Mi(Xiaomi) Smart home bindings?
I bought this lock https://www.gearbest.com/access-control/pp_1142172.html?wid=1433363
Xiaomi Smarthome binding support this lock?
@dimalo, thanks for all what you do on this. I have just received 3 Vibration Sensors and I’m willing to help getting logs but I don’t know how. Is there a place with a bit of explanation of what I can do to provide the info needed?
Got 6 of the Vibration Sensors today. Would be great If your can add Support to this really good working Binding.
Thx
Thanks for implementing this! Still figuring out how I can do all gestures :slight_smile:
these are all available, correct?
MOVE
ROTATE_RIGHT
ROTATE_LEFT
FLIP90
FLIP180
TAP_TWICE
SHAKE_AIR
FREE_FALL
ALERT
Yes, this gestures are available … but i don‘t understand the alert. What‘s to do to receive an alert?
Guess you need a alert/event to trigger rules.
How should your .rules file know when it’s triggered :slight_smile:
My Cube is triggering the Alert action when it senses slight vibrations. for example if it lies on the table and somebody gets to the table and bumps on it.
Hi @thefathefa, I also received some and added the sensor already, see here. I added a small tutorial in the readme explaining how to get the informations from new devices.
for the trigger i don’t use the alert event.
rule "OgSr Xiaomi Cube"
    Channel 'mihome:sensor_cube:158d00xxxxxxxx:action' triggered
    var actionName = receivedEvent.getEvent()
    switch(actionName) {
        case "MOVE":
        case "ROTATE_RIGHT":
Have they added info about what face is up and what face was previously up when pushed or double tapped?
That was (the main) part of the reason I stopped using the Mi Gateway for my cubes. The gateway had no events for that.
You did a very good job to update the binding + readme. Now everybody can easily help you with new devices.
I’ll check the new jar this evening.
I also notived that the power socket sends 3 events when turning it on or off. It always results in the correct one, but I assume that this is not normal?
2018-09-10 15:49:17.966 [ome.event.ItemCommandEvent] - Item 'Xiaomi_Socket_Power' received command ON
2018-09-10 15:49:17.984 [vent.ItemStateChangedEvent] - Xiaomi_Socket_Power changed from OFF to ON
2018-09-10 15:49:18.030 [vent.ItemStateChangedEvent] - Xiaomi_Socket_Power changed from ON to OFF
2018-09-10 15:49:18.066 [vent.ItemStateChangedEvent] - Xiaomi_Socket_Power changed from OFF to ON
2018-09-10 15:49:58.976 [ome.event.ItemCommandEvent] - Item 'Xiaomi_Socket_Power' received command OFF
2018-09-10 15:49:59.002 [vent.ItemStateChangedEvent] - Xiaomi_Socket_Power changed from ON to OFF
2018-09-10 15:49:59.014 [vent.ItemStateChangedEvent] - Xiaomi_Socket_Power changed from OFF to ON
2018-09-10 15:49:59.020 [vent.ItemStateChangedEvent] - Xiaomi_Socket_InUse changed from OFF to ON
2018-09-10 15:49:59.030 [vent.ItemStateChangedEvent] - Xiaomi_Socket_LoadPower changed from 0.00 to 13.32
2018-09-10 15:49:59.100 [vent.ItemStateChangedEvent] - Xiaomi_Socket_Power changed from ON to OFF
2018-09-10 15:49:59.111 [vent.ItemStateChangedEvent] - Xiaomi_Socket_InUse changed from ON to OFF
2018-09-10 15:49:59.115 [vent.ItemStateChangedEvent] - Xiaomi_Socket_LoadPower changed from 13.32 to 0
As you can see, the inUse & LoadPower item is only updated after I switch off the socket. I generated this logs a few times, with more or less time between switching on/off, but the output is always the same.
@dimalo, great ! I installed it and I have the vibration sensors up. Super fast, thanks a lot.
I also saw you guys are considering the lock as well for support, I’ll give it a try for sure.
hey @wars
please open an issue and post some trace logs :ok_hand:
Is this enough?
Power off
2018-09-15 00:06:42.095 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Device 158d0001xxxxxx on channel mihome:sensor_plug:socket_plug:power received command OFF
2018-09-15 00:06:42.091 [ome.event.ItemCommandEvent] - Item 'Xiaomi_Socket_Power' received command OFF
2018-09-15 00:06:42.121 [vent.ItemStateChangedEvent] - Xiaomi_Socket_Power changed from ON to OFF
2018-09-15 00:06:42.124 [DEBUG] [g.mihome.handler.XiaomiBridgeHandler] - Send to bridge mihome:bridge:gateway: {"cmd": "write", "sid": "158d0001xxxxxx", "data": "{\"status\": \"off\", \"key\": \"5339AFB96DCE180DFDECD7B1985C98D5"}"}
2018-09-15 00:06:42.130 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Sending message: {"cmd": "write", "sid": "158d0001xxxxxx", "data": "{\"status\": \"off\", \"key\": \"5339AFB96DCE180DFDECD7B1985C98D5"}"} to /192.168.0.80:9898
2018-09-15 00:06:42.535 [DEBUG] [.mihome.internal.socket.XiaomiSocket] - Received Datagram from 192.168.0.80:9898 on Port 9898
2018-09-15 00:06:42.538 [TRACE] [g.mihome.handler.XiaomiBridgeHandler] - Received message {"cmd":"write_ack","model":"plug","sid":"158d0001xxxxxx","short_id":52627,"data":"{\"voltage\":3600,\"status\":\"on\",\"inuse\":\"1\",\"power_consumed\":\"6059\",\"load_power\":\"11.92\"}"}
2018-09-15 00:06:42.541 [TRACE] [g.mihome.handler.XiaomiBridgeHandler] - Updated "last time seen" for device 158d0001xxxxxx
2018-09-15 00:06:42.545 [DEBUG] [g.mihome.handler.XiaomiBridgeHandler] - Device 158d0001xxxxxx honored write request
2018-09-15 00:06:42.550 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Item got update: {"cmd":"write_ack","model":"plug","sid":"158d0001xxxxxx","short_id":52627,"data":"{\"voltage\":3600,\"status\":\"on\",\"inuse\":\"1\",\"power_consumed\":\"6059\",\"load_power\":\"11.92\"}"}
2018-09-15 00:06:42.565 [vent.ItemStateChangedEvent] - Xiaomi_Socket_Power changed from OFF to ON
2018-09-15 00:06:42.584 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Data received and notified 1 listeners
2018-09-15 00:06:42.587 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Thread Thread[Thread-93,5,main] waiting for data on port 9898
2018-09-15 00:06:42.616 [DEBUG] [.mihome.internal.socket.XiaomiSocket] - Received Datagram from 192.168.0.80:4321 on Port 9898
2018-09-15 00:06:42.618 [TRACE] [g.mihome.handler.XiaomiBridgeHandler] - Received message {"cmd":"report","model":"plug","sid":"158d0001xxxxxx","short_id":52627,"data":"{\"status\":\"off\"}"}
2018-09-15 00:06:42.620 [TRACE] [g.mihome.handler.XiaomiBridgeHandler] - Updated "last time seen" for device 158d0001xxxxxx
2018-09-15 00:06:42.623 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Item got update: {"cmd":"report","model":"plug","sid":"158d0001xxxxxx","short_id":52627,"data":"{\"status\":\"off\"}"}
2018-09-15 00:06:42.635 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Data received and notified 1 listeners
2018-09-15 00:06:42.637 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Thread Thread[Thread-93,5,main] waiting for data on port 9898
2018-09-15 00:06:42.644 [vent.ItemStateChangedEvent] - Xiaomi_Socket_Power changed from ON to OFF
2018-09-15 00:06:42.655 [vent.ItemStateChangedEvent] - Xiaomi_Socket_InUse changed from ON to OFF
2018-09-15 00:06:42.657 [vent.ItemStateChangedEvent] - Xiaomi_Socket_LoadPower changed from 11.92 to 0
2018-09-15 00:06:47.969 [DEBUG] [.mihome.internal.socket.XiaomiSocket] - Received Datagram from 192.168.0.80:4321 on Port 9898
2018-09-15 00:06:47.973 [TRACE] [g.mihome.handler.XiaomiBridgeHandler] - Received message {"cmd":"heartbeat","model":"gateway","sid":"34ce008bfe89","short_id":"0","token":"5UeSl7xoRcfrcQcq","data":"{\"ip\":\"192.168.0.80\"}"}
2018-09-15 00:06:47.976 [TRACE] [g.mihome.handler.XiaomiBridgeHandler] - Updated "last time seen" for device 34ce008bfe89
2018-09-15 00:06:47.980 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Item got update: {"cmd":"heartbeat","model":"gateway","sid":"34ce008bfe89","short_id":"0","token":"5UeSl7xoRcfrcQcq","data":"{\"ip\":\"192.168.0.80\"}"}
2018-09-15 00:06:47.983 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Data received and notified 1 listeners
2018-09-15 00:06:47.986 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Thread Thread[Thread-93,5,main] waiting for data on port 9898
Power on
2018-09-15 00:06:49.064 [ome.event.ItemCommandEvent] - Item 'Xiaomi_Socket_Power' received command ON
2018-09-15 00:06:49.085 [vent.ItemStateChangedEvent] - Xiaomi_Socket_Power changed from OFF to ON
2018-09-15 00:06:49.082 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Device 158d0001xxxxxx on channel mihome:sensor_plug:socket_plug:power received command ON
2018-09-15 00:06:49.102 [DEBUG] [g.mihome.handler.XiaomiBridgeHandler] - Send to bridge mihome:bridge:gateway: {"cmd": "write", "sid": "158d0001xxxxxx", "data": "{\"status\": \"on\", \"key\": \"8FBDE7243A0E729A0B6863C8F1599B1B"}"}
2018-09-15 00:06:49.108 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Sending message: {"cmd": "write", "sid": "158d0001xxxxxx", "data": "{\"status\": \"on\", \"key\": \"8FBDE7243A0E729A0B6863C8F1599B1B"}"} to /192.168.0.80:9898
2018-09-15 00:06:49.514 [DEBUG] [.mihome.internal.socket.XiaomiSocket] - Received Datagram from 192.168.0.80:9898 on Port 9898
2018-09-15 00:06:49.517 [TRACE] [g.mihome.handler.XiaomiBridgeHandler] - Received message {"cmd":"write_ack","model":"plug","sid":"158d0001xxxxxx","short_id":52627,"data":"{\"voltage\":3600,\"status\":\"off\",\"inuse\":\"0\",\"power_consumed\":\"6059\",\"load_power\":\"0.00\"}"}
2018-09-15 00:06:49.518 [TRACE] [g.mihome.handler.XiaomiBridgeHandler] - Updated "last time seen" for device 158d0001xxxxxx
2018-09-15 00:06:49.521 [DEBUG] [g.mihome.handler.XiaomiBridgeHandler] - Device 158d0001xxxxxx honored write request
2018-09-15 00:06:49.523 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Item got update: {"cmd":"write_ack","model":"plug","sid":"158d0001xxxxxx","short_id":52627,"data":"{\"voltage\":3600,\"status\":\"off\",\"inuse\":\"0\",\"power_consumed\":\"6059\",\"load_power\":\"0.00\"}"}
2018-09-15 00:06:49.545 [vent.ItemStateChangedEvent] - Xiaomi_Socket_Power changed from ON to OFF
2018-09-15 00:06:49.551 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Data received and notified 1 listeners
2018-09-15 00:06:49.554 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Thread Thread[Thread-93,5,main] waiting for data on port 9898
2018-09-15 00:06:49.604 [DEBUG] [.mihome.internal.socket.XiaomiSocket] - Received Datagram from 192.168.0.80:4321 on Port 9898
2018-09-15 00:06:49.607 [TRACE] [g.mihome.handler.XiaomiBridgeHandler] - Received message {"cmd":"report","model":"plug","sid":"158d0001xxxxxx","short_id":52627,"data":"{\"status\":\"on\"}"}
2018-09-15 00:06:49.610 [TRACE] [g.mihome.handler.XiaomiBridgeHandler] - Updated "last time seen" for device 158d0001xxxxxx
2018-09-15 00:06:49.613 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Item got update: {"cmd":"report","model":"plug","sid":"158d0001xxxxxx","short_id":52627,"data":"{\"status\":\"on\"}"}
2018-09-15 00:06:49.620 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Data received and notified 1 listeners
2018-09-15 00:06:49.623 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Thread Thread[Thread-93,5,main] waiting for data on port 9898
2018-09-15 00:06:49.629 [vent.ItemStateChangedEvent] - Xiaomi_Socket_Power changed from OFF to ON
2018-09-15 00:06:57.943 [DEBUG] [.mihome.internal.socket.XiaomiSocket] - Received Datagram from 192.168.0.80:4321 on Port 9898
2018-09-15 00:06:57.946 [TRACE] [g.mihome.handler.XiaomiBridgeHandler] - Received message {"cmd":"heartbeat","model":"gateway","sid":"34ce008bfe89","short_id":"0","token":"1KPVYIMYdofMJ44G","data":"{\"ip\":\"192.168.0.80\"}"}
2018-09-15 00:06:57.949 [TRACE] [g.mihome.handler.XiaomiBridgeHandler] - Updated "last time seen" for device 34ce008bfe89
2018-09-15 00:06:57.953 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Item got update: {"cmd":"heartbeat","model":"gateway","sid":"34ce008bfe89","short_id":"0","token":"1KPVYIMYdofMJ44G","data":"{\"ip\":\"192.168.0.80\"}"}
2018-09-15 00:06:57.956 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Data received and notified 1 listeners
2018-09-15 00:06:57.959 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Thread Thread[Thread-93,5,main] waiting for data on port 9898
Hi guys,
I followed your wonderful “read me” explanation from the binding page in order to track something from Wima Lock I recently bought (few posts up), but all I got is sort of this:
2018-09-16 14:03:55.228 [TRACE] [g.mihome.handler.XiaomiBridgeHandler] - Received message {"cmd":"read_ack","model":"","sid":"158dXXXXdf77c","short_id":54728,"data":"{\"voltage\":3350}"}
2018-09-16 14:03:55.228 [TRACE] [g.mihome.handler.XiaomiBridgeHandler] - Updated "last time seen" for device 158dXXXXdf77c
2018-09-16 14:03:55.228 [DEBUG] [g.mihome.handler.XiaomiBridgeHandler] - Device 158dXXXXdf77c honored read request
2018-09-16 14:03:55.228 [DEBUG] [discovery.XiaomiItemDiscoveryService] - Unknown discovered model:
2018-09-16 14:03:55.181 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Sending message: {"cmd": "read", "sid": "158dXXXXdf77c"} to /192.168.1.102:9898
2018-09-16 15:25:09.186 [DEBUG] [g.mihome.handler.XiaomiBridgeHandler] - Send to bridge mihome:bridge:7811dXXXX356: {"cmd": "read", "sid": "158dXXXXdf77c"}
2018-09-16 15:25:09.201 [TRACE] [g.mihome.handler.XiaomiBridgeHandler] - Received message {"cmd":"read_ack","model":"","sid":"158dXXXXdf77c","short_id":54728,"data":"{\"voltage\":3350}"}
Seems there is communication between the lock and the gate, but only about the battery level. No any trace for msgs when the lock is locked/unlocked, no info which key is used, no info when not allowed key is used or some of the allowed is forgotten in the lock. Any ideas how to chase that.
Thank you very much for the binding and all the efforts to add more and more stuff to it!
I’m getting “unknown_event” and “short_pressed” from my dual switch wireless buttons. This would seem kind of strange?
Also, does these buttons support long press, short press etc (in hardware, binding seems to not right have support)?
Even if the buttons doesn’t support long press etc. it would seem strange that a single short press would trigger “unknown”?
2018-09-17 18:39:39.178 [vent.ChannelTriggeredEvent] - mihome:86sw2:158d000255ee87:ch1 triggered SHORT_PRESSED
2018-09-17 18:39:39.185 [vent.ChannelTriggeredEvent] - mihome:86sw2:158d000255ee87:ch1 triggered UNKNOWN_EVENT
Also the dual channel reports twice, which is not so optimal as everything would turn both on and then off again in the same key press.
2018-09-17 21:11:48.564 [vent.ChannelTriggeredEvent] - mihome:86sw2:158d000255ee87:dual_ch triggered SHORT_PRESSED
2018-09-17 21:11:48.572 [vent.ChannelTriggeredEvent] - mihome:86sw2:158d000255ee87:dual_ch triggered SHORT_PRESSED
hey guys!
Any news about the Aqara shock / vibration sensors? (i mean, the aqara djt11lm)
Atm the “Xiaomi Mi IO” and the “Xiaomi Mi smart home” bindings still can’t find them!
Thanks in advance :wink:
ps: i know about the guide in the binding page about those sensors, to sniff gateway messagges…but even if i found them i can’t read values and put in sitemap!
@Sladaar
https://openhab.jfrog.io/openhab/libs-pullrequest-local/org/openhab/binding/org.openhab.binding.mihome/2.4.0-SNAPSHOT/org.openhab.binding.mihome-2.4.0-SNAPSHOT.jar
Many thanks @horschte, i just figured out while searching for the problem that I still was in OH2.2 (so the xiaomi binding couldn’t update i guess and was still in 2.2), and I was damn sure i was in 2.3.
Only now i remember how painful was the migration (in windows 10), too many problems and i used the 2.2 backup to have a working system again.
Thanks for the hint!
So anybody corrected the Xiaomi Smart home binding issues without going back to 2.2?
I’m losing my mind on this one, tried absolute everything.
Paper UI detects all devices and the gateway is online, but after 2 hours all devices go offline and doesn’t send any values.
Any Help is highly appreciated
