Do you by chance have anything defined within conf/services/addons.cfg or are all entries still in comments in there?
I wouldn’t have any explanation, why an uninstall happens during the runtime without doing anything actively yourself…
Hi everyone!
I am asking for your help.
I have two openHAB 1.8.3 installations in different locations, and both were linked to different my.openHAB accounts. The first one is installed on a Debian PC, the second one on a RaspberryPI.
I moved the first one to the new myopenHAB service few days after it was brought live, and there were no problems.
Now I decided to move the second one, I follow the instructions, do same steps that I’ve done for the first, but openHAB doesn’t come Online in myopenhab.org. Here is what I’ve done:
Created a new account on myopenhab.org, using existing uuid and secret;
Activated this account by following the link from the letter;
Checked Java version on my Raspberry - it is 1.8.0_122;
Replaced the old my.openhab binding jar with the new openhabcloud one in the folder /usr/share/openhab/addons
Restarted openHAB, and… fail:
"Your openHAB is not online. Please check if your installation is running or recheck the openHAB settings in your account."
I looked into logs and did not find any errors or even warnings from openhabcloud binding, only debug messages. Here is what I tried to do additionally:
Tried to expose one of my items in openhab.cfg, because I read somewhere that it can help. No effect.
Tried to remove old uuid and secret files, restart openHAB and let it generate new files, update them in myopenhab.org account settings, and restart openHAB again. No effect, openHAB is still offline.
I don’t know what to do next. Here is the output of netstat -tan | grep 139.162.171.235 (IP address of myopenhab.org), maybe it can help somehow:
are there any new news About the Alexa Skill?
I like the Alexa Hue Skill with my two Hue Bulbs but i will Love the Alexa openHAB Skill with my Rollershutter and Radiator and and and.
Hi roher,
no help, but I have the same problem. OH 1.8.3 on Raspberry with Jessie.
OH is running, logs are looking good, but myopenhab showing “offline”.
Did the same things like you did, but no success
I am having the same problem for OH1 on RaspberryPi2 running Wheezy. Successfully registered to myOpenHAB but cannot get on line from runtime. No error messages. Have you or anyone else discovered the solution?
I setup and configured myopenhab. It works at the moment but whenever i go into “My Dashboards” and go into “Paper UI”, i can see all my configurations however i cannot set any one of them. It simply doesnot save. I cannot install new binding, i cannot change any configurations and etc. Is there anything i am missing?
This seem to still be a problem. I’ve tried several of the suggestion posted here, and I have done an exhaustive search trying to find and fixture out a solution, with no success.
" [INFO ] [core.karaf.internal.FeatureInstaller] - Uninstalled ‘openhab-misc-openhabcloud’"
Has everyone came up with a solution to this problem??
You can either install addons through PaperUI or addons.cfg.
If you have any addons configured in addons.cfg, you cannot install other addons through PaperUI. If you do those get uninstalled,
