i guess i am doing something wrong here.
i have ZERO experience with openhab’s text rule engine so i am using the rule engine from paperUI which is usually ok for me.
i am trying to catch the LONG_PRESSED event but it does not appear in my list and it doesn’t work when i write it. also my xiaomi binding does not discover my vibration sensor from xiaomi even though i read that it should.
can anyone help me with that?
these are my options…
Seems like there is some confusion about gateway versions and the difference between aqara and xiaomi.
Now following the smart home lineup for quite a while this is my impression of it’s history:
Important to know is, that Xiaomi has made a platform for different manufacturers to integrate their smart devices in one big ecosystem. For example Yeelight - they build the lamps, but integrate them with the Xiaomi protocol making them compatible with the MiHome App. Same for the vacuum robot, which is build by a different company (Rockrobo or so…). I guess Mijia might be similar…
This is also the case for our smart home devices. The first generation was built by Lumi. I don’t know if they rebranded to Aqara or if it’s a different company now but the newer devices are all built by Aqara.
Actually this is not the case. My gateway identifies iteslf with the MI IO binding (see here) as lumi.gateway.v3 and it’s the round one!
This is the square one @bartsnijder is talking about. I know, very confusing!
So to clarify:
Round “Lumi” gateway: there are two versions (v2 & v3), which look the same and are round, probably the ones most people use here - I don’t know what the difference is between them
Round “Aqara” gateway: the new gateway (supporting HomeKit) - this is not tested with the binding, brand new, and the community would appreciate any pioneer buying that thing and giving it a go with the binding and OH
Devices, which are able to act as a gateway, for example the Air Conditioning Companion see here
Regarding support for the acpartner devices - If anybody has this device please do following:
Enable TRACE logging, make sure the acpartner is set up in your network and developer mode is on. Then trigger a discovery in OH PaperUI and log the result. The binding should send a message with { cmnd: whois } and every gateway answer. Then open an issue and post the log here.
I have just had a Aqara delivered and have downloaded the Mihome binding. PaperUI did not find the hub after i have set it up on my ipad (that was a task in its self). Im pretty well stuck now as my knowledge is limited when it come coding etc.
@jsn
You can follow the same procedure to capture the communication between openhab and the gateway.
You can find a tutorial on how to log here in the binding documentation
Today I received my 2nd gateway which is now succesfuly added to the OH system. Due to the mentioned rumours about not being able to add gatweways with updated firmware I skipped updating them.
Although the system works fine now and is not WAN-connected updating to the latest firmware is not necessary yet, but has anybody verified the firmware issues?
Is it indeed not possible to go to the latest FW without any OH integration problems or was there another root cause?
Thanks!
I have a motion detector. I did not use it for a while and deleted it in Openhab. Now I wanted to use it again but the ID does not know anymore. He does not appear in the INBOX anymore. I have already deleted it in the MiHome app and newly trained, unfortunately without success!
Does anyone have an idea how I can create the motion detector again?
I have changed the battery. I can use the device into the MiHome App without problems. The only problem is that the sonsor no longer appears in openhab.
