Recently started off on OpenHAB 1.8 and then made the switch to 2.0. I’m having issues connecting with my openHAB app. I can connect via the local network EG: 192.168.1.111:8080/classicui/app?sitemap=home through my browser, but when I point to that address via the app it doesn’t go anywhere and I get an error stating: “HTTP Error: server Error”. Also the autodiscover doesn’t work in the app to find my sitemap either. Thoughts? log file
Yes, but that does not mean that the auto-discovery from the app works.
The default openHAB distro does not contain the mDNS bundle and thus it does not announce itself - I have just fixed that and tomorrows build of the distro should then have it always included. It should then also work with the version from the PlayStore.
So it sounds like I should hold off a day, and re-install then? I’m working on a fresh install and there are quite a few bugs that I’ve run into so starting fresh might not be the worst idea. Will that be in the snapshot or does it need to be pulled from github?
Still learning the ropes here. From the snapshot what should I copy over exactly? Everything inside and that won’t mess with the install? (things are actually working! don’t want to mess them up)
look up openhab2-tools. its an update script that will update the install. pay attention to the install directory, you may need to change to match yours. also, # in front of designer lines if you dont want it installed. also, will have to make the /DOWN directory. also look at this…
