Hi all,
inspired by Custom Widget: Music Control I started to port such a widget to my classic ui interface:
Version 1.1:
- Initial support for album covers (only displayed if enough space is available)
- Initial work done to add multiplayer support
This currently requires habpanel to be installed; for some .css - but that could be removed. It’s an early prototype - I’ll updated the post if I enhance it. But it might be useful already:
sitemap:
Switch item=ItemPlayRandomTitles
Webview url="/static/Player/Player.html" height=5
Webview url="/static/Player/Player.html" height=2
Slider item=GroupRadioVolume
openHAB.js:
// * Required definitions:
// * - var baseURL = "../";
// * Required API
// * - Google jQuery: https://ajax.googleapis.com/ajax/libs/jquery/2.1.0/jquery.min.js
function _GetData(itemUrl) {
var itemValue = null;
$.ajax({
contentType: 'text/plain',
url: itemUrl,
data: {},
async: false,
success: function (data) {
if (data != "NULL") {
itemValue = data;
return itemValue;
// JSON to CSV Converter
function _ConvertToCSV(objArray) {
var array = typeof objArray != 'object' ? JSON.parse(objArray) : objArray;
var str = '';
for (var i = 0; i < array.data.length; i++) {
var line = '';
for (var index in array.data[i]) {
if (line != '') line += ','
line += array.data[i][index];
str += line + '\r\n';
return str;
function GetOpenHABItem(item) {
var itemUrl = baseURL.concat("rest/items/").concat(item).concat("/state/");
return _GetData(itemUrl)
function GetOpenHABItemIntValue(item) {
return Math.round(GetOpenHabItem(item));
function GetOpenHABItemHistoryJSON(item) {
var itemUrl = baseURL.concat("rest/persistence/items/").concat(item);
var jsonData = null;
jsonData = _GetData(itemUrl);
return jsonData;
function GetOpenItemHABHistoryCSV(item) {
var jsonData = GetOpenHABItemHistoryJSON(item);
return _ConvertToCSV(jsonData);
function GetParameter(parameterName) {
var result = null,
tmp = [];
location.search.substr(1).split("&")
.forEach(function (item) {
tmp = item.split("=");
if (tmp[0] === parameterName) {
result = decodeURIComponent(tmp[1]);
return result;
Player.html:
<html>
<head>
<!-- HABPanel Styles -->
<link rel="stylesheet" href="../../habpanel/vendor/vendor.min.css" />
<link rel="stylesheet" href="../../habpanel/assets/styles/themes/default/default.min.css" />
<!-- MusicControl Widget Styles -->
<style>
#main {
height: 100%;
width: 100%;
display: table;
#container {
display: table-cell;
height: 100%;
vertical-align: middle;
.btn-group {
top: -40px;
.btn-pad {
padding: 15px 40px;
opacity: 0.85;
.btn-radius {
padding: 5px 5px;
border-radius: 50% !important;
background-color: #d23f31;
height: 56px;
width: 56px;
box-shadow: 0 0 4px rgba(0, 0, 0, .14), 0 4px 8px rgba(0, 0, 0, .28);
box-sizing: content-box;
margin-left: -13px;
position: relative;
z-index: 1000;
cursor: pointer;
.btn-red {
background-color: red;
.button-main {
position: relative;
top: 10;
.glyphicon-text {
font-size: xx-large;
padding: 0px;
.btn-lf {
position: relative;
top: -10px;
left: 8px;
background-color: #fff;
color: #000;
border-top-left-radius: 10%;
border-bottom-left-radius: 10%;
cursor: pointer;
.btn-lf:hover {
background-color: #eaeaea;
color: #fff;
.btn-rt {
position: relative;
top: -10px;
right: 8px;
margin-left: -13px;
color: #000;
border-top-right-radius: 10%;
border-bottom-right-radius: 10%;
cursor: pointer;
.btn-rt:hover {
color: #fff;
.btn-info {
vertical-align: bottom;
.btn-warning {
.name-text {
text-align: center;
display: block;
.title-text {
font-size: x-large;
text-align: center;
display: block;
.div-slider {
width: 220px;
margin: 0 auto;
html,
body,
label {
color: #fff;
text-align: center;
background: inherit;
img {
height: 150px;
width: 150;
position: relative;
z-index: 0;
display: block;
top: 40;
left: 40;
</style>
<script type="text/javascript">
var baseURL = "../../";
var squeezeBoxURL = "http://HAUS:9000/status.html";
</script>
<script type="text/javascript" src="https://ajax.googleapis.com/ajax/libs/jquery/2.1.0/jquery.min.js"></script>
<script type="text/javascript" src="../javascript/openHAB.js"></script>
<!--Buttons:
"brightness_down", "brightness_toggle", "brightness_up", "done", "down", "fire", "jump_fwd", "jump_rew", "left", "left_repeat",
"menu_browse_album", "menu_browse_artist", "menu_browse_genre", "menu_browse_music", "menu_browse_playlists", "menu_plugins",
"menu_home", "menu_now_playing", "menu_playlist", "menu_pop", "menu_search_album", "menu_search_artist",
"menu_search_song", "menu_settings", "muting", "numberScroll_0", "numberScroll_1", "numberScroll_2",
"numberScroll_3", "numberScroll_4", "numberScroll_5", "numberScroll_6", "numberScroll_7", "numberScroll_8",
"numberScroll_9", "pause", "play", "play_0", "play_1", "playdisp_0", "playdisp_1", "playdisp_2",
"playdisp_3", "playdisp_4", "playdisp_5", "playdisp_toggle", "power_off", "power_on", "power_toggle",
"repeat_0", "repeat_1", "repeat_2", "repeat_toggle", "right", "right", "scan_end", "scan_fwd",
"scan_rew", "search", "shuffle_off", "shuffle_on", "shuffle_toggle", "sleep", "slimtrisButtonHandler_add",
"slimtrisButtonHandler_down", "slimtrisButtonHandler_left", "slimtrisButtonHandler_play", "slimtrisButtonHandler_right",
"slimtrisButtonHandler_up", "stop", "textsize_large", "textsize_small", "textsize_medium" (on displays that support it),
"textsize_toggle", "titleFormat", "up", "volume_down", & "volume_up".
var imageSrc = "http://192.168.0.73:9000/music/current/cover.jpg";
// ?player=" + GetOpenHABItem("ItemAudioCurrentPlayerId");
var showCover = false;
$(document).ready(function () {
document.getElementById("play").style.display = "none";
var pageHeight = window.innerHeight;
var pageWidth = window.innerWidth;
var pageElement = document.getElementById("main");
// only show cover if there is enough space ...
if (pageHeight < 180) {
showCover = false;
document.getElementById("cover").style.display = "none";
document.getElementById("widget").style.top = "0px";
} else {
showCover = true;
pageElement.style.height = pageHeight + "px";
pageElement.style.width = pageWidth + "px";
pageElement = document.getElementById("container");
document.body.style.height = pageHeight + "px";
document.body.style.width = pageWidth + "px";
setInterval(function () {
updateCover();
}, 5000);
* Update cover image ...
function updateCover() {
var _date = new Date();
var _element = document.getElementById("cover");
// Add cache breaker to image URL; temporary hack until we know how
// to get the full cover URL without the proxy URL.
_element.src = imageSrc + "?update=" + _date.getTime();
* Return the player id; if you only control a single player you
* may hardcode the MAC address. If more than one player is used we load
* the current active MAC from OH.
function getPlayerId() {
return GetOpenHABItem("ItemAudioCurrentPlayerId");
function next() {
$.get(squeezeBoxURL + "?p0=button&p1=jump_fwd&player=" + getPlayerId());
function prev() {
$.get(squeezeBoxURL + "?p0=playlist&p1=index&p2=jump_rew&player=" + getPlayerId());
function pause() {
document.getElementById("play").style.display = "inherit";
document.getElementById("pause").style.display = "none";
$.get(squeezeBoxURL + "?p0=play&player=" + getPlayerId());
function play() {
document.getElementById("pause").style.display = "inherit";
$.get(squeezeBoxURL + "?p0=pause&player=" + getPlayerId());
</script>
</head>
<body>
<div id="main">
<div id="container">
<label class="name-text" >{{config.my_name}}</label>
<label class="title-text">{{itemValue(config.inputsource_item)}}</label>
<label class="title-text">{{itemValue(config.song_title)}}</label>
<label class="name-text" >{{itemValue(config.song_artist)}} {{itemValue(config.song_album)}}</label>
<div id="widget" class="btn-group">
<img id="cover"></img>
<label class="btn-pad btn-lf" onclick="prev()">
<i class="glyphicon glyphicon-step-backward"></i>
</label>
<label id="play" class="btn-radius btn-info" onclick="play()">
<i class="glyphicon glyphicon-play glyphicon-text button-main"></i>
</label>
<label id="pause" class="btn-radius btn-warning" onclick="pause()">
<i class="glyphicon glyphicon-pause glyphicon-text button-main" ></i>
</label>
<label class="btn-pad btn-rt" onclick="next()">
<i class="glyphicon glyphicon-step-forward"></i>
</label>
</div>
<label class="name-text">({{itemValue(config.song_playingtime)}})</label>
</div>
</div>
</body>
</html>
with kind regards,
Patrik
