I’m currently following instructions from the Sonoff/Tasmota community on how to connect my 8266 E12 device to OpenHAB2 via MQTT. All three are installed and to some degree working but my log output (via Karaf consol using log:display) seems to think I’m trying to connect to 2 MQTT brokers, one of which is correct but the other “RobsMosquitto” isn’t. I can’t remember or find how OpenHAB2 was configured to reference RobsMosquiito and wondered if someone could help me remove it as it’s causing errors.
The log display MQTT bits looks like…
> 19:47:42.860 [INFO ] [openhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
> 19:47:42.860 [INFO ] [rt.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto'
> 19:47:42.916 [INFO ] [rt.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'robsmosquitto'
> 19:47:42.929 [ERROR] [rt.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
> org.eclipse.paho.client.mqttv3.MqttException: Connection lost
> at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:146) [218:org.openhab.io.transport.mqtt:1.11.0]
> at java.lang.Thread.run(Thread.java:748) [?:?]
> Caused by: java.io.EOFException
> at java.io.DataInputStream.readByte(DataInputStream.java:267) ~[?:?]
> at org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream.readMqttWireMessage(MqttInputStream.java:65) ~[?:?]
> at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:107) ~[?:?]
> ... 1 more
> 19:47:42.933 [ERROR] [rt.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'mosquitto' was lost: Connection lost : ReasonCode 32109 : Cause : null
> 19:47:42.934 [INFO ] [rt.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'mosquitto'
> 1
and followed by repetitions of…
> 20:06:24.295 [ERROR] [rt.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'mosquitto' was lost: Connection lost : ReasonCode 32109 : Cause : null
> 20:06:24.295 [INFO ] [rt.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'mosquitto'
> 20:06:34.297 [INFO ] [rt.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto'
> 20:06:34.302 [ERROR] [rt.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
> ... 1 more
> 20:06:34.303 [ERROR] [rt.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'robsmosquitto' was lost: Connection lost : ReasonCode 32109 : Cause : null
> 2
Thanks for your responses but I’ve checked my mqtt.cfg (and all other .cfg files in /services folder) and it does not contain any reference to robsmosquitto. Are there any other places where this could possibly have been configured during installation?
Did you by any chance install the new mqtt transport layer that some new experimental bindings are using like MySensors?
I did and it broke my mqtt binding and the errors were similar if I remember correctly.
I had to reinstall openhab from scratch. Twice…
Hi Josar,
Yes, it was a typo.
…and I’ve restarted my openHAB2 (2.2.0) a number of times but still have the same problem.
It’s not clear to me as to why my OpenHAB2 appears (or is it?) to be attempting to connect to 2 MQTT brokers - have I got this right? If so, why is it doing this?
Hi Vincent,
To be honest, I’m not sure. I was just following the guidance in the openHAB2 documentation about installing bindings for MQTT but don’t think I came across or installed anything related to MySensors.
…but i do agree about the total uninstallation of openHAB2 to try. I’ll see what comments I get back in the next few hours then give the uninstall a go.
Rob
Thanks Vincent. That’s got rid of the mysterious robsmosqutto.
However, my mosquitto fails to start with log info provided below.
Any ideas what’s wrong?
16:57:59.993 [INFO ] [rt.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto'
16:58:00.004 [ERROR] [rt.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
... 1 more
16:58:00.008 [ERROR] [rt.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'robsmosquitto' was lost: Connection lost : ReasonCode 32109 : Cause : null
16:58:00.009 [INFO ] [rt.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'robsmosquitto'
