Short after installing MapDB for restore it creates lot of warnings??:
2018-04-10 15:43:37.755 [vent.ItemStateChangedEvent] - Temperatur_kjoleskap changed from 5.800000000000001 to 5.9
2018-04-10 15:43:37.753 [WARN ] [pse.smarthome.core.items.GenericItem] - failed notifying listener ‘org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl@29fb58’ about state update of item Temperatur_kjoleskap: 2018-02-16 is not in a valid format.
java.lang.IllegalArgumentException: 2018-02-16 is not in a valid format.
at org.openhab.core.library.types.DateTimeType.<init>(DateTimeType.java:50) [200:org.openhab.core.compat1x:2.2.0]
at org.openhab.core.library.types.DateTimeType.valueOf(DateTimeType.java:64) [200:org.openhab.core.compat1x:2.2.0]
at org.openhab.persistence.mapdb.internal.MapDBitemSerializer.deserialize(MapDBitemSerializer.java:59) [253:org.openhab.persistence.mapdb:1.11.0]
at org.openhab.persistence.mapdb.internal.MapDBitemSerializer.deserialize(MapDBitemSerializer.java:1) [253:org.openhab.persistence.mapdb:1.11.0]
at org.mapdb.BTreeMap$NodeSerializer.deserialize(BTreeMap.java:449) [253:org.openhab.persistence.mapdb:1.11.0]
at org.mapdb.BTreeMap$NodeSerializer.deserialize(BTreeMap.java:288) [253:org.openhab.persistence.mapdb:1.11.0]
at org.mapdb.Store.deserialize(Store.java:297) [253:org.openhab.persistence.mapdb:1.11.0]
at org.mapdb.StoreDirect.get2(StoreDirect.java:475) [253:org.openhab.persistence.mapdb:1.11.0]
at org.mapdb.StoreWAL.get2(StoreWAL.java:336) [253:org.openhab.persistence.mapdb:1.11.0]
at org.mapdb.StoreWAL.get(StoreWAL.java:320) [253:org.openhab.persistence.mapdb:1.11.0]
at org.mapdb.Caches$HashTable.get(Caches.java:246) [253:org.openhab.persistence.mapdb:1.11.0]
at org.mapdb.EngineWrapper.get(EngineWrapper.java:58) [253:org.openhab.persistence.mapdb:1.11.0]
at org.mapdb.BTreeMap.put2(BTreeMap.java:677) [253:org.openhab.persistence.mapdb:1.11.0]
at org.mapdb.BTreeMap.put(BTreeMap.java:643) [253:org.openhab.persistence.mapdb:1.11.0]
at org.openhab.persistence.mapdb.internal.MapDBPersistenceService.store(MapDBPersistenceService.java:161) [253:org.openhab.persistence.mapdb:1.11.0]
at org.openhab.core.persistence.internal.PersistenceServiceDelegate.store(PersistenceServiceDelegate.java:55) [200:org.openhab.core.compat1x:2.2.0]
at org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl.handleStateEvent(PersistenceManagerImpl.java:131) [114:org.eclipse.smarthome.core.persistence:0.10.0.b1]
at org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl.stateChanged(PersistenceManagerImpl.java:432) [114:org.eclipse.smarthome.core.persistence:0.10.0.b1]
at org.eclipse.smarthome.core.items.GenericItem$1.run(GenericItem.java:234) [109:org.eclipse.smarthome.core:0.10.0.b1]
at java.text.DateFormat.parse(DateFormat.java:366) ~[?:?]
at org.openhab.core.library.types.DateTimeType.<init>(DateTimeType.java:47) ~[?:?]
... 21 more
Thank you for answering
It seems quite random because it does this with a lot of other items aswell.
This is an other “standard” weather item that givs same error:
DateTime ObservationTime “Oppdatert [%1$tH:%1$tM]” {channel=“weatherunderground:weather:cd8316cc:current#observationTime”}
This is my mapdb.persist:
Strategies {
default = everyUpdate
Items {
// persist all Items on every change and restore them from the MapDB at startup
* : strategy = everyChange, restoreOnStartup
l
018-04-11 08:26:02.890 [vent.ItemStateChangedEvent] - ObservationTime changed from 2018-04-11T08:20:59.000+0200 to 2018-04-11T08:25:59.000+0200
2018-04-11 08:26:02.935 [WARN ] [pse.smarthome.core.items.GenericItem] - failed notifying listener ‘org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl@a732d0’ about state update of item ObservationTime: 2018-02-16 is not in a valid format.
Did not find it anywhere ;( cleared the cache and got this after restart:
2018-04-11 11:23:45.793 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-04-11 11:23:46.479 [vent.ItemStateChangedEvent] - x300_basseng_temp_inn changed from 5.2 to 5.3
2018-04-11 11:23:46.351 [ERROR] [g.eclipse.smarthome.core.persistence] - [org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl(8)] The addPersistenceService method has thrown an exception
at org.openhab.core.library.types.DateTimeType.<init>(DateTimeType.java:50) ~[?:?]
at org.openhab.core.library.types.DateTimeType.valueOf(DateTimeType.java:64) ~[?:?]
at org.openhab.persistence.mapdb.internal.MapDBitemSerializer.deserialize(MapDBitemSerializer.java:59) ~[?:?]
at org.openhab.persistence.mapdb.internal.MapDBitemSerializer.deserialize(MapDBitemSerializer.java:1) ~[?:?]
at org.mapdb.BTreeMap$NodeSerializer.deserialize(BTreeMap.java:449) ~[?:?]
at org.mapdb.BTreeMap$NodeSerializer.deserialize(BTreeMap.java:288) ~[?:?]
at org.mapdb.Store.deserialize(Store.java:297) ~[?:?]
at org.mapdb.StoreDirect.get2(StoreDirect.java:475) ~[?:?]
at org.mapdb.StoreWAL.get2(StoreWAL.java:336) ~[?:?]
at org.mapdb.StoreWAL.get(StoreWAL.java:320) ~[?:?]
at org.mapdb.Caches$HashTable.get(Caches.java:246) ~[?:?]
at org.mapdb.EngineWrapper.get(EngineWrapper.java:58) ~[?:?]
at org.mapdb.BTreeMap.get(BTreeMap.java:602) ~[?:?]
at org.mapdb.BTreeMap.get(BTreeMap.java:589) ~[?:?]
at org.openhab.persistence.mapdb.internal.MapDBPersistenceService.query(MapDBPersistenceService.java:175) ~[?:?]
at org.openhab.core.persistence.internal.QueryablePersistenceServiceDelegate.query(QueryablePersistenceServiceDelegate.java:47) ~[?:?]
at org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl.initialize(PersistenceManagerImpl.java:262) ~[?:?]
at org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl.startEventHandling(PersistenceManagerImpl.java:377) ~[?:?]
at org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl.addPersistenceService(PersistenceManagerImpl.java:107) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506) ~[?:?]
at org.apache.felix.scr.impl.inject.BindMethod.invoke(BindMethod.java:658) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1722) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1699) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:372) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:320) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:291) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:915) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:482) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:999) ~[?:?]
at org.openhab.core.persistence.internal.PersistenceServiceFactory.registerDelegateService(PersistenceServiceFactory.java:72) ~[?:?]
at org.openhab.core.persistence.internal.PersistenceServiceFactory.addPersistenceService(PersistenceServiceFactory.java:53) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) ~[?:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) ~[?:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) ~[?:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) ~[?:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) ~[?:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) ~[?:?]
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) ~[?:?]
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) ~[?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) ~[?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:402) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.startBundle(FeaturesServiceImpl.java:1361) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:888) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1248) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$1(FeaturesServiceImpl.java:1147) ~[?:?]
... 117 more
Not necessarily, some binding do and some don’t
I just put it in there just in case it did
Rename your mapdb.back back to mapdb.persist and start OH
I really hope that will do it because I am fresh out of ideas
Just a thought: your DateTime object only seems to give a problem for the date part, which you have not specified in your formatting string; I have such an object defined as this:
MapDB does not complain. I know it is far fetched, but the fact that only the date part is given in the error made me think about this. (Edit, the following is a wrong statement, see below (thank you @vzorglub): MapDB only persists numbers and maybe your formatting throws off something.)
Thanks but I don’t have any Datetime items other than observation time, it still complains about this for temperature and humidity items… Whats strange is that it only complains about the same date every time, 2018-02-16…
