I have confirmed that the message payload being delivered to the devices/4f0a116f/state topic is:
{"power":1}
And yet whenever the topic is updated, I see the following in openhab.log:
[WARN ] [ab.binding.mqtt.generic.ChannelState] - Command '1' not supported by type 'OnOffValue': No enum constant org.eclipse.smarthome.core.library.types.OnOffType.1
Iâm confused why this is happening â I explicitly added on=1, off=0 to the Thing configuration, so I would expect that it would âjust workâ.
Any ideas how this would work in conjunction with JSONPath? I need the JSONPath transformation in order to extract just the power field; other fields may be present and will not be static, so I canât hard-code them in a Map.
Sure. But one way is correct and ought to work, one way is not and will never work.
Youâre not the only one struggling with this feature, maybe it is broken in some versions - what version is involved here?
A caution when editing Things files, seems especially relevant for minor edits. Some bindings are better than others at managing in-flight thing changes.
Iâd restart the binding after edits, to pick up new settings.
Chaining transforms is described in the binding docs. Itâs a rather clever feature that only MQTT binding has, so far.
I think (from other similar posts) the word âcommandâ is a bit misleading in the bindingâs message, and should be interpreted more like âpayloadâ
If I think Iâve screwed up on the topic or payload type for mqtt, I run it through mqttfx where itâs easy to change both the topic and payload to see where Iâve gone wrong.
Yes. What Iâm saying is that the OPs error message is produced in response to processing an incoming topic, just as he as configured, and the word âcommandâ in the error message refers in this case to the incoming payload and is a misnomer in openHABs usual terms.
There is no openHAB command involved.
Have I got it right, @ssmall ?
My question is standing, does the device react at all when the openHAB switch is triggered?
In my understanding that warning is caused by a state message sent by the device, which COULD have been triggered by�
I have encountered same problem in a similar but very common configuration. Iâm using Sonoff RF Bridge to switch items. I try to define a read only channel that receives input from RF senders like Intertechno or cheap contact sensors for windows and doors.
I have configured the channel as proposed by @H102 with transformationPattern JSONPATH and MAP chained, but no working solution was found in this thread so far. Also Iâm struggling to implement the MAP transformation (MAP transformation 2.5.4 is installed). My channel is:
I also tried swapping JSONPATH and MAP transformation with the same result:
[WARN ] [t.generic.ChannelStateTransformation] - Transformation service MAP for pattern RfCodes.map not found!
[WARN ] [ab.binding.mqtt.generic.ChannelState] - Command 'F27322' not supported by type 'OnOffValue': No enum constant org.eclipse.smarthome.core.library.types.OnOffType.F27322
without having to define a separate Map or JS transformation for each channel. So @ssmall, you should try again with your first approach. Maybe there was a handling problem or a bug in the binding, when you tried it first.
However, the warning still shows, if a code is received which is not covered by the two switch states. This will clutter my log, when I will have all sensors configured for MQTT2. So I am still open for an even better solution.
My next step will be to find a way to have a momentary button to trigger ON and OFF states, but I did not find yet a way to use system channel types with MQTT binding.
[quote="rossko57, post:18, topic:91398]
Youâd be interested in REGEX with JSONPATH
[/quote]
I had been experimenting with REGEX before so I thought it would be easy to incorporate like in the appended post. But I struggled with the channel not updating if I only change strings. Now I have created a dummy channel for which I change the name each time I want to try out a new transformation string. That way, the thing is updated every time.
not sure if you mean channel trigger option?
[/quote]
I was in fact thinking about creating a channel with type system.rawbutton and [profile="rawbutton-toggle-switch"] because I wanted to avoid a rule. But after you gave me the hint, I think, it will be much easier to just create one rule, where all codes for the buttons are located and they can switch the items via sendCommand. That way I will avoid even to have items for the wall switches. But Iâm getting off topic.
My working configuration for the channel now looks this:
