Hi Team
I would like a clue on moving forward. Thinks are not behaving as expected…
Found this entry: New to MQTT and OH, trouble getting the binding down
Which is a good match, and have looked at that and here the suggestion is go get something into the events.log first – and I’m having problems with that… nothing happens.
I have created an test.items, added this line:
String freezer_inside [“Freezer %s”] {mqtt="<[oh2:borand/shed/freezer/temp_inside_freezer]"}
And I could image it is wrong, but is hoping that something will show somewhere… - nothing. Have restarted and all that stuff.
MQTT is working:
pi@raspbox3:/etc/openhab2/items $ mosquitto_sub -h localhost -d -t borand/shed/freezer/temp_inside_freezer
Client mosqsub/24929-raspbox3 sending CONNECT
Client mosqsub/24929-raspbox3 received CONNACK
Client mosqsub/24929-raspbox3 sending SUBSCRIBE (Mid: 1, Topic: borand/shed/freezer/temp_inside_freezer, QoS: 0)
Client mosqsub/24929-raspbox3 received SUBACK
Subscribed (mid: 1): 0
Client mosqsub/24929-raspbox3 received PUBLISH (d0, q0, r0, m0, ‘borand/shed/freezer/temp_inside_freezer’, … (7 bytes))
-14.062
mqtt.cfg contains these lines:
URL to the MQTT broker, e.g. tcp://localhost:1883 or ssl://localhost:8883
oh2.url=tcp://localhost:1883
Optional. Client id (max 23 chars) to use when connecting to the broker.
If not provided a default one is generated.
oh2.clientId=OpenHAB2_MQTT
In openhab.log I get these entries:
2016-12-23 09:59:39.323 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'oh2mqtt’
2016-12-23 09:59:39.635 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'oh2’
2016-12-23 09:59:39.661 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
Connection lost (32109) - java.io.EOFException
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:138)[199:org.openhab.io.transport.mqtt:1.9.0.201612130210]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_65]
Caused by: java.io.EOFException
at java.io.DataInputStream.readByte(DataInputStream.java:267)[:1.8.0_65]
at org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream.readMqttWireMessage(MqttInputStream.java:56)[199:org.openhab.io.transport.mqtt:1.9.0.201612130210]
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:100)[199:org.openhab.io.transport.mqtt:1.9.0.201612130210]
… 1 more
2016-12-23 09:59:39.677 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to ‘oh2mqtt’ was lost: Connection lost : ReasonCode 32109 : Cause : null
2016-12-23 09:59:39.678 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'oh2mqtt’
2016-12-23 09:59:49.679 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'oh2mqtt’
2016-12-23 09:59:49.693 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
… 1 more
2016-12-23 09:59:49.695 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to ‘oh2’ was lost: Connection lost : ReasonCode 32109 : Cause : null
2016-12-23 09:59:49.696 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker ‘oh2’
Here we get both a ‘oh2’ and a ‘oh2mqtt’ – I had the oh2 first, then changed it to oh2mqtt, but then I noticed the two entries, and changed it back (in mqtt.cfg) – and restart… but something is stored somewhere…
I have found this entry:
which also talks about two mqtt entries, and that it can be solved by “Karaf Console (ssh openhab@localhost -p 8101 with password: habopen) “
Tried to run this ssh command, but comes out and askes for password – guess the openhab users, but the password is openhab and is not ‘taken’ when I type it…
So, what is the next step…
