I have knx based automation and want to set up a couple of HBPanels. The issue I’m trying to resolve is that the original state of the item is shown and not the transformed one.
The MAP transformation I use works well in Sitemaps. The same transformation has been added to channel configuration and looks like it works well as well (though I do not know how to check it, if the .map file has an issue, I get warning in the log on update).
I checked REST /items/ endpoint for my item, and it does not contain a transformedState field, just a state field is available.
Not sure where to look, please advise if anyone has HABPanel working with tranformations and knx2 binding,
No, unfortunately it does not work regardless of any settings I found. I use Dummy widgets. “Use server-provided format if available” does not change anything and specifying transformation in “Format” does not work as well.
