KevinI
(Kevin)
November 16, 2018, 9:33am
25
I’m seeing the following errors in the openhsb2.log when testing using IOS app and remote connections.
Not sure if this is causing me any issues but it’s a new set of messages.
2018-11-16 09:20:07.015 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 13267 failed: null
2018-11-16 09:20:09.099 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 13278 failed: null
2018-11-16 09:20:13.155 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 13280 failed: null
2018-11-16 09:20:16.466 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 13287 failed: null
Regards
Kevin
besolved
(Björn)
November 16, 2018, 9:58am
26
Wow, thank you Dan! Everything runs fine- great work. Hope you can sleep now:). Thanks to the Community!
Openh
(Luis)
November 16, 2018, 3:03pm
27
Problem persist, can conectó to the cloud, Goggle Assistant cant reach my devices
digitaldan
(Dan Cunningham)
November 16, 2018, 3:25pm
28
Can you check you can connect using a browser? I want to make sure your OH is actually connected to the cloud service.
digitaldan
(Dan Cunningham)
November 16, 2018, 3:26pm
29
Is this problem still persisting for you?
zolon
(Zolon Farsane)
November 16, 2018, 4:07pm
30
No. It started working with expected results around 5am CST. Maybe sooner, but that is when I woke up.
Openh
(Luis)
November 16, 2018, 5:14pm
31
SOLVED I just try from my iPad and everything it’s ok. Google Home its working fine though. Thanks Dan. For other persons having the same troubleshoting just try to acces your cloud instance for an external device.
vbbaby3
(Jörg)
November 27, 2018, 4:47pm
32
Does myopenhab.org have problems again?
Its kinda weird. myopenhab.org say my openhab is offline. But I can see Event log updates fine??
It worked fine an hour ago, and then suddenly, offline.
Is this the same Problem ?
No not exactly, cause the cloud is somehow working… I´m about to restart my openhab server. Hopefully it will fix it.
EDIT - Restart of openhab server got the cloud working fully again.
