MQTT persistence worked in 2.0.0 snapshot but not 2.1.0 release
Hi I haven’t updated in a long time, but I was running one of the 2.0.0 snapshot builds. Since then I have upgraded to 2.1.0 release (not nightly) and my states have stopped publishing to mqtt. Here is my config:
/opt/openhab/conf/services/
$cat mqtt.cfg
# Define your MQTT broker connections here for use in the MQTT Binding or MQTT
# Persistence bundles. Replace <broker> with an ID you choose.
# URL to the MQTT broker, e.g. tcp://localhost:1883 or ssl://localhost:8883
#<broker>.url=tcp://<host>:1883
mqb.url=tcp://localhost:1883
# Optional. Client id (max 23 chars) to use when connecting to the broker.
# If not provided a default one is generated.
mqb.clientId=openhab
# Optional. User id to authenticate with the broker.
#<broker>.user=<user>
# Optional. Password to authenticate with the broker.
#<broker>.pwd=<password>
# Optional. Set the quality of service level for sending messages to this broker.
# Possible values are 0 (Deliver at most once),1 (Deliver at least once) or 2
# (Deliver exactly once). Defaults to 0.
#<broker>.qos=<qos>
# Optional. True or false. Defines if the broker should retain the messages sent to
# it. Defaults to false.
#<broker>.retain=<retain>
# Optional. True or false. Defines if messages are published asynchronously or
# synchronously. Defaults to true.
#<broker>.async=<async>
# Optional. Defines the last will and testament that is sent when this client goes offline
# Format: topic:message:qos:retained <br/>
#<broker>.lwt=<last will definition>
$cat mqtt-persistence.cfg
# Name of the broker as defined in mqtt.cfg
broker=mqb
# The MQTT topic to which the persistence messages should be sent.
topic=ohab
# A string representing the persistence message content.
message=%1$s|%3$s
/opt/openhab/conf/persistence
$cat mqtt.persist
Strategies {
        default = everyChange
Items {
        // persist all items every hour and on every change
        * : strategy = everyChange
I am just trying to publish everything to that ohab topic.
Any help is greatly appreciated
Thanks,
Bri
I can switch back to the 2.0.0 snapshot and it works with those same files. Am I missing something I should configure in the 2.1.0 release? Any suggestions greatly appreciated. I just want to send mqtt messages on any state change. Is there some other way?
If you are interested to publish all item states from openHAB2 to the MQTT Broker, you could use the MQTT-EventBus solution:
  • Setup your broker connection with the $OPENHAB_CONF/services/mqtt.cfg
    ($OPENHAB_CONF = /opt/openhab/conf in your case)
  • Define within $OPENHAB_CONF/services/mqtt-eventbus.cfg your publishing settings
    (and optionally, your subscribing):
broker=mqb
statePublishTopic=openhab/out/${item}/state
commandPublishTopic=openhab/out/${item}/command
stateSubscribeTopic=openhab/in/${item}/state
commandSubscribeTopic=openhab/in/${item}/command
This will send the state of every $item to a separate topic. Keep in mind that this is a massive link. It will “connect” the entire Event Bus of openHAB2 to the Broker.
For persistence, I recommend using a 2-tier solution as @rlkoshak wrote here: Good Tutorial On Persistence (RRD4J and JDBC-MYSQL)? - #5 by rlkoshak.
  • mapdb for everyChange & restoreOnStartup (set as the default persistence service)
  • Influxdb for everyChange to be used with Grafana
  • Optionally, a 3rd tier with MySQL would be nice also but heavy :slight_smile:
MQTT persistence doesn’t really store historical data. It’s only used for publishing states of selected items to the broker.
It has the advantage of fine tuning the mqtt.persist to define a strategy of what to “persist” (put the items for which you want to publish the state in a group, then persist the group members)
Thank you so much @Dim ! I will try this after the holiday weekend. That looks like it would do exactly what I want. I currently use openhab as a zwave gateway/bridge so I don’t have really any other state changes other than the zwave stuff which I track all that.
Thanks Again
