Thinking along the same lines, I have reset the device to factory. I thought it might have been something I did that caused it to malfunction but that did nothing. I then paired the device at a friends home with the smartthings hub and it worked with no issues. Brought back home and paired with openhab and back to the same problem.
I imagine if its the implementation of the switch, I should be able to hack at it locally. I’m just not quite sure where to start. I visited cd-jackson.com and see this “http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/567” . The Color control and color temperature seem to be included in there.
Here is some more of my log. Could that be HSB values instead of RGB? See below, the numbers go above 255 towards the very end.
=> openhab.log <==
2018-03-06 20:39:15.311 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 9: Color report RED 0
2018-03-06 20:39:15.312 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 9: Color report finished {GREEN=0, BLUE=0, RED=0, WARM_WHITE=194}
2018-03-06 20:39:15.554 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 9: Color report GREEN 0
2018-03-06 20:39:15.554 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 9: Color report finished {GREEN=0, BLUE=0, RED=0, WARM_WHITE=194}
2018-03-06 20:39:15.758 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 9: Color report BLUE 0
2018-03-06 20:39:15.758 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 9: Color report finished {GREEN=0, BLUE=0, RED=0, WARM_WHITE=194}
2018-03-06 20:39:15.956 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 9: Color report WARM_WHITE 255
2018-03-06 20:39:15.956 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 9: Color report finished {GREEN=0, BLUE=0, RED=0, WARM_WHITE=255}
==> events.log <==
2018-03-06 20:39:17.760 [ome.event.ItemCommandEvent] - Item 'zwave_device_7b2f526d_node9_color_color' received command 199,0,0
2018-03-06 20:39:17.762 [vent.ItemStateChangedEvent] - zwave_device_7b2f526d_node9_color_color changed from 0,0,0 to 199,0,0
2018-03-06 20:39:20.855 [ome.event.ItemCommandEvent] - Item 'zwave_device_7b2f526d_node9_color_color' received command 199,72,0
2018-03-06 20:39:20.857 [vent.ItemStateChangedEvent] - zwave_device_7b2f526d_node9_color_color changed from 199,0,0 to 199,72,0
2018-03-06 20:39:23.444 [ome.event.ItemCommandEvent] - Item 'zwave_device_7b2f526d_node9_color_color' received command 80
2018-03-06 20:39:23.446 [vent.ItemStateChangedEvent] - zwave_device_7b2f526d_node9_color_color changed from 199,72,0 to 199,72,80
==> openhab.log <==
2018-03-06 20:39:23.762 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 9: Color report RED 0
2018-03-06 20:39:23.762 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 9: Color report finished {GREEN=0, BLUE=0, RED=0, WARM_WHITE=255}
==> events.log <==
2018-03-06 20:39:23.766 [vent.ItemStateChangedEvent] - zwave_device_7b2f526d_node9_color_color changed from 199,72,80 to 0,0,0
==> openhab.log <==
2018-03-06 20:39:24.003 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 9: Color report GREEN 0
2018-03-06 20:39:24.004 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 9: Color report finished {GREEN=0, BLUE=0, RED=0, WARM_WHITE=255}
2018-03-06 20:39:24.203 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 9: Color report BLUE 0
2018-03-06 20:39:24.204 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 9: Color report finished {GREEN=0, BLUE=0, RED=0, WARM_WHITE=255}
==> events.log <==
2018-03-06 20:39:24.352 [ome.event.ItemCommandEvent] - Item 'zwave_device_7b2f526d_node9_color_color' received command 100
2018-03-06 20:39:24.355 [vent.ItemStateChangedEvent] - zwave_device_7b2f526d_node9_color_color changed from 0,0,0 to 0,0,100
==> openhab.log <==
2018-03-06 20:39:24.508 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 9: Color report WARM_WHITE 207
2018-03-06 20:39:24.509 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 9: Color report finished {GREEN=0, BLUE=0, RED=0, WARM_WHITE=207}
==> events.log <==
2018-03-06 20:39:24.511 [vent.ItemStateChangedEvent] - zwave_device_7b2f526d_node9_color_color changed from 0,0,100 to 0,0,0
==> openhab.log <==
2018-03-06 20:39:26.936 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 9: Color report WARM_WHITE 207
2018-03-06 20:39:26.936 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 9: Color report finished {GREEN=0, BLUE=0, RED=0, WARM_WHITE=207}
==> events.log <==
2018-03-06 20:39:27.328 [ome.event.ItemCommandEvent] - Item 'zwave_device_7b2f526d_node9_color_color' received command 305,0,0
2018-03-06 20:39:27.330 [vent.ItemStateChangedEvent] - zwave_device_7b2f526d_node9_color_color changed from 0,0,0 to 305,0,0
2018-03-06 20:39:27.642 [ome.event.ItemCommandEvent] - Item 'zwave_device_7b2f526d_node9_color_color' received command 360,0,0
2018-03-06 20:39:27.644 [vent.ItemStateChangedEvent] - zwave_device_7b2f526d_node9_color_color changed from 305,0,0 to 360,0,0
