good morning
I have been reading and copying examples from the community for many days.
One of the examples used was the binding of “MILIGHT”, when I really had to use the “YEELIGHT”, I guess rookie failure. I have deleted the “MILIGHT” binding, and the commands in the rules, but I still get error messages in the log.
How should I properly uninstall the binding and related orders?
Thank you very much
Sorry for my english is a translation from google
I use Openhabian
You can uninstall the binding and any Things associated with that binding through PaperUI. Browse to the binding in the Add-ons tab and choose uninstall.
Thank you for your response to my problem.
I already have the binding uninstalled.
I think the problem is that you delete the binding before detaching the items
Since 2 days ago I deleted the binding and during this time I have restarted more than once openhabian.
Somewhere there is some binding or rules and I can not find it to erase it.
Can there be a temporary file that I can not control?
When openhabian is restarted, will all temporarys be erased? Or have to be erased manually.
Thank you so much
2017-08-15 12:21:59.655 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update ‘OFF’ for item ‘Light_FF_Bed2_Ceiling’ to handler for channel ‘milight:whiteLed:eec4f96c:3:ledtemperature’, because no thing with the UID ‘milight:whiteLed:eec4f96c:3’ could be found.
Somewhere these links are created, but I can not find them
2017-08-15 19:41:15.642 [ItemChannelLinkAddedEvent ] - Link ‘Light_FF_Bed2_Ceiling-milight:whiteLed:eec4f96c:3:ledbrightness’ has been added.
2017-08-15 19:41:15.644 [ItemChannelLinkAddedEvent ] - Link ‘Light_FF_Bed2_Ceiling_NightMode-milight:whiteLed:ed025e35:1:lednightmode’ has been added.
2017-08-15 19:41:15.646 [ItemChannelLinkAddedEvent ] - Link ‘Light_FF_Bed2_Ceiling-milight:whiteLed:eec4f96c:3:ledtemperature’ has been added.
2
I could not detect them, I thought I had to do it with MILIGT and I did not know how to do it manually, then I realized that I had to do it with YEELIGHT.
Normally not, but I have tested it in case they are generated and could erase it.
Sorry to bother you, tomorrow I’ll keep looking, my family complains.
Goodnight
Where can I find the link possibly created with Habmin?
I can not find it.
Link ‘Light_FF_Bed2_Ceiling-milight: whiteLed: eec4f96c: 3: lednightmode’ has been added.
Bindig, is unlated
In PaperUI, it does not exist or appear as hidden.
The cache is cleared.
In simple mode it does not appear or be created.
I do not know what I can do anymore
2017-08-18 11:00:33.790 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'OFF' for item 'Light_FF_Bed2_Ceiling' to handler for channel 'milight:whiteLed:ed025e35:1:ledtemperature', because no thing with the UID 'milight:whiteLed:ed025e35:1' could be found.
2017-08-18 11:00:33.793 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'OFF' for item 'Light_FF_Bed2_Ceiling' to handler for channel 'milight:whiteLed:eec4f96c:2:lednightmode', because no thing with the UID 'milight:whiteLed:eec4f96c:2' could be found.
2017-08-18 11:00:33.795 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'OFF' for item 'Light_FF_Bed2_Ceiling' to handler for channel 'milight:whiteLed:eec4f96c:3:lednightmode', because no thing with the UID 'milight:whiteLed:eec4f96c:3' could be found.
2017-08-18 11:00:33.796 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'OFF' for item 'Light_FF_Bed2_Ceiling' to handler for channel 'milight:whiteLed:ed025e35:0:ledtemperature', because no thing with the UID 'milight:whiteLed:ed025e35:0' could be found.
2017-08-18 11:00:33.798 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'OFF' for item 'Light_FF_Bed2_Ceiling' to handler for channel 'milight:whiteLed:eec4f96c:1:lednightmode', because no thing with the UID 'milight:whiteLed:eec4f96c:1' could be found.
2017-08-18 11:00:33.799 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'OFF' for item 'Light_FF_Bed2_Ceiling' to handler for channel 'milight:whiteLed:92d52c32:1:lednightmode', because no thing with the UID 'milight:whiteLed:92d52c32:1' could be found
Hello Joseph, I’m a rookie, I’m trying to install the Yeelight without any results. May I ask you how have you done it? I have installed openhabian (openhab2) on my raspberry and I don’t have any other binding, I need to control 2 Yeelight ceiling lamp. Thanks so much
Thanks Joseph but I’m not able to find anything, so I don’t know if I’ve to add some binding ( I’m using only the Yeelight 2.1.0 snapshot); at the end what’s i the command “channel” for the item switch, in the online manual I haven’t found.
Thanks again
