Mercedes Me / no status
I have successfully (at least I think so) installed Mercedes Me and bound it with my brand new Mercedes GLC combustion vehicle.
I use add-on from market, last update at 27. September 2023.
The binding is detecting following features as supported or unsupported:
    featureUrbanGuard    false
    featureDcCharging    false
    commandBatteryMaxSocConfigure    false
    featurePictureTransfer    false
    featureDistronicPro    false
    commandSpeedalertStop    false
    commandBatteryChargeProgramConfigure    false
    featureFastCharging    false
    vehicle    combustion
    commandDoorsUnlock    true
    commandWeekProfileConfigure    false
    commandChargeOptStart    false
    featureEcoCharging    false
    commandWindowsOpen    true
    commandSunroofLift    true
    featureControllableSunroof    true
    commandZevPreconditioningStart    false
    featureRemoteSettingTemperature    false
    commandSunroofOpen    true
    featureHepaFilter    false
    commandAuxheatStop    false
    commandZevPreconditionConfigure    false
    featureVariableOpenableWindow    true
    featureMopf    false
    commandTheftalarmSelectInterior    false
    commandWindowsVentilate    true
    commandDoorsLock    true
    commandSpeedalertStart    false
    commandAuxheatStart    false
    featureAuxHeat    false
    featureRemoteSettingPersonalizedTemperature    true
    commandTheftalarmDeselectTow    false
    commandTheftalarmSelectDamagedetection    false
    commandChildpresencedetectionDeactivatealarm    false
    commandTheftalarmStart    false
    commandSigposStart    true
    featureDoubleDoorLock    false
    featureVariableOpenableSunroof    true
    featureDriverAssistancePackageHigh    false
    featurePrecondNow    false
    featureChargingClockTimer    false
    commandChargeOptStop    false
    featureConvertible    false
    featureWeeklyProfile    false
    featureBidirectionalCharging    false
    commandTheftalarmDeselectInterior    false
    featureDriverAssistancePackagePlus    false
    commandEngineStart    false
    commandChargeProgramConfigure    false
    commandWiperHealthReset    false
    commandAuxheatConfigure    false
    commandTheftalarmSelectTow    false
    commandEngineStop    false
    featureRearSunProtectionBlinds    false
    commandZevPreconditionConfigureSeats    false
    commandTemperatureConfigure    false
    commandSunroofClose    true
    commandZevPreconditioningStop    false
    commandTheftalarmConfirmDamagedetection    false
    commandChargeOptConfigure    false
    commandTheftalarmStop    false
    featurePluggedStateDependingPreEntryClimateControl    false
    featureControllableRearWindowBlind    false
    commandWindowsClose    true
Now my problem:
i’m nota able to acces any status information of the vehicle. Only GPS is working, all other readable status informations are showing “NULL” like eg.
2023-11-07_11h44_25
I tried to find out in the forum whether I have overseen something to configure.
But I have not found any hint wrt. my issue.
Can somebody advice or at elast give some hints?
Thx in advance
update: checked “vehicle#proto-update (String)” - Timestamps and content are not updated.
As told: GPS is the only information that seems to work.
Any hint?
Can you check the logs?
Sounds like an exception is interrupting the update!
And which openHAB version?
thx.
I use latest OH4.4.
I checked the logs - I do not see anything expectional.
Token renewing seems to run:
2023-11-11 11:27:42.532 [INFO ] [esme.internal.handler.AccountHandler] -
Token received AccessTokenResponse [accessToken=e....k, tokenType=Bearer, expiresIn=7199, refreshToken=7....o,
scope=openid email phone profile offline_access ciam-uid, state=null, createdOn=2023-11-11T10:27:42.463888181Z]
When I request the vehicle to close the windows by:
2023-11-11 11:39:10.283 [INFO ] [esme.internal.handler.VehicleHandler] - Received command class org.openhab.core.library.types.DecimalType 1 for mercedesme:combustion:685de9c7e0:GLC:vehicle#windows
2023-11-11 11:39:10.742 [INFO ] [rcedesme.internal.server.MBWebsocket] - Send Message {proto.ClientMessage.commandRequest=vin: " W....4112"
request_id: "62c42aca-c865-46fb-b49f-aaac6578885"
windows_close {
the thing “proto data update” is updated to
{"minSocUpperLimit":{"timestamp_in_ms":1699608174459,"ratio_unit":"PERCENT","nil_value":true,"timestamp":1699608174,"status":1},"bidirectionalChargingActive":{"timestamp_in_ms":1699608174459,"nil_value":true,"timestamp":1699608174,"status":1},"chargeCouplerACStatus":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"doorLockStatusOverall":{"timestamp_in_ms":1699691171000,"timestamp":1699691171,"int_value":0},"precondSeatFrontRight":{"timestamp_in_ms":1699607930000,"bool_value":false,"timestamp":1699607930},"tirePressMeasTimestamp":{"timestamp_in_ms":1699697254000,"timestamp":1699697254,"int_value":1699697254},"drivenTimeStart":{"timestamp_in_ms":1699691121000,"timestamp":1699691121,"int_value":28},"smartCharging":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"vehicleHealthStatus":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"doorlockstatusdecklid":{"timestamp_in_ms":1699691171000,"bool_value":false,"timestamp":1699691171},"nextDepartureTime":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"maxrange":{"timestamp_in_ms":1695050995000,"distance_unit":"KILOMETERS","nil_value":true,"timestamp":1695050995,"status":4},"batteryState":{"timestamp_in_ms":1699624375000,"timestamp":1699624375,"int_value":4},"maxSocLowerLimit":{"timestamp_in_ms":1695050995000,"ratio_unit":"PERCENT","nil_value":true,"timestamp":1695050995,"status":4},"doorstatusgas":{"timestamp_in_ms":1699607930000,"timestamp":1699607930,"int_value":0},"weeklyProfile":{"timestamp_in_ms":1698649887000,"nil_value":true,"timestamp":1698649887,"status":4},"liquidRangeSkipIndication":{"timestamp_in_ms":1699699154000,"bool_value":false,"timestamp":1699699154},"chargingErrorWim":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"chargeCouplerDCStatus":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"doorlockstatusfrontright":{"timestamp_in_ms":1699691171000,"bool_value":false,"timestamp":1699691171},"tirepressureRearRight":{"display_value":"240","timestamp_in_ms":1699694140000,"pressure_unit":"KPA","double_value":242.5,"timestamp":1699694140},"languageHU":{"timestamp_in_ms":1699689257000,"timestamp":1699689257,"int_value":0},"tireMarkerRearLeft":{"timestamp_in_ms":1699697254000,"timestamp":1699697254,"int_value":0},"vehiclePositionErrorCode":{"timestamp_in_ms":1699699123563,"timestamp":1699699123,"int_value":5},"departureTimeMode":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"parkbrakestatus":{"timestamp_in_ms":1699691119000,"bool_value":true,"timestamp":1699691119},"bindingInfo":{"version":"2.3-alpha","oh-bundle":"3.4.0.202309262121","vehicle":"mercedesme:combustion"},"precondOperatingMode":{"timestamp_in_ms":1699607930000,"timestamp":1699607930,"int_value":0},"starterBatteryState":{"timestamp_in_ms":1699641561000,"timestamp":1699641561,"int_value":0},"precondNowError":{"timestamp_in_ms":1699607930000,"timestamp":1699607930,"int_value":0},"turnOffEnginePreWarningTime":{"timestamp_in_ms":1699608131563,"nil_value":true,"timestamp":1699608131,"status":1},"windowStatusOverall":{"timestamp_in_ms":1699656618000,"timestamp":1699656618,"int_value":3},"tireSensorAvailable":{"timestamp_in_ms":1699694140000,"timestamp":1699694140,"int_value":0},"minSoc":{"timestamp_in_ms":1699608174459,"ratio_unit":"PERCENT","nil_value":true,"timestamp":1699608174,"status":1},"rangeelectric":{"timestamp_in_ms":1695050995000,"distance_unit":"KILOMETERS","nil_value":true,"timestamp":1695050995,"status":4},"tireMarkerRearRight":{"timestamp_in_ms":1699697254000,"timestamp":1699697254,"int_value":0},"windowstatusrearright":{"timestamp_in_ms":1699607930000,"timestamp":1699607930,"int_value":2},"serviceintervaldays":{"timestamp_in_ms":1699689263000,"nil_value":true,"timestamp":1699689263,"status":3},"electricalRangeSkipIndication":{"timestamp_in_ms":1699608131563,"nil_value":true,"timestamp":1699608131,"status":1},"windowstatusrearleft":{"timestamp_in_ms":1699607930000,"timestamp":1699607930,"int_value":2},"endofchargetime":{"timestamp_in_ms":1695050995000,"clock_hour_unit":"T24H","nil_value":true,"timestamp":1695050995,"status":4},"chargeFlapACStatus":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"chargingBreakClockTimer":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"hybridWarnings":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"positionHeading":{"timestamp_in_ms":1699691116000,"double_value":277,"timestamp":1699691116},"precondAtDepartureDisable":{"timestamp_in_ms":1699607930000,"nil_value":true,"timestamp":1699607930,"status":4},"auxheattimeselection":{"timestamp_in_ms":1699607930000,"timestamp":1699607930,"int_value":0},"doorstatusrearleft":{"timestamp_in_ms":1699691130000,"bool_value":false,"timestamp":1699691130},"odo":{"display_value":"2935","timestamp_in_ms":1699699154000,"distance_unit":"KILOMETERS","timestamp":1699699154,"int_value":2935},"warninglowbattery":{"timestamp_in_ms":1699626917000,"bool_value":false,"timestamp":1699626917},"tirewarninglamp":{"timestamp_in_ms":1699697254000,"timestamp":1699697254,"int_value":0},"positionLong":{"timestamp_in_ms":1699691116000,"double_value":4.56,"timestamp":1699691116},"electricconsumptionreset":{"timestamp_in_ms":1699699153000,"electricity_consumption_unit":"KWH_PER_100KM","nil_value":true,"timestamp":1699699153,"status":4},"precondatdeparture":{"timestamp_in_ms":1699607930000,"nil_value":true,"timestamp":1699607930,"status":4},"temperatureUnitHU":{"timestamp_in_ms":1699608301000,"bool_value":false,"timestamp":1699608301},"averageSpeedReset":{"display_value":"49","timestamp_in_ms":1699691121000,"speed_unit":"KM_PER_HOUR","double_value":49.3,"timestamp":1699691121},"ecoscoreconst":{"display_value":"49","timestamp_in_ms":1699697254000,"ratio_unit":"PERCENT","timestamp":1699697254,"int_value":49},"doorstatusfrontright":{"timestamp_in_ms":1699691131000,"bool_value":false,"timestamp":1699691131},"tcuConnectionStateLowChannel":{"timestamp_in_ms":1699697546182,"timestamp":1699697546},"chargingstatus":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"ecoscoretotal":{"timestamp_in_ms":1699608131563,"ratio_unit":"PERCENT","nil_value":true,"timestamp":1699608131,"status":1},"doorstatusfrontleft":{"timestamp_in_ms":1699691155000,"bool_value":false,"timestamp":1699691155},"electricRatioOverall":{"timestamp_in_ms":1699608131563,"nil_value":true,"timestamp":1699608131,"status":1},"warningbrakeliningwear":{"timestamp_in_ms":1699697254000,"bool_value":false,"timestamp":1699697254},"distanceZEStart":{"display_value":"0.6","timestamp_in_ms":1699690907000,"distance_unit":"KILOMETERS","double_value":0.6,"timestamp":1699690907},"doorlockstatusgas":{"timestamp_in_ms":1699691171000,"bool_value":false,"timestamp":1699691171},"engineHoodStatus":{"timestamp_in_ms":1699607930000,"bool_value":false,"timestamp":1699607930},"doorstatusrearright":{"timestamp_in_ms":1699691123000,"bool_value":true,"timestamp":1699691123},"keylineActivationState":{"timestamp_in_ms":1695050995000,"timestamp":1695050995},"oilLevel":{"display_value":"100","timestamp_in_ms":1699697254000,"ratio_unit":"PERCENT","timestamp":1699697254,"int_value":100},"turnOffEnginePreWarning":{"timestamp_in_ms":1699608131563,"nil_value":true,"timestamp":1699608131,"status":1},"tirewarningsrdk":{"timestamp_in_ms":1699697254000,"timestamp":1699697254,"int_value":0},"precondNow":{"timestamp_in_ms":1699607930000,"bool_value":false,"timestamp":1699607930},"rangeliquid":{"display_value":"589","timestamp_in_ms":1699691118000,"distance_unit":"KILOMETERS","timestamp":1699691118,"int_value":589},"sunroofEventActive":{"timestamp_in_ms":1699607930000,"bool_value":false,"timestamp":1699607930},"chargingPower":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"auxheattime1":{"display_value":"00:00","timestamp_in_ms":1699699154000,"clock_hour_unit":"T24H","timestamp":1699699154,"int_value":0},"averageSpeedStart":{"display_value":"41","timestamp_in_ms":1699691121000,"speed_unit":"KM_PER_HOUR","double_value":41.2,"timestamp":1699691121},"drivenTimeReset":{"timestamp_in_ms":1699691121000,"timestamp":1699691121,"int_value":3559},"positionLat":{"timestamp_in_ms":1699691116000,"double_value":1.23,"timestamp":1699691116},"auxheattime2":{"display_value":"00:00","timestamp_in_ms":1699699154000,"clock_hour_unit":"T24H","timestamp":1699699154,"int_value":0},"auxheattime3":{"display_value":"00:00","timestamp_in_ms":1699699154000,"clock_hour_unit":"T24H","timestamp":1699699154,"int_value":0},"vehicleLockState":{"timestamp_in_ms":1699691171000,"timestamp":1699691171,"int_value":3},"windowStatusRearRightBlind":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"ecoscorefreewhl":{"display_value":"59","timestamp_in_ms":1699697254000,"ratio_unit":"PERCENT","timestamp":1699697254,"int_value":59},"doorlockstatusrearright":{"timestamp_in_ms":1699691171000,"bool_value":false,"timestamp":1699691171},"chargingPowerEcoLimit":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"distanceStart":{"display_value":"19.2","timestamp_in_ms":1699691121000,"distance_unit":"KILOMETERS","double_value":19.2,"timestamp":1699691121},"soc":{"timestamp_in_ms":1699697254000,"ratio_unit":"PERCENT","nil_value":true,"timestamp":1699697254,"status":4},"distanceReset":{"display_value":"2929.5","timestamp_in_ms":1699691121000,"distance_unit":"KILOMETERS","double_value":2929.5,"timestamp":1699691121},"sunroofStatusFrontBlind":{"timestamp_in_ms":1699607930000,"timestamp":1699607930,"int_value":1},"windowstatusfrontleft":{"timestamp_in_ms":1699656618000,"timestamp":1699656618,"int_value":2},"speedUnitFromIC":{"timestamp_in_ms":1699608131563,"nil_value":true,"timestamp":1699608131,"status":1},"windowStatusRearLeftBlind":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"doorlockstatusvehicle":{"timestamp_in_ms":1699691171000,"timestamp":1699691171,"int_value":2},"tankLevelAdBlue":{"display_value":"87","timestamp_in_ms":1699697254000,"ratio_unit":"PERCENT","timestamp":1699697254,"int_value":87},"tirepressureRearLeft":{"display_value":"240","timestamp_in_ms":1699694140000,"pressure_unit":"KPA","double_value":242.5,"timestamp":1699694140},"liquidconsumptionstart":{"display_value":"6.2","timestamp_in_ms":1699691121000,"double_value":6.204,"combustion_consumption_unit":"LITER_PER_100KM","timestamp":1699691121},"temperaturePoints":{"temperature_points_value":{"temperature_points":[{"temperature":22,"zone":"frontLeft","temperature_display_value":"22.0"},{"temperature":22,"zone":"frontRight","temperature_display_value":"22.0"}]},"timestamp_in_ms":1699699154000,"temperature_unit":"CELSIUS","timestamp":1699699154},"departuretimesoc":{"timestamp_in_ms":1695050995000,"ratio_unit":"PERCENT","nil_value":true,"timestamp":1695050995,"status":4},"selectedChargeProgram":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"chargePrograms":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"distanceZEReset":{"display_value":"124.6","timestamp_in_ms":1699690891000,"distance_unit":"KILOMETERS","double_value":124.6,"timestamp":1699690891},"maxSocUpperLimit":{"timestamp_in_ms":1699608174459,"ratio_unit":"PERCENT","nil_value":true,"timestamp":1699608174,"status":1},"tiremarker":{"timestamp_in_ms":1699697254000,"nil_value":true,"timestamp":1699697254,"status":3},"overallRange":{"display_value":"589","timestamp_in_ms":1699691118000,"distance_unit":"KILOMETERS","double_value":589,"timestamp":1699691118},"tirewarningsprw":{"timestamp_in_ms":1699697254000,"nil_value":true,"timestamp":1699697254,"status":4},"precondSeatFrontLeft":{"timestamp_in_ms":1699607930000,"bool_value":false,"timestamp":1699607930},"drivenTimeZEReset":{"timestamp_in_ms":1699691121000,"timestamp":1699691121,"int_value":514},"tireMarkerFrontRight":{"timestamp_in_ms":1699697254000,"timestamp":1699697254,"int_value":0},"serviceintervaldistance":{"display_value":"22315","timestamp_in_ms":1699691118000,"distance_unit":"KILOMETERS","timestamp":1699691118,"int_value":22315},"chargeCouplerACLockStatus":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"precondActive":{"timestamp_in_ms":1699607930000,"bool_value":false,"timestamp":1699607930},"ecoscorebonusrange":{"display_value":"1.9","timestamp_in_ms":1699697254000,"distance_unit":"KILOMETERS","double_value":1.9,"timestamp":1699697254},"precondState":{"timestamp_in_ms":1699607930000,"timestamp":1699607930},"rangeAdBlue":{"display_value":"630000","timestamp_in_ms":1699697254000,"distance_unit":"KILOMETERS","timestamp":1699697254,"int_value":630000},"sunroofEvent":{"timestamp_in_ms":1699607930000,"timestamp":1699607930,"int_value":0},"liquidconsumptionreset":{"display_value":"6.4","timestamp_in_ms":1699691121000,"double_value":6.444,"combustion_consumption_unit":"LITER_PER_100KM","timestamp":1699691121},"warningbrakefluid":{"timestamp_in_ms":1699697254000,"bool_value":false,"timestamp":1699697254},"hvBatteryThermalPropagationEvent":{"timestamp_in_ms":1699623771000,"timestamp":1699623771,"int_value":0},"chargingMode":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"windowstatusfrontright":{"timestamp_in_ms":1699656525000,"timestamp":1699656525,"int_value":4},"auxheatActive":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"electricconsumptionstart":{"timestamp_in_ms":1699699153000,"electricity_consumption_unit":"KWH_PER_100KM","nil_value":true,"timestamp":1699699153,"status":4},"trackingStateHU":{"timestamp_in_ms":1699689302000,"bool_value":true,"timestamp":1699689302},"chargingErrorInfrastructure":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"ignitionstate":{"timestamp_in_ms":1699691121000,"timestamp":1699691121,"int_value":0},"precondSeatRearLeft":{"timestamp_in_ms":1699607930000,"nil_value":true,"timestamp":1699607930,"status":4},"rooftopstatus":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"electricRatioReset":{"timestamp_in_ms":1699608131563,"nil_value":true,"timestamp":1699608131,"status":1},"warningwashwater":{"timestamp_in_ms":1699697254000,"bool_value":false,"timestamp":1699697254},"sunroofstatus":{"timestamp_in_ms":1699607930000,"timestamp":1699607930,"int_value":0},"nextDepartureTimeWeekday":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"minSocLowerLimit":{"timestamp_in_ms":1699608174459,"ratio_unit":"PERCENT","nil_value":true,"timestamp":1699608174,"status":1},"filterParticleLoading":{"timestamp_in_ms":1699092876000,"timestamp":1699092876,"int_value":0},"tirepressureFrontRight":{"display_value":"245","timestamp_in_ms":1699694140000,"pressure_unit":"KPA","double_value":245,"timestamp":1699694140},"oilWarningLevel":{"timestamp_in_ms":1699697254000,"timestamp":1699697254,"int_value":1},"chargingPowerControl":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"auxheatwarnings":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"precondSeatRearRight":{"timestamp_in_ms":1699607930000,"nil_value":true,"timestamp":1699607930,"status":4},"tirepressureFrontLeft":{"display_value":"245","timestamp_in_ms":1699694140000,"pressure_unit":"KPA","double_value":247.5,"timestamp":1699694140},"auxheatruntime":{"timestamp_in_ms":1699699154000,"nil_value":true,"timestamp":1699699154,"status":3},"proximityCalculationForVehiclePositionRequired":{"timestamp_in_ms":1699699123563,"bool_value":false,"timestamp":1699699123},"chargingactive":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"vehicleDataConnectionState":{"timestamp_in_ms":1699697546182,"bool_value":true,"timestamp":1699697546},"windowStatusRearBlind":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"endofChargeTimeWeekday":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"warningcoolantlevellow":{"timestamp_in_ms":1699697254000,"bool_value":false,"timestamp":1699697254},"doorStatusOverall":{"timestamp_in_ms":1699691155000,"timestamp":1699691155,"int_value":0},"drivenTimeZEStart":{"timestamp_in_ms":1699691121000,"timestamp":1699691121,"int_value":4},"ecoscoreaccel":{"display_value":"91","timestamp_in_ms":1699697254000,"ratio_unit":"PERCENT","timestamp":1699697254,"int_value":91},"sunroofStatusRearBlind":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"departuretime":{"timestamp_in_ms":1699608174459,"clock_hour_unit":"T24H","nil_value":true,"timestamp":1699608174,"status":1},"decklidstatus":{"timestamp_in_ms":1699691169000,"bool_value":false,"timestamp":1699691169},"doorlockstatusfrontleft":{"timestamp_in_ms":1699691171000,"bool_value":false,"timestamp":1699691171},"rangeElectricWltp":{"timestamp_in_ms":1699699154000,"distance_unit":"KILOMETERS","nil_value":true,"timestamp":1699699154,"status":4},"chargeFlapDCStatus":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"tireWarningLevelPrw":{"timestamp_in_ms":1699697254000,"nil_value":true,"timestamp":1699697254,"status":4},"tanklevelpercent":{"display_value":"59","timestamp_in_ms":1699697254000,"ratio_unit":"PERCENT","timestamp":1699697254,"int_value":59},"chargeCouplerDCLockStatus":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"doorlockstatusrearleft":{"timestamp_in_ms":1699691171000,"bool_value":false,"timestamp":1699691171},"auxheatstatus":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"electricRatioStart":{"timestamp_in_ms":1699608131563,"nil_value":true,"timestamp":1699608131,"status":1},"precondError":{"timestamp_in_ms":1699607930000,"timestamp":1699607930,"int_value":0},"chargingErrorDetails":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4},"vtime":{"timestamp_in_ms":1699699155000,"timestamp":1699699155,"changed":true,"int_value":1699702756},"tireMarkerFrontLeft":{"timestamp_in_ms":1699697254000,"timestamp":1699697254,"int_value":0},"departureTimeIcon":{"timestamp_in_ms":1695050995000,"nil_value":true,"timestamp":1695050995,"status":4}}
But no other thing or item is updated!
Any hint?
Thanks for the logs.
Please double check versioning.
  1. There’s no OH4.4 version. Do you mean OH4.0.4?
  2. Bundle installed is version 2.3-alpha for OH3.4 according to proto update. If you`ve installed OH4.x it doesn’t match
    “bindingInfo”: {
    “version”: “2.3-alpha”,
    “oh-bundle”: “3.4.0.202309262121”,
    “vehicle”: “mercedesme:combustion”
  3. There already a 2.4 beta version for this binding. It contains especially a bugfix for combustion vehicles.
So if you are running on OH4.x
  • deinstall bundle in Marketplace
  • ensure it’s really deleted: check directory /var/lib/openhab/marketplace/bundles
  • and then download OH4.1 bundle version from resources and drop it into addons folder
Many Thanks.
That resolved my issues!
