since a couple of days my connection to the openhab cloud is cut. Restarting the system helps only for a few minutes. Then the connection is lost again. I already tried to uninstall and reinstall the related binding. Does anyone knows this issue and knows what to do?
Many thanks in advance
edit: I performed a fritzbox update a couple of days before. Could this be the issue?
openHAB cloud is creating a new SSE sitemap subscription every few seconds, and it will reach the max subscription limit of 50 pretty quickly. You can increase the subscription max by setting a configuration parameter, but it will still reach max subscriptions eventually.
Edit: FYI, you can “fix” the problem temporarily by restarting the org.openhab.core.io.rest.sitemap bundle in the Karaf console.
