Hi, i have the following problem. I am using openhab since 2017 on a raspberry, and I am using it principally to control 2 Philips Hue light, to toggle it via an Arduino board that I have made (it is only a simple botton). Now I want to transfer all openhab on my Synology nas. I have done all the installation of openhab properly, and the lights switch on/off via the sitemaps (so at least the Philips binding and the sitemaps button works), but I can’t figure how to make work the button. I have flashed the same program on it but only with the ip address modified with the one of the Synology. I see that it works, because I see the “TOOGLE” command via MQTT.fx, but the lights doesn’t react, and neither the button on the sitemaps. All the files, sitemaps, item, rules…have been copied from raspberry. I haven’t install all the package that I have on my raspberry, but at least the ones to make the button works…like MQTT bindings 1 and 2. I have also installed the Mosquitto from SynoCommunity…
Please, some help me. I can’t understand were a was making a mistake. Thanks.
I hope to have uploaded all needed information
Platform information:
Hardware: Synology DS218
OS: DSM 6.2.2
Java Runtime Environment: Java8 1.8.0_241
openHAB version: 2.5.2
Issue of the topic: please be detailed explaining your issue
Please post configurations (if applicable):
Items:
//This is the Items File
String pulsante {mqtt="<[broker:Tommy SmartHouse/utilities/pulsante:command:TOOGLE]"}
Switch Philips_Switch "Lampadario" <light> { channel="hue:0100:ecb5fa0097f5:4:brightness" }
Switch Philips_Switch "Lampadario" <light> { channel="hue:0100:ecb5fa0097f5:6:brightness" }
Sitemap:
sitemap home label="Tommy SmartHouse"
Frame label="Philips"
Switch item=Philips_Switch
Rules:
//This is the rules file
rule "update pulsante"
Item pulsante received command TOOGLE
if(Philips_Switch.state == ON) sendCommand(Philips_Switch, OFF)
else sendCommand(Philips_Switch, ON)
openhab.log:
2020-03-31 16:53:15.291 [WARN ] [cTransformationWhitelistWatchService] - Cannot read whitelist file, exec transformations won't be processed: /volume1/@appstore/openHAB/conf/misc/exec.whitelist
2020-03-31 16:53:33.846 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'home.items', using it anyway:
Duplicate ModelItem 'Philips_Switch'
2020-03-31 16:53:33.870 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.items'
2020-03-31 16:53:34.950 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
2020-03-31 16:53:36.706 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.sitemap'
2020-03-31 16:53:37.308 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.things'
2020-03-31 16:53:46.950 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.rules'
2020-03-31 16:53:47.588 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2020-03-31 16:53:48.442 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'home.things' is either empty or cannot be parsed correctly!
2020-03-31 16:53:49.611 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.1.47:8080
2020-03-31 16:53:49.614 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.1.47:8443
2020-03-31 16:53:49.946 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2020-03-31 16:53:49.955 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2020-03-31 16:53:52.643 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2020-03-31 16:53:53.050 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2020-03-31 16:53:53.341 [INFO ] [openhab.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2020-03-31 23:06:03.363 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '43.79466342298849,11.150407094690491'.
2020-03-31 23:19:43.018 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'home.items', using it anyway:
2020-03-31 23:19:43.024 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.items'
2020-03-31 23:20:52.476 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'home.items', using it anyway:
2020-03-31 23:20:52.479 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.items'
2020-03-31 23:22:47.454 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.rules'
events.log:
2020-03-31 14:38:55.732 [thome.event.ExtensionEvent] - Extension 'package-expert' has been installed.
2020-03-31 14:40:06.732 [thome.event.ExtensionEvent] - Extension 'transformation-javascript' has been installed.
2020-03-31 14:40:06.751 [thome.event.ExtensionEvent] - Extension 'transformation-regex' has been installed.
2020-03-31 14:40:06.754 [thome.event.ExtensionEvent] - Extension 'ui-habpanel' has been installed.
2020-03-31 14:40:06.755 [thome.event.ExtensionEvent] - Extension 'transformation-jsonpath' has been installed.
2020-03-31 14:40:06.757 [thome.event.ExtensionEvent] - Extension 'transformation-xpath' has been installed.
2020-03-31 14:40:06.759 [thome.event.ExtensionEvent] - Extension 'ui-restdocs' has been installed.
2020-03-31 14:40:06.761 [thome.event.ExtensionEvent] - Extension 'transformation-map' has been installed.
2020-03-31 14:40:06.763 [thome.event.ExtensionEvent] - Extension 'ui-basic' has been installed.
2020-03-31 14:40:06.765 [thome.event.ExtensionEvent] - Extension 'ui-classic' has been installed.
2020-03-31 14:40:06.767 [thome.event.ExtensionEvent] - Extension 'ui-habmin' has been installed.
2020-03-31 14:40:06.770 [thome.event.ExtensionEvent] - Extension 'transformation-xslt' has been installed.
2020-03-31 14:40:06.772 [thome.event.ExtensionEvent] - Extension 'transformation-exec' has been installed.
2020-03-31 14:40:06.774 [thome.event.ExtensionEvent] - Extension 'ui-paper' has been installed.
2020-03-31 14:40:06.776 [thome.event.ExtensionEvent] - Extension 'transformation-scale' has been installed.
2020-03-31 15:53:51.160 [.ItemChannelLinkAddedEvent] - Link 'Philips_Switch-hue:0100:ecb5fa0097f5:4:brightness' has been added.
2020-03-31 15:53:51.162 [.ItemChannelLinkAddedEvent] - Link 'Philips_Switch-hue:0100:ecb5fa0097f5:6:brightness' has been added.
2020-03-31 15:55:20.683 [ome.event.ItemCommandEvent] - Item 'Philips_Switch' received command ON
2020-03-31 15:55:20.704 [nt.ItemStatePredictedEvent] - Philips_Switch predicted to become NULL
2020-03-31 15:55:21.830 [ome.event.ItemCommandEvent] - Item 'Philips_Switch' received command OFF
2020-03-31 15:55:21.835 [nt.ItemStatePredictedEvent] - Philips_Switch predicted to become NULL
2020-03-31 16:02:44.285 [ome.event.ItemCommandEvent] - Item 'Philips_Switch' received command ON
2020-03-31 16:02:44.292 [nt.ItemStatePredictedEvent] - Philips_Switch predicted to become NULL
2020-03-31 16:02:45.047 [ome.event.ItemCommandEvent] - Item 'Philips_Switch' received command OFF
2020-03-31 16:02:45.054 [nt.ItemStatePredictedEvent] - Philips_Switch predicted to become NULL
2020-03-31 16:05:21.273 [home.event.InboxAddedEvent] - Discovery Result with UID 'hue:bridge:ecb5fa0097f5' has been added.
2020-03-31 16:05:21.746 [thome.event.ExtensionEvent] - Extension 'binding-hue' has been installed.
2020-03-31 16:08:43.344 [me.event.InboxRemovedEvent] - Discovery Result with UID 'hue:bridge:ecb5fa0097f5' has been removed.
2020-03-31 16:08:43.395 [hingStatusInfoChangedEvent] - 'hue:bridge:ecb5fa0097f5' changed from UNINITIALIZED to INITIALIZING
2020-03-31 16:08:43.559 [hingStatusInfoChangedEvent] - 'hue:bridge:ecb5fa0097f5' changed from INITIALIZING to OFFLINE (CONFIGURATION_ERROR): Not authenticated. Press pairing button on the Hue bridge or set a valid user name in configuration.
2020-03-31 16:08:53.617 [me.event.ThingUpdatedEvent] - Thing 'hue:bridge:ecb5fa0097f5' has been updated.
2020-03-31 16:08:53.630 [vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[]]
2020-03-31 16:08:54.218 [me.event.ThingUpdatedEvent] - Thing 'hue:bridge:ecb5fa0097f5' has been updated.
2020-03-31 16:08:54.223 [hingStatusInfoChangedEvent] - 'hue:bridge:ecb5fa0097f5' changed from OFFLINE (CONFIGURATION_ERROR): Not authenticated. Press pairing button on the Hue bridge or set a valid user name in configuration. to ONLINE
2020-03-31 16:08:54.244 [home.event.InboxAddedEvent] - Discovery Result with UID 'hue:0850:ecb5fa0097f5:5' has been added.
2020-03-31 16:08:54.250 [home.event.InboxAddedEvent] - Discovery Result with UID 'hue:0820:ecb5fa0097f5:7' has been added.
2020-03-31 16:08:54.260 [home.event.InboxAddedEvent] - Discovery Result with UID 'hue:0840:ecb5fa0097f5:8' has been added.
2020-03-31 16:08:54.564 [home.event.InboxAddedEvent] - Discovery Result with UID 'hue:0100:ecb5fa0097f5:4' has been added.
2020-03-31 16:08:54.569 [home.event.InboxAddedEvent] - Discovery Result with UID 'hue:0100:ecb5fa0097f5:6' has been added.
2020-03-31 16:08:54.576 [home.event.InboxAddedEvent] - Discovery Result with UID 'hue:0210:ecb5fa0097f5:7' has been added.
2020-03-31 16:09:33.470 [me.event.InboxRemovedEvent] - Discovery Result with UID 'hue:0100:ecb5fa0097f5:4' has been removed.
2020-03-31 16:09:33.502 [hingStatusInfoChangedEvent] - 'hue:0100:ecb5fa0097f5:4' changed from UNINITIALIZED to INITIALIZING
2020-03-31 16:09:33.534 [me.event.ThingUpdatedEvent] - Thing 'hue:0100:ecb5fa0097f5:4' has been updated.
2020-03-31 16:09:33.536 [hingStatusInfoChangedEvent] - 'hue:0100:ecb5fa0097f5:4' changed from INITIALIZING to ONLINE
2020-03-31 16:09:33.577 [vent.ItemStateChangedEvent] - Philips_Switch changed from NULL to OFF
2020-03-31 16:09:44.618 [me.event.InboxRemovedEvent] - Discovery Result with UID 'hue:0100:ecb5fa0097f5:6' has been removed.
2020-03-31 16:09:44.633 [hingStatusInfoChangedEvent] - 'hue:0100:ecb5fa0097f5:6' changed from UNINITIALIZED to INITIALIZING
2020-03-31 16:09:44.666 [me.event.ThingUpdatedEvent] - Thing 'hue:0100:ecb5fa0097f5:6' has been updated.
2020-03-31 16:09:44.668 [hingStatusInfoChangedEvent] - 'hue:0100:ecb5fa0097f5:6' changed from INITIALIZING to ONLINE
2020-03-31 16:10:28.685 [ome.event.ItemCommandEvent] - Item 'Philips_Switch' received command ON
2020-03-31 16:10:28.706 [nt.ItemStatePredictedEvent] - Philips_Switch predicted to become ON
2020-03-31 16:10:28.747 [vent.ItemStateChangedEvent] - Philips_Switch changed from OFF to ON
2020-03-31 16:10:30.439 [ome.event.ItemCommandEvent] - Item 'Philips_Switch' received command OFF
2020-03-31 16:10:30.460 [nt.ItemStatePredictedEvent] - Philips_Switch predicted to become OFF
2020-03-31 16:10:30.486 [vent.ItemStateChangedEvent] - Philips_Switch changed from ON to OFF
2020-03-31 16:11:18.261 [thome.event.ExtensionEvent] - Extension 'binding-mqtt' has been installed.
2020-03-31 16:11:44.268 [thome.event.ExtensionEvent] - Extension 'binding-mqtt1' has been installed.
2020-03-31 16:52:42.797 [hingStatusInfoChangedEvent] - 'hue:0100:ecb5fa0097f5:6' changed from ONLINE to UNINITIALIZED
2020-03-31 16:52:42.827 [hingStatusInfoChangedEvent] - 'hue:0100:ecb5fa0097f5:6' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-31 16:52:42.828 [hingStatusInfoChangedEvent] - 'hue:0100:ecb5fa0097f5:4' changed from ONLINE to UNINITIALIZED
2020-03-31 16:52:42.849 [hingStatusInfoChangedEvent] - 'hue:0100:ecb5fa0097f5:4' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-31 16:52:42.851 [hingStatusInfoChangedEvent] - 'hue:bridge:ecb5fa0097f5' changed from ONLINE to UNINITIALIZED
2020-03-31 16:52:42.873 [hingStatusInfoChangedEvent] - 'hue:bridge:ecb5fa0097f5' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-31 16:52:43.066 [temChannelLinkRemovedEvent] - Link 'Philips_Switch => hue:0100:ecb5fa0097f5:6:brightness' has been removed.
2020-03-31 16:52:43.067 [temChannelLinkRemovedEvent] - Link 'Philips_Switch => hue:0100:ecb5fa0097f5:4:brightness' has been removed.
2020-03-31 16:53:57.936 [hingStatusInfoChangedEvent] - 'hue:0100:ecb5fa0097f5:4' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-03-31 16:53:57.939 [hingStatusInfoChangedEvent] - 'hue:0100:ecb5fa0097f5:6' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-03-31 16:53:58.399 [hingStatusInfoChangedEvent] - 'hue:bridge:ecb5fa0097f5' changed from UNINITIALIZED to INITIALIZING
2020-03-31 16:53:59.849 [hingStatusInfoChangedEvent] - 'hue:bridge:ecb5fa0097f5' changed from INITIALIZING to ONLINE
2020-03-31 16:53:59.962 [hingStatusInfoChangedEvent] - 'hue:0100:ecb5fa0097f5:6' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-03-31 16:53:59.977 [hingStatusInfoChangedEvent] - 'hue:0100:ecb5fa0097f5:4' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-03-31 16:54:00.021 [hingStatusInfoChangedEvent] - 'hue:0100:ecb5fa0097f5:6' changed from INITIALIZING to ONLINE
2020-03-31 16:54:00.029 [hingStatusInfoChangedEvent] - 'hue:0100:ecb5fa0097f5:4' changed from INITIALIZING to ONLINE
2020-03-31 16:54:00.284 [vent.ItemStateChangedEvent] - Philips_Switch changed from NULL to OFF
2020-03-31 16:54:14.399 [ome.event.ItemCommandEvent] - Item 'Philips_Switch' received command ON
2020-03-31 16:54:14.432 [nt.ItemStatePredictedEvent] - Philips_Switch predicted to become ON
2020-03-31 16:54:14.456 [vent.ItemStateChangedEvent] - Philips_Switch changed from OFF to ON
2020-03-31 16:54:15.097 [ome.event.ItemCommandEvent] - Item 'Philips_Switch' received command OFF
2020-03-31 16:54:15.119 [nt.ItemStatePredictedEvent] - Philips_Switch predicted to become OFF
2020-03-31 16:54:15.149 [vent.ItemStateChangedEvent] - Philips_Switch changed from ON to OFF
2020-03-31 16:54:43.197 [ome.event.ItemCommandEvent] - Item 'Philips_Switch' received command ON
2020-03-31 16:54:43.226 [nt.ItemStatePredictedEvent] - Philips_Switch predicted to become ON
2020-03-31 16:54:43.256 [vent.ItemStateChangedEvent] - Philips_Switch changed from OFF to ON
2020-03-31 16:54:44.105 [ome.event.ItemCommandEvent] - Item 'Philips_Switch' received command OFF
2020-03-31 16:54:44.130 [nt.ItemStatePredictedEvent] - Philips_Switch predicted to become OFF
2020-03-31 16:54:44.151 [vent.ItemStateChangedEvent] - Philips_Switch changed from ON to OFF
2020-03-31 18:02:05.920 [vent.ItemStateChangedEvent] - Philips_Switch changed from OFF to ON
2020-03-31 19:10:58.539 [ome.event.ItemCommandEvent] - Item 'pulsante' received command TOGGLE
2020-03-31 19:10:58.551 [vent.ItemStateChangedEvent] - pulsante changed from NULL to TOGGLE
2020-03-31 19:11:00.099 [ome.event.ItemCommandEvent] - Item 'Philips_Switch' received command OFF
2020-03-31 19:11:00.138 [nt.ItemStatePredictedEvent] - Philips_Switch predicted to become OFF
2020-03-31 19:11:00.163 [vent.ItemStateChangedEvent] - Philips_Switch changed from ON to OFF
2020-03-31 19:57:59.880 [ome.event.ItemCommandEvent] - Item 'pulsante' received command TOGGLE
2020-03-31 19:57:59.890 [ome.event.ItemCommandEvent] - Item 'Philips_Switch' received command ON
2020-03-31 19:57:59.915 [nt.ItemStatePredictedEvent] - Philips_Switch predicted to become ON
2020-03-31 19:57:59.936 [vent.ItemStateChangedEvent] - Philips_Switch changed from OFF to ON
2020-03-31 20:34:06.456 [ome.event.ItemCommandEvent] - Item 'pulsante' received command TOGGLE
2020-03-31 20:34:06.466 [ome.event.ItemCommandEvent] - Item 'Philips_Switch' received command OFF
2020-03-31 20:34:06.493 [nt.ItemStatePredictedEvent] - Philips_Switch predicted to become OFF
2020-03-31 20:34:06.518 [vent.ItemStateChangedEvent] - Philips_Switch changed from ON to OFF
2020-03-31 21:25:44.482 [ome.event.ItemCommandEvent] - Item 'pulsante' received command TOGGLE
2020-03-31 21:25:44.495 [ome.event.ItemCommandEvent] - Item 'Philips_Switch' received command ON
2020-03-31 21:25:44.523 [nt.ItemStatePredictedEvent] - Philips_Switch predicted to become ON
2020-03-31 21:25:44.548 [vent.ItemStateChangedEvent] - Philips_Switch changed from OFF to ON
2020-03-31 22:57:36.255 [ome.event.ItemCommandEvent] - Item 'pulsante' received command TOGGLE
2020-03-31 22:57:36.265 [ome.event.ItemCommandEvent] - Item 'Philips_Switch' received command OFF
2020-03-31 22:57:36.293 [nt.ItemStatePredictedEvent] - Philips_Switch predicted to become OFF
2020-03-31 22:57:36.315 [vent.ItemStateChangedEvent] - Philips_Switch changed from ON to OFF
2020-03-31 22:57:38.468 [ome.event.ItemCommandEvent] - Item 'pulsante' received command TOGGLE
2020-03-31 22:57:38.478 [ome.event.ItemCommandEvent] - Item 'Philips_Switch' received command ON
2020-03-31 22:57:38.505 [nt.ItemStatePredictedEvent] - Philips_Switch predicted to become ON
2020-03-31 22:57:38.527 [vent.ItemStateChangedEvent] - Philips_Switch changed from OFF to ON
2020-03-31 23:26:23.289 [ome.event.ItemCommandEvent] - Item 'Philips_Switch' received command OFF
2020-03-31 23:26:23.333 [nt.ItemStatePredictedEvent] - Philips_Switch predicted to become OFF
2020-03-31 23:26:23.404 [vent.ItemStateChangedEvent] - Philips_Switch changed from ON to OFF
2020-03-31 23:26:24.432 [ome.event.ItemCommandEvent] - Item 'Philips_Switch' received command ON
2020-03-31 23:26:24.458 [nt.ItemStatePredictedEvent] - Philips_Switch predicted to become ON
2020-03-31 23:26:24.493 [vent.ItemStateChangedEvent] - Philips_Switch changed from OFF to ON
2020-03-31 23:26:31.716 [ome.event.ItemCommandEvent] - Item 'Philips_Switch' received command OFF
2020-03-31 23:26:31.743 [nt.ItemStatePredictedEvent] - Philips_Switch predicted to become OFF
2020-03-31 23:26:31.789 [vent.ItemStateChangedEvent] - Philips_Switch changed from ON to OFF
2020-03-31 23:26:32.710 [ome.event.ItemCommandEvent] - Item 'Philips_Switch' received command ON
2020-03-31 23:26:32.742 [nt.ItemStatePredictedEvent] - Philips_Switch predicted to become ON
2020-03-31 23:26:32.787 [vent.ItemStateChangedEvent] - Philips_Switch changed from OFF to ON
Arduino program:
#include <ESP8266WiFi.h>
#include <MQTTClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <ESP8266HTTPUpdateServer.h>
/* WIFI Settings */
// Name of wifi network
const char* ssid = "*******";
// Password to wifi network
const char* password = "*******";
/* Web Updater Settings */
// Host Name of Device
const char* host = "pulsante";
// Path to access firmware update page (Not Neccessary to change)
const char* update_path = "/firmware";
// Username to access the web update page
const char* update_username = "admin";
// Password to access the web update page
const char* update_password = "password";
/* MQTT Settings */
// Topic which listens for commands
char* subscribeTopic = "Tommy SmartHouse/utilities/pulsante";
//MQTT Server IP Address
const char* server = "192.168.1.47";
//Unique device ID
const char* mqttDeviceID = "Tommy_SmartHouseDevice1";
int pulsante;
int ultimo_stato;
ESP8266WebServer httpServer(80);
ESP8266HTTPUpdateServer httpUpdater;
WiFiClient net;
MQTTClient client;
unsigned long lastMillis = 0;
void connect();
void setup()
Serial.begin(19200);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
client.begin(server, net);
client.onMessage(messageReceived);
connect();
MDNS.begin(host);
httpUpdater.setup(&httpServer, update_path, update_username, update_password);
httpServer.begin();
MDNS.addService("http", "tcp", 80);
pinMode(pulsante, INPUT);
void connect()
while (WiFi.status() != WL_CONNECTED)
delay(1000);
while (!client.connect(mqttDeviceID))
delay(1000);
client.subscribe(subscribeTopic);
void loop()
client.loop();
delay(10);
if(!client.connected())
connect();
httpServer.handleClient();
pulsante=digitalRead(0);
if(pulsante==ultimo_stato){
else{
client.publish("Tommy SmartHouse/utilities/pulsante", "TOOGLE");
delay (100);
ultimo_stato=pulsante;
void messageReceived(String &topic, String &payload)
