I have set the loglevel for the cloudconnector to debug, but still do not see an error. In myopenhab ith says still offline..
16:37:51.594 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
17:11:08.778 [DEBUG] [org.openhab.io.openhabcloud ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.core.events.EventSubscriber, org.eclipse.smarthome.model.script.engine.action.ActionService}={component.name=org.openhab.openhabcloud, expose=[gAll, EG_Aussenbeleuchtung, EG_EZ_Esstisch, EG_EZ_Wand, EG_Fenster, EG_Flur_Strahler, EG_KU_Arbeitsplatte, EG_KU_LED, EG_KU_LEDSpot, EG_Treppe_Strahler, EG_WZ_Sofa_Links, EG_KU_Strahler, EG_KU_Saeule_Steckdosen, EG_WZ_Haupt, EG_WZ_Led, EG_WZ_Sofa_Rechts, EG_WZ_Strahler, gEG_Lights, Sunset_Event, All, gEG_ambient, gEG_Powerplug, gEG_Main, gEG_Spots, gEG_XMAS, gXMAS], baseURL=https://myopenhab.org/, service.config.category=io, service.config.description.uri=io:openhabcloud, mode=remote, service.pid=org.openhab.openhabcloud, service.config.label=openHAB Cloud, component.id=217, service.id=348, service.bundleid=217, service.scope=bundle} - org.openhab.io.openhabcloud
17:11:08.894 [DEBUG] [o.openhabcloud.internal.CloudService] - openHAB Cloud connector deactivated
17:11:08.922 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
17:11:09.027 [DEBUG] [org.openhab.io.openhabcloud ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.events.EventSubscriber, org.eclipse.smarthome.model.script.engine.action.ActionService}={component.name=org.openhab.openhabcloud, expose=[gAll, EG_Aussenbeleuchtung, EG_EZ_Esstisch, EG_EZ_Wand, EG_Fenster, EG_Flur_Strahler, EG_KU_Arbeitsplatte, EG_KU_LED, EG_KU_LEDSpot, EG_Treppe_Strahler, EG_WZ_Sofa_Links, EG_KU_Strahler, EG_KU_Saeule_Steckdosen, EG_WZ_Haupt, EG_WZ_Led, EG_WZ_Sofa_Rechts, EG_WZ_Strahler, gEG_Lights, Sunset_Event, All, gEG_ambient, gEG_Powerplug, gEG_Main, gEG_Spots, gEG_XMAS, gXMAS], baseURL=https://myopenhab.org/, service.config.category=io, service.config.description.uri=io:openhabcloud, mode=remote, service.pid=org.openhab.openhabcloud, service.config.label=openHAB Cloud, component.id=217, service.id=349, service.bundleid=217, service.scope=bundle} - org.openhab.io.openhabcloud
17:11:09.109 [DEBUG] [o.openhabcloud.internal.CloudService] - openHAB Cloud connector activated
17:11:09.144 [DEBUG] [o.openhabcloud.internal.CloudService] - Could not determine update version of java 1.8.0
17:11:09.179 [DEBUG] [o.openhabcloud.internal.CloudService] - Using secret at '/var/lib/openhab2/openhabcloud/secret' with content 'MYSECRET'
17:11:09.206 [DEBUG] [o.openhabcloud.internal.CloudService] - UUID = MYUUID, secret = MYSECRET
17:11:09.241 [DEBUG] [o.openhabcloud.internal.CloudService] - Using secret at '/var/lib/openhab2/openhabcloud/secret' with content 'MYSECRET'
17:22:19.716 [DEBUG] [io.openhabcloud.internal.CloudClient] - No connection, Item update is not sent
17:22:22.107 [DEBUG] [io.openhabcloud.internal.CloudClient] - No connection, Item update is not sent
