Ok, I think I’m getting the hang of it. I have been able to install and configure the binding.
I had to use the last compilation from GitHUB (20170220) despite the flooding of messages about state changing: the one from fatman42285 compiled in May wasn’t giving that problem, but somehow it wasn’t working for me, as I could never send any command to the botvac, neither was able to read any properties.
Then, I wanted to create a .items and a .sitemap files but I discovered I had better let the Paper UI interface creates the items and then manually create the sitemap from them.
Now I have a pretty plain sitemap with all the info and the commands, and that’s when the fun starts
I own a D5 model, and I would like some tips from other owners.
It seems to me that some items aren’t coherent with this model.
Especially, the CleaningMode and the CleaningModifier items.
The Botvac D5 Connected lacks some feature in comparison with its older brother:
- it doesn’t have a map (does it?)
- it doesn’t have a turbo mode (on the opposite, it has a “gentle” mode)
My questions for you:
How do you compensate for that?
Every time I start the botvac, it seems to start in “Extra Care” mode, I would like to understand where should Intervene to be able to decide whether I want the gentle approach or not.
Have you been able to draw a cleaning map, or it is limited on the Neato server side?
Last question, and that’s for all, actually:
The binding has a refresh property, usually set to 10 seconds.
Does that mean that every ten seconds we’re going to poll the Neato server? ins’t that going to borderline with a DOS attack :-)?
