Myopenhab.org items not showing
You´ll probably need to add a rule and I believe a trigger item for Alexa… And then something like this..
Rule "label.."
When
         item <alexa trigger item> changed
Then
        BraviaInput.sendCommand ("HDMI4")
I think thats the way to do it, but I have never tried it with a string.
Btw.. You should start a new thread on this :slight_smile:
thanks i will give it a try and move this to a new threat. thanks and i will test.!
I just checked the log file and found following error
2019-08-06 20:57:11.196 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /rest/items
javax.servlet.ServletException: javax.servlet.ServletException: java.lang.IllegalStateException: Request scope has been already shut down.
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:88) ~[?:?]
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.Server.handle(Server.java:531) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:352) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) ~[87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) ~[87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) ~[87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produce(EatWhatYouKill.java:132) ~[87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) [87:org.eclipse.jetty.util:9.4.11.v20180605]
Caused by: javax.servlet.ServletException: java.lang.IllegalStateException: Request scope has been already shut down.
	at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489) ~[169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) ~[169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) ~[169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) ~[169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) ~[169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) ~[?:?]
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865) ~[85:org.eclipse.jetty.servlet:9.4.11.v20180605]
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535) ~[85:org.eclipse.jetty.servlet:9.4.11.v20180605]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[?:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) ~[82:org.eclipse.jetty.security:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1317) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) ~[?:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473) ~[85:org.eclipse.jetty.servlet:9.4.11.v20180605]
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1219) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) ~[?:?]
	... 14 more
Caused by: java.lang.IllegalStateException: Request scope has been already shut down.
	at jersey.repackaged.com.google.common.base.Preconditions.checkState(Preconditions.java:173) ~[167:org.glassfish.jersey.bundles.repackaged.jersey-guava:2.22.2]
	at org.glassfish.jersey.process.internal.RequestScope.retrieveCurrent(RequestScope.java:239) ~[171:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:314) ~[171:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) ~[169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	... 14 more
May that be the problem? And does anyone have an idea how to solve that?
Make sure you are using the correct java version:
what is the correct java version?
here is what I have:
java version "1.8.0_201"
Java(TM) SE Runtime Environment (build 1.8.0_201-b09)
Java HotSpot(TM) Client VM (build 25.201-b09, mixed mode)
That’s why I posted a link to the installation prerequisites.
Wow, don’t know how I could miss that one. Sorry.
So I do have the correct Java version. Any other suggestions?
I had some issues initially setting up also. In the end I don’t really know what my issue was other than being a noob back then. Sometimes I tend to be impatient and not let things run the course they should, making changes faster than updates happen.
I have switched to hue emulation and other than Alexa randomly telling me the kitchen light does not exist. It works great. This is an alexa problem not an openHAB problem.
I do however use my openHAB on my google device.
One tip I have to offer is check https://alexa.amazon.com/ from a laptop. Go to smart home then devices. See what’s there. I have had much better luck using this to discover devices verses my actual echo. Not sure that I can explain this again an alexa issue. I just know sitting in my bedroom working on the laptop I have asked alexa to discover devices. She will run discovery then say “no new devices”. I immediately click open a new browser and click discover devices and all works.
Only suggestion I have at the present moment. I know it can be frustration but when it all works you will be very happy! Once it all works it will generally keep working with no issues!!
Hi Kim, just to thank you for your advise on this one, with this info and just another change i saw on another post i made it to work!! thanks again. I will be posting my solution on the post i crated as advised for yourself!
When might the IFTTT integration be working again? I am trying to set up integration with my Samsung washer via IFTTT and OpenHAB Cloud but can’t get OpenHAB Cloud (or therefore IFTTT) to see my “Washing Finished” switch item.
Here is a workaround, although not easy to implement:
Thanks for sharing! Although as you say, looks like a lot of work to set it all up
I have the same problem. I’d like to expose some virtual buttons to MyOpenCloud to use with IFTTT but I can’t find them.
I changed the state and there are correctly exposed but they don’t show up. Any hints?
That feature is disabled currently:
@DanE, you might have gotten this to work, but just in case, let me share what made it work for me. Once I set the Mode to “Notifications & Remote Access” in the openHAB Cloud connector, my items, that had the tagging, were discovered by Alexa. And yes, if the Mode is set back to “Notifications”, Alexa will loose access to the items.
To be honest, I do not feel that great to have all my items scanned by Alexa via the openHAB home skill…
Wow, now I put so much time into this and didn’t get it to work. so at some point I gave up for the moment. This week when I checked everything again, I noticed that all my items are there. Now I can use all my items with alexa without doin any changes. very weird!
These both refer to making items files.
What about devices that are discovered within PaperUI?
They all need to be linked to Items.
Of course - but if I create the items in PaperUI and put the “Lighting” category on them, I don’t see them in Alexa. Is it required that I create the items in an items file rather than in PaperUI?
No, but for PaperUI created items you need to tag via REST Api:
