MQTT embedded Broker ERROR
Hallo,
i use openhab 2.5.3 with MQTT Broker Moquette and MQTT Broker Moquette.
After a while i got this error message as a loop.
19:46:13.611 [ERROR] [o.moquette.broker.NewNettyMQTTHandler] - Error processing protocol message: PUBLISH
java.lang.IllegalArgumentException: Could not deserialize [-84, -19, 0, 5, 115, 114, 0, 38, 105, 111, 46, 109, 111, 113, 117, 101, 116, 116, 101, 46, 98, 114, 111, 107, 101, 114, 46, 115, 117, 98, 115, 99, 114, 105, 112, 116, 105, 111, 110, 115, 46, 84, 111, 112, 105, 99, 0, 8, -86, 19, 52, -4, -125, -66, 2, 0, 1, 76, 0, 5, 116, 111, 112, 105, 99, 116, 0, 18, 76, 106, 97, 118, 97, 47, 108, 97, 110, 103, 47, 83, 116, 114, 105, 110, 103, 59, 120, 112, 116, 0, 19, 100, 111, 111, 114, 98, 101, 108, 108, 47, 99, 48, 49, 47, 36, 104, 111, 109, 105, 101] [1.4.199/0]
	at org.h2.mvstore.DataUtils.newIllegalArgumentException(DataUtils.java:857) ~[bundleFile:1.4.199]
	at org.h2.mvstore.type.ObjectDataType.deserialize(ObjectDataType.java:376) ~[bundleFile:1.4.199]
	at org.h2.mvstore.type.ObjectDataType$SerializedObjectType.read(ObjectDataType.java:1547) ~[bundleFile:1.4.199]
	at org.h2.mvstore.type.ObjectDataType.read(ObjectDataType.java:231) ~[bundleFile:1.4.199]
	at org.h2.mvstore.type.ObjectDataType.read(ObjectDataType.java:114) ~[bundleFile:1.4.199]
	at org.h2.mvstore.Page.read(Page.java:693) ~[bundleFile:1.4.199]
	at org.h2.mvstore.Page.read(Page.java:238) ~[bundleFile:1.4.199]
	at org.h2.mvstore.MVStore.readPage(MVStore.java:2187) ~[bundleFile:1.4.199]
	at org.h2.mvstore.MVMap.readPage(MVMap.java:554) ~[bundleFile:1.4.199]
	at org.h2.mvstore.Page$NonLeaf.getChildPage(Page.java:1086) ~[bundleFile:1.4.199]
	at org.h2.mvstore.MVMap.traverseDown(MVMap.java:1877) ~[bundleFile:1.4.199]
	at org.h2.mvstore.MVMap.operate(MVMap.java:1664) ~[bundleFile:1.4.199]
	at org.h2.mvstore.MVMap.put(MVMap.java:151) ~[bundleFile:1.4.199]
	at io.moquette.persistence.H2RetainedRepository.retain(H2RetainedRepository.java:34) ~[bundleFile:?]
	at io.moquette.broker.PostOffice.receivedPublishQos1(PostOffice.java:200) ~[bundleFile:?]
	at io.moquette.broker.MQTTConnection.processPublish(MQTTConnection.java:354) ~[bundleFile:?]
	at io.moquette.broker.MQTTConnection.handleMessage(MQTTConnection.java:77) ~[bundleFile:?]
	at io.moquette.broker.NewNettyMQTTHandler.channelRead(NewNettyMQTTHandler.java:58) [bundleFile:?]
	at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:374) [bundleFile:4.1.42.Final]
	at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:360) [bundleFile:4.1.42.Final]
	at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:352) [bundleFile:4.1.42.Final]
	at io.moquette.broker.metrics.MQTTMessageLogger.channelRead(MQTTMessageLogger.java:46) [bundleFile:?]
	at io.moquette.broker.metrics.MessageMetricsHandler.channelRead(MessageMetricsHandler.java:50) [bundleFile:?]
	at io.netty.handler.codec.ByteToMessageDecoder.fireChannelRead(ByteToMessageDecoder.java:328) [bundleFile:4.1.42.Final]
	at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:302) [bundleFile:4.1.42.Final]
	at io.moquette.broker.metrics.BytesMetricsHandler.channelRead(BytesMetricsHandler.java:51) [bundleFile:?]
	at io.netty.handler.timeout.IdleStateHandler.channelRead(IdleStateHandler.java:287) [bundleFile:4.1.42.Final]
	at io.netty.channel.DefaultChannelPipeline$HeadContext.channelRead(DefaultChannelPipeline.java:1422) [bundleFile:4.1.42.Final]
	at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:931) [bundleFile:4.1.42.Final]
	at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:163) [bundleFile:4.1.42.Final]
	at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:700) [bundleFile:4.1.42.Final]
	at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:635) [bundleFile:4.1.42.Final]
	at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:552) [bundleFile:4.1.42.Final]
	at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:514) [bundleFile:4.1.42.Final]
	at io.netty.util.concurrent.SingleThreadEventExecutor$6.run(SingleThreadEventExecutor.java:1044) [bundleFile:4.1.42.Final]
	at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74) [bundleFile:4.1.42.Final]
	at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30) [bundleFile:4.1.42.Final]
	at java.lang.Thread.run(Thread.java:748) [?:1.8.0_152]
Caused by: java.lang.ClassNotFoundException: io.moquette.broker.subscriptions.Topic cannot be found by com.h2database.mvstore_1.4.199
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:484) ~[org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395) ~[org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387) ~[org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150) ~[org.eclipse.osgi-3.12.100.jar:?]
	at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:1.8.0_152]
	at java.lang.Class.forName0(Native Method) ~[?:1.8.0_152]
	at java.lang.Class.forName(Class.java:348) ~[?:1.8.0_152]
	at java.io.ObjectInputStream.resolveClass(ObjectInputStream.java:683) ~[?:1.8.0_152]
	at java.io.ObjectInputStream.readNonProxyDesc(ObjectInputStream.java:1863) ~[?:1.8.0_152]
	at java.io.ObjectInputStream.readClassDesc(ObjectInputStream.java:1746) ~[?:1.8.0_152]
	at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:2037) ~[?:1.8.0_152]
	at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1568) ~[?:1.8.0_152]
	at java.io.ObjectInputStream.readObject(ObjectInputStream.java:428) ~[?:1.8.0_152]
	at org.h2.mvstore.type.ObjectDataType.deserialize(ObjectDataType.java:374) ~[bundleFile:1.4.199]
	... 53 more
19:46:13.624 [ERROR] [o.moquette.broker.NewNettyMQTTHandler] - Unexpected exception while processing MQTT message. Closing Netty channel. CId=doorbell-c01
java.nio.channels.ClosedChannelException: null
	at io.netty.channel.AbstractChannel$AbstractUnsafe.close(AbstractChannel.java:607) [bundleFile:4.1.42.Final]
	at io.netty.channel.DefaultChannelPipeline$HeadContext.close(DefaultChannelPipeline.java:1364) [bundleFile:4.1.42.Final]
	at io.netty.channel.AbstractChannelHandlerContext.invokeClose(AbstractChannelHandlerContext.java:621) [bundleFile:4.1.42.Final]
	at io.netty.channel.AbstractChannelHandlerContext.close(AbstractChannelHandlerContext.java:605) [bundleFile:4.1.42.Final]
	at io.netty.channel.ChannelDuplexHandler.close(ChannelDuplexHandler.java:79) [bundleFile:4.1.42.Final]
	at io.moquette.broker.metrics.BytesMetricsHandler.close(BytesMetricsHandler.java:66) [bundleFile:?]
	at io.moquette.broker.metrics.MessageMetricsHandler.close(MessageMetricsHandler.java:65) [bundleFile:?]
	at io.netty.channel.AbstractChannelHandlerContext.close(AbstractChannelHandlerContext.java:467) [bundleFile:4.1.42.Final]
	at io.netty.channel.DefaultChannelPipeline.close(DefaultChannelPipeline.java:969) [bundleFile:4.1.42.Final]
	at io.netty.channel.AbstractChannel.close(AbstractChannel.java:231) [bundleFile:4.1.42.Final]
	at io.moquette.broker.NewNettyMQTTHandler.channelRead(NewNettyMQTTHandler.java:62) [bundleFile:?]
The embedded broker has been abandoned and is not recommended/ Many people use Mosquitto.
do i have to change my hole code if i change to Mosquitto?
do you have a installation guide, because i don’t use openHABian on my RPI3b+.
How did you install openHAB? If you just used the packages it is easy to move to openHABian by just following the Linux install instructions.
I do not use MQTT so I have not researched installing Mosquitto but I know there is a menu option in openhabian-config.
is it possible to install openHABian without deinstalling openhab and edit all settings?
Yes, that is the method I tend to use.
# install git
sudo apt-get update
sudo apt-get install git
# download and link
sudo git clone https://github.com/openhab/openhabian.git /opt/openhabian
sudo ln -s /opt/openhabian/openhabian-setup.sh /usr/local/bin/openhabian-config
# execute
sudo openhabian-config
from openHABian | openHAB
i installed openhabian.
now if i try to install Mosquitto i got this message:
Do you really want to install a separate MQTT broker? β”‚
β”‚ Note that openHAB version 2.5M1 or higher comes with a new OHv2 MQTT β”‚
β”‚ binding that if you choose to enable it by default will use thus occupy β”‚
β”‚ the same ports as mosquitto here would try to use.
where is the statement of openhab that embedded MQTT Broker is no longer supported?
@rlkoshak mentioned it here. Perhaps he can cite his source.
You need to use PaperUI and uninstall the embedded broker and you shouldn’t need to edit all your settings.
thank you.
after installing Mosquitto via openhabian config i installed MQTT Binding via PaperUI.
after this my broker isn’t online and i got this error:
14:31:23.975 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'mqtt:broker:pibroker' changed from OFFLINE to OFFLINE (COMMUNICATION_ERROR): Timeout
14:31:23.982 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'mqtt:broker:pibroker' changed from OFFLINE (COMMUNICATION_ERROR): Timeout to OFFLINE (COMMUNICATION_ERROR): CONNECT failed as CONNACK contained an Error Code: NOT_AUTHORIZED.
14:31:24.029 [ERROR] [org.openhab.binding.mqtt             ] - bundle org.openhab.binding.mqtt:2.5.3 (260)[org.openhab.binding.mqtt.internal.discovery.MqttServiceDiscoveryService(257)] : The activate method has thrown an exception
java.lang.IllegalArgumentException: ID segment '127.0.0.1' contains invalid characters. Each segment of the ID must match the pattern [A-Za-z0-9_-]*.
	at org.eclipse.smarthome.core.common.AbstractUID.validateSegment(AbstractUID.java:97) ~[?:?]
	at org.eclipse.smarthome.core.common.AbstractUID.<init>(AbstractUID.java:75) ~[?:?]
	at org.eclipse.smarthome.core.common.AbstractUID.<init>(AbstractUID.java:58) ~[?:?]
	at org.eclipse.smarthome.core.thing.UID.<init>(UID.java:57) ~[?:?]
	at org.eclipse.smarthome.core.thing.ThingUID.<init>(ThingUID.java:43) ~[?:?]
	at org.openhab.binding.mqtt.internal.discovery.MqttServiceDiscoveryService.brokerAdded(MqttServiceDiscoveryService.java:105) ~[?:?]
	at org.openhab.binding.mqtt.internal.discovery.MqttServiceDiscoveryService.lambda$1(MqttServiceDiscoveryService.java:85) ~[?:?]
	at java.util.concurrent.ConcurrentHashMap.forEach(ConcurrentHashMap.java:1597) ~[?:1.8.0_152]
	at java.util.Collections$UnmodifiableMap.forEach(Collections.java:1505) ~[?:1.8.0_152]
	at org.openhab.binding.mqtt.internal.discovery.MqttServiceDiscoveryService.startBackgroundDiscovery(MqttServiceDiscoveryService.java:85) ~[?:?]
	at org.eclipse.smarthome.config.discovery.AbstractDiscoveryService.activate(AbstractDiscoveryService.java:384) ~[?:?]
	at org.openhab.binding.mqtt.internal.discovery.MqttServiceDiscoveryService.activate(MqttServiceDiscoveryService.java:54) ~[?:?]
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_152]
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_152]
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_152]
	at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_152]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) ~[bundleFile:?]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) ~[bundleFile:?]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) ~[bundleFile:?]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) [bundleFile:?]
	at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:317) [bundleFile:?]
	at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:307) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:340) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:114) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:982) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:955) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:900) [bundleFile:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [org.eclipse.osgi-3.12.100.jar:?]
	at java.security.AccessController.doPrivileged(Native Method) [?:1.8.0_152]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) [org.eclipse.osgi-3.12.100.jar:?]
	at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [bundleFile:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [osgi.core-6.0.0.jar:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [osgi.core-6.0.0.jar:?]
	at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [osgi.core-6.0.0.jar:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [osgi.core-6.0.0.jar:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [osgi.core-6.0.0.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) [org.eclipse.osgi-3.12.100.jar:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:906) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:892) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:959) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:732) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1045) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:999) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) [bundleFile:?]
	at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:666) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:432) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) [bundleFile:?]
	at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:338) [bundleFile:?]
	at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:382) [bundleFile:?]
	at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) [bundleFile:?]
	at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:264) [bundleFile:?]
	at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [bundleFile:?]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [bundleFile:?]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [bundleFile:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [osgi.core-6.0.0.jar:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [osgi.core-6.0.0.jar:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [osgi.core-6.0.0.jar:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [osgi.core-6.0.0.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.container.Module.start(Module.java:467) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [org.eclipse.osgi-3.12.100.jar:?]
14:31:24.114 [ERROR] [org.openhab.binding.mqtt             ] - bundle org.openhab.binding.mqtt:2.5.3 (260)[org.openhab.binding.mqtt.internal.discovery.MqttServiceDiscoveryService(257)] : The activate method has thrown an exception
	at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:86) [bundleFile:?]
	at org.apache.felix.scr.impl.inject.BindParameters.getServiceObject(BindParameters.java:47) [bundleFile:?]
	at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:664) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2308) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1805) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1788) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:435) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:325) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:294) [bundleFile:?]
14:31:24.200 [ERROR] [org.openhab.binding.mqtt             ] - bundle org.openhab.binding.mqtt:2.5.3 (260)[org.openhab.binding.mqtt.internal.discovery.MqttServiceDiscoveryService(257)] : The activate method has thrown an exception
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:756) [bundleFile:?]
Stop OH, clean the cache, and restart 2 times.
sudo systemctl stop openhab2
sudo openhab-cli clean-cache
sudo systemctl start openhab2
then after OH has fully started do a restart.
sudo systemctl restart openhab2
If that does not work then open the openhabian-config tool and select option 10 Apply Improvements then options 11, 13, and 14. Second thought you may want to do this prior to cleaning the cache and restarting.
i tried both of your solution but now i got this information:
15:00:38.242 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '127.0.0.1' with clientid a740bb6b-f0a0-4da5-883f-b8f189ba36ad
15:00:38.920 [INFO ] [t.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '127.0.0.1'. Next attempt in 60000ms
15:00:38.933 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'mqtt:broker:pibroker' changed from OFFLINE (COMMUNICATION_ERROR): CONNECT failed as CONNACK contained an Error Code: NOT_AUTHORIZED. to OFFLINE
Change the IP address from 127.0.0.1 to whatever your server IP address is. Also add the port 1883 e.g. 10.0.0.14:1883
after i try to change the IP address to my RPI3b+ address.
same problem as before :frowning:
15:06:29.696 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.22' with clientid b364fb70-2114-41c6-b180-3d1be93a46f6
15:06:29.739 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'mqtt:broker:pibroker' changed from OFFLINE to OFFLINE (COMMUNICATION_ERROR): CONNECT failed as CONNACK contained an Error Code: NOT_AUTHORIZED.
Use the openhabian-config tool and run fix permissions option.
If that fails then add the mqtt bridge via files or if you see a place in PaperUI to set secure to false then try that.
Things file example:
Bridge mqtt:broker:pibroker "pibroker" [ host="10.0.1.14", port=1883, secure=false, username="myusername", password="xxxxxxxx" ]
EDIT: I just noticed your on OH version 2.5.3 and there may be an issue with mqtt??? You can downgrade to version 2.5.1 and try it.
Here are the steps per the doc’s to upgrade/downgrade:
Upgrading is as easy as:
sudo apt-get update
sudo apt-get upgrade
You may want to switch to a different repo, or an older (but more stable) version of openHAB. To do this, simply select the repo as in the installation instructions above, then find the version by bringing a list of all versions available to install:
sudo apt-get update
apt-cache showpkg openhab2
Once you know which version you want, you can upgrade/downgrade to it by using the apt-get install openhab2=[version] command, for example:
sudo apt-get install openhab2=2.1.0-1
thank you for your hints.
i downgrade to OH 2.5.2 with the same problem :frowning:
6:11:47.253 [INFO ] [t.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '127.0.0.1'. Next attempt in 60000ms
16:11:47.262 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '127.0.0.1' with clientid 0a192fed-c29a-471e-a16f-5028f1aa0621
16:11:57.103 [INFO ] [t.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.1.22'. Next attempt in 60000ms
16:11:57.112 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'mqtt:broker:pibroker' changed from OFFLINE (COMMUNICATION_ERROR): CONNECT failed as CONNACK contained an Error Code: NOT_AUTHORIZED. to OFFLINE
Looks like OH is trying to connect to 2 brokers??
If your using a things file for the mqtt bridge then make sure you have removed any other bridge created in PaperUI. You also may have duplicates that need to be removed from /var/lib/openhab2/jsondb/org.eclipse.smarthome.core.thing.link.ItemChannelLink.json for links and items are: /var/lib/openhab2/jsondb/org.eclipse.smarthome.core.items.Item.json
If you need to make a change to these files make sure to stop OH first.
One other thing:
Got to the Karaf Console:
openhab-cli console
then type in:
 bundle:list -s | grep -i mqtt
and post the output.
did you do this?
yes
i delete this two files but with a kind of same problem:
17:04:14.488 [INFO ] [t.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.1.22'. Next attempt in 60000ms
17:04:14.506 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'mqtt:broker:pibroker' changed from OFFLINE (COMMUNICATION_ERROR): CONNECT failed as CONNACK contained an Error Code: NOT_AUTHORIZED. to OFFLINE
Here are my activated files:
204 β”‚ Active β”‚  80 β”‚ 1.1.2                   β”‚ com.hivemq.client.mqtt
239 β”‚ Active β”‚  80 β”‚ 2.5.3                   β”‚ org.openhab.binding.mqtt
240 β”‚ Active β”‚  81 β”‚ 2.5.3                   β”‚ org.openhab.binding.mqtt.generic
241 β”‚ Active β”‚  82 β”‚ 2.5.3                   β”‚ org.openhab.binding.mqtt.homeassistant
242 β”‚ Active β”‚  82 β”‚ 2.5.3                   β”‚ org.openhab.binding.mqtt.homie
249 β”‚ Active β”‚  80 β”‚ 2.5.0                   β”‚ org.openhab.core.io.transport.mqtt
do i also have to create a mqtt.cfg??
