Rule
sendNotification
Dont seam to work after af change to myopenhab.org
I have several sendbroadcastnotification commands in my rule. They do work with the new myopenhab.
Just made a quick check with sendnotification. Works for me!
Does it work when you send a message through myopenhab.org website (device section)?
no devices ?
Can I use the REST API with openhab Cloud and if yes what is the correct syntax.
I have tried
with http://myopenhab.org/CMD?myitemname=OFF
I am receiving: āError 404 Not foundā
https://myopenhab.org/CMD?myitemname=OFF
Receiving forbidden
I am using a tool which should add the login/password.
Do I have to use HTTP basic authentication?
If yes how does the syntax look taking into account that the login contains the ā@ā due to the email address is used as the login.
Itās not so easy to make a guess what may be your problem from a two-word-answerā¦
Donāt you have any devices or donāt you know where to find the devices section?
It says no Devices, but iām using the iPhone app with the new URL
Sorry to belabor this, but I am not seeing my exposed devices at all in IFTTT (you replied in my other thread). Iāve been banging my head on this and am curious if what I quoted above might mean that it is not a problem with my set up but rather a problem with myopenhab.org and IFTTT integration? Please let me know so that I can continue to work on figuring out what is wrong or just wait until things are resolved with IFTTT. Iām still running 1.3.8. Thanks
Can you access your sitemap with the iPhone app (local and/or remote)? Does the website myopenhab.org says that you are online?
Possibly. I donāt know how the tool you are using works. When I access it from Tasker I use basic auth. Also, note that that URL syntax will only work for OH 1.x. Setting an Itemās state using GET has never been officially supported and no longer exists in OH 2.0.
According to the quote that is part of your post, IFTTT will not be available until next Tuesday at the earliest.
Thatās what I thought but it seemed like some folks are at least seeing some of their items in IFTTT whereas I cannot see them at all. Thatās the reason I posed the question.
Yes using the iphone Sitemap, and its not local.
It says online On the www
Sorry, but then I have no other ideasā¦
I want to be able to see the item phone1 that is a Switch item. The the file /etc/openhab/configurations/openhab.cfg i have added openhabcloud:expose=phone1
Why does this not work?
I am running openhab 1.8.3.
Both notification and remote access is working.
Anyone that has a clu why its not working for me?
I will later use this for IFTTT but i understand that is not working right now.
Iām having a similar issue, I can see my OpenHAB is online, Iām able to remotely see my sitemap. However no items are showing on myopenhab page. Iāve tried with quotes and without in the config file.
Perhaps a few more details on the config, examples evenā¦
I understand IFTTT failed and itās coming at some point, but at this point I canāt see it would work for me as I have no items.
Iām having the same issue. Iāve tried changing the config file, changing items state, etc. Not sure what Iām missing!
Similar issue here. My config is:
openhabcloud:expose=Lock_Front_Door,Outdoor_BackDeckLEDs,Upstairs_Fire,Scene_LivingAreas,Locks
But Scene_LivingAreas and Locks do not get status sent to myopenhab.org. Scene_LivingAreas is a Number item, Locks is a group (I am not certain if groups should work).
I have the same problem as above running Openhab 1.8.3. I got an email on the 15th saying the IFTTT would stop working on the 16th so Iāve changed over and itās broke. Donāt you think that a) You shouldāve given a little more time and b) You shouldāve tested this more thoroughly?
Iām using openHAB 2 encase that is different but I donāt think the config file is used for the new one. It SEEMS that it now itās moved from my.openhab.org to the new myopenhab.org it needs a new extension and setup which uses the db files not the config files.
I have got my items back into myopenhab.org by removing the old my.openhab extention (using paperUI which is what I originally installed it with) and then I deleted the my.openhab config file and folder before then installed the new āopenHAB Cloud Connectorā extension (again in paperUI).
Next I restarted openHAB (just to be sure) and went to:
Save it and wait for myopenhab to pick them up.
items not showing up in the new myopenhab. OH Version 1.8, suitable Java Version. System comes online, can connect through the iOS App und via Webservice, but the item list stays empty. Got 3 items to expose, already configured, restarted OH serveral times, no luck
