an issue but I don’t know if there is enough information here yet to reproduce and diagnose the problem.
I can somewhat confirm this error. UI feels sluggish, and randomly it takes like 20s to refresh pages. Also, when needed to pick something from a list (f.e. pick mqtt broker when adding a mqtt thing, or selecting a thing to create equpiment from). Also can confirm that the issue goes away immediately when I use https access instead of http.
EDIT: ok just as I wrote this, the issue returned on https as well. Confused to say the least.
I’m using fresh install, dockerized latest official image.
I tried Edge. And to my surprise, it’s day and night. Yes, every now and then the issue appears, but all I need is to open the UI in new tab every 30 mins or so and it works. While in chrome it was unusable.
