I am making an IN/OUT sign using MainUI pages and have it all working but would love to know how to get it full screen in a browser (this isnt a tablet question).
I basically want to be in Run Mode and have the function the Fullscreen button in the bottom right does - is there a URL I can reference directly for this, if not some sort of script I can embed or something similar?
Do you mean that you want to get rid of the left-hand menu? If so, just click the pushpin to unpin it.
Or do you mean that you want the browser to be a full-screen window with no tabs/taskbar? Thatās possible with JavaScript, but I donāt know how youād build that into a MainUI page. Maybe you can make it the default for the browser when it launches.
https://usefulangle.com/post/12/javascript-going-fullscreen-is-rare
Iāve never actually noticed that option before. Looks like it is just triggering a Javascript, but I canāt think of how youād do that without human intervention.
Id be happy to run some javascript to do it if I could work out how - just running the URL in fullscreen in chrome isnt doing this
OK I think fixed grid layout gets me very close
was there a solution for the challenge?
i use Fully Kiosk Browser and would like to start the page in full screen and run-mode.
Iām struggling with exactly the same issue⦠I would like to run a dashboard on a wall screen - and the dashboard should be displayed in rendered mode by default. So a get parameter as &render=true would be awesome ![]()
Markus
Thanks Oliver,
unfortunatally this thread is only about fullscreen, but not for rendering it by default
what do you mean by rendering? If you mean, it should directly jump into fullscreen mode then yes, the solution provides exactly this.
to not show the edit mode but the ārun modeā. So the view you get after clicking on ārun modeā or āCtrl rā
just read through the link provided incl. its sub links.
It works as requested
This seems to be a solution IF you set this page as the default start page (which seems to be rendered by default) but not for any other page.
I donāt want to change the default page (as this doesnāt make sense for me at all). I wanāt to apply this for a dedicated page which is only build for a dedicated wallscreen.
you didnāt read carefully the post. Again, it provides what you are requesting. Even the title of the linked post provides the informationā¦
edit:
you need to adjust the parameter āstart_urlā of the manifest file
