Hello all
i’m begginner and struggling at initial configuration/setup problem.
In Paper UI i’ve found already present a System Broker:
MQTT Broker
System MQTT Broker
mqtt:systemBroker:embedded-mqtt-broker
After read documentation i’ve also found that OH2 has an embedded broker, so installed it.
Now i would like to remove the System Broker but after clicked on the button to remove it, i’m getting it always in ‘REMOVING’ status and also it show up in the logs…
2019-02-15 07:51:49.944 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to ‘98.87.89.1’. Next attempt in 10000ms
2019-02-15 07:51:49.956 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to ‘98.87.89.1’ with clientid paho1698040587602 and file store ‘/var/lib/openhab2/mqtt/98.87.89.1’
2019-02-15 07:51:59.959 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to ‘98.87.89.1’. Next attempt in 10000ms
2019-02-15 07:52:09.962 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to ‘98.87.89.1’. Next attempt in 10000ms
2019-02-15 07:52:19.965 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to ‘98.87.89.1’. Next attempt in 10000ms
2019-02-15 07:52:29.968 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to ‘98.87.89.1’. Next attempt in 10000ms
2019-02-15 07:52:39.971 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to ‘98.87.89.1’. Next attempt in 10000ms
2019-02-15 07:52:49.975 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to ‘98.87.89.1’. Next attempt in 10000ms
2019-02-15 07:52:59.979 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to ‘98.87.89.1’. Next attempt in 10000ms
2019-02-15 07:52:59.990 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to ‘98.87.89.1’ with clientid paho1698040587602 and file store ‘/var/lib/openhab2/mqtt/98.87.89.1’
Any idea?
Whats the differences between the two brokers?
TIA
H
