Very good idea, but not experienced with it. Cut out a cp2102 isn’t problem, but how to configurate complete system to work via GPIO ?
Just had a read in both the fhem 2.0 adapter and this ebus binding and am wondering if it would make a lot of difference. Although I am personally no fan of converting back and forth, the ebus adapter 2 is already providing the cp2102 usb option.
The roundtrip time is apparently the time between command and response and that might increase on a congested ebus.
The ebus binding documentation seems to indicate that ebusd is handling latency on the bus very well, so maybe have a look again at the option to have ebusd as the broker in between. In the ebus 3.x topic one has posted their ebus config yesterday, may be worth a try.
Also, as you now know it is working (polling and receiving data such as outside temperature), dial back the amount of polling from 10 seconds to 60 or even higher (how many updates do you even want and every update that you ask for will put a message on the ebus where you don’t want to cause traffic jams of messages).
I still have my doubts about cp2102, as I think there might be typical cheap knock-offs as with many digital items nowadays. But as you are receiving data, the basics of your homemade adapter are apparently correct.
ok, step by step. So first of all test to run it via ebusd ? So I can start ebusd again, and where to change to ebusd ?
and this configaration :
EBUSD_OPTS=“–scanconfig --device=/dev/ttyUSB0 --latency=0 --enablehex --address=00 --localhost --port=8888 --logfile=/var/log/ebusd.log”
Where to add ?
in the file /etc/default/ebusd
Please note that the change should read
EBUSD_OPTS="--scanconfig --device=/dev/ttyUSB0 --latency=0 --enablehex --address=00 --localhost --port=8888 --logfile=/var/log/ebusd.log"
This is slightly different with straight quotes, etc.
now if you didn’t start ebusd already:
systemctl start ebusd
when ebusd was already started before:
systemctl restart ebusd
I have tried to get ebusd running on my Pi Zero W, but could not start it and am unable to find why (ser2net can access ttyAMA0, why not ebusd). So I am unable to test myself with ebusd.
Next the ebus bridge in openhab should be set to network and no longer to serial:
address: localhost or 10.0.0.127
port: 8888
driver: ebusd
ok, done:
number of received telegrams is increasing
but roundtrio time is 0 now
before I changed configuration to ebusd, I deleted created vrc700 general.
But new wasn´t detected
How to check, if now it works better ?
2022-10-29 19:37:40.416 [main notice] ebusd 22.4.v22.4 started with auto scan on device /dev/ttyUSB2
2022-10-29 19:37:41.103 [bus notice] bus started with own address 00/05
2022-10-29 19:37:41.202 [bus notice] signal acquired
2022-10-29 19:37:42.394 [bus notice] new master 10, master count 2
2022-10-29 19:37:42.416 [bus notice] new master 71, master count 3
2022-10-29 19:37:42.416 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:37:52.055 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:37:58.127 [bus notice] new master 03, master count 4
2022-10-29 19:37:58.127 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d70081082400000000
2022-10-29 19:38:01.327 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:38:04.723 [update notice] received unknown MS cmd: 1076b51303040d00 / 020d00
2022-10-29 19:38:05.220 [update notice] received unknown MS cmd: 1008b512020000 / 00
2022-10-29 19:38:05.451 [update notice] received unknown MS cmd: 1008b512020464 / 00
2022-10-29 19:38:12.761 [update notice] received unknown MS cmd: 1076b512030f0201 / 07990200e6010cff
2022-10-29 19:38:14.173 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:38:17.038 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:38:20.037 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:38:38.218 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:38:41.715 [update notice] received unknown MS cmd: 1008b5110101 / 093c370080ffff0100ff
2022-10-29 19:38:42.429 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:38:51.706 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:39:04.688 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:39:11.846 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:39:18.387 [update notice] received unknown MS cmd: 7108b5120e11e201bd01c001fa010c9d050000 / 020232
2022-10-29 19:39:19.283 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:39:26.404 [update notice] received unknown MS cmd: 7108b5120e11e201be01bf01fc010c8b050000 / 020232
2022-10-29 19:39:31.779 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d70081082400000000
2022-10-29 19:39:32.537 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:39:42.207 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:39:52.127 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:40:05.088 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:40:06.310 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:40:12.814 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:40:19.249 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:40:30.522 [update notice] received unknown MS cmd: 7108b5120e11dd01bf01bd0124020c9d050000 / 020232
2022-10-29 19:40:30.967 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:40:32.507 [update notice] received unknown MS cmd: 1008b5110101 / 093b370080ffff0100ff
2022-10-29 19:40:32.692 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:40:32.772 [update notice] received unknown MS cmd: 1076b5110101 / 093c37fe0cff530000ff
2022-10-29 19:40:33.037 [update notice] received unknown MS cmd: 1076b512030f0201 / 07990200e3010cff
2022-10-29 19:40:33.302 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:40:33.567 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:40:34.451 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:40:37.886 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:40:38.527 [update notice] received unknown MS cmd: 7108b5120e11dd01bf01bd012b020c92050000 / 020232
2022-10-29 19:40:41.347 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:40:42.542 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:40:42.611 [main notice] direct cmd: ff15070400
2022-10-29 19:40:42.622 [update notice] received unknown MS cmd: 1008b5110101 / 093b370080ffff0100ff
2022-10-29 19:40:42.887 [update notice] received unknown MS cmd: 1076b5110101 / 093c38fe0cff530000ff
2022-10-29 19:40:43.151 [update notice] received unknown MS cmd: 1076b512030f0201 / 07990200e4010cff
2022-10-29 19:40:43.417 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:40:43.600 [bus error] send to 15: ERR: arbitration lost, retry
2022-10-29 19:40:43.681 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:40:44.785 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:40:46.526 [update notice] received unknown MS cmd: 7108b5120e11de01c001bd0132020c9e050000 / 020232
2022-10-29 19:40:48.246 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:40:51.640 [bus error] send to 15: ERR: arbitration lost, retry
2022-10-29 19:40:51.725 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:40:52.693 [update notice] received unknown MS cmd: 1008b5110101 / 093b380080ffff0100ff
2022-10-29 19:40:52.957 [update notice] received unknown MS cmd: 1076b5110101 / 093c38fe0cff530000ff
2022-10-29 19:40:53.221 [update notice] received unknown MS cmd: 1076b512030f0201 / 07990200e5010cff
2022-10-29 19:40:53.406 [bus error] send to 15: ERR: arbitration lost
2022-10-29 19:40:53.406 [main error] direct: ERR: arbitration lost
2022-10-29 19:40:53.487 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:40:53.751 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:40:54.569 [update notice] received unknown MS cmd: 7108b5120e11e001bf01bd0137020c8b050000 / 020232
2022-10-29 19:40:55.145 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:40:56.473 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:40:56.473 [main notice] direct cmd: ff08070400
2022-10-29 19:40:56.570 [update notice] received unknown MS cmd: 7108b509022802 / 0c020005165f0100484d553031
2022-10-29 19:40:58.597 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:41:02.076 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:41:02.541 [update notice] received unknown MS cmd: 7108b5120e11e001c001bd013c020c9e050000 / 020232
2022-10-29 19:41:02.682 [bus error] send to 08: ERR: arbitration lost, retry
2022-10-29 19:41:02.762 [update notice] received unknown MS cmd: 1008b5110101 / 093c380080ffff0100ff
2022-10-29 19:41:03.027 [update notice] received unknown MS cmd: 1076b5110101 / 093c38fe0cff530000ff
2022-10-29 19:41:03.291 [update notice] received unknown MS cmd: 1076b512030f0201 / 07990200e6010cff
2022-10-29 19:41:03.505 [update notice] received unknown BC cmd: 10feb505025c00
2022-10-29 19:41:03.689 [bus error] send to 08: ERR: arbitration lost, retry
2022-10-29 19:41:03.770 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:41:04.035 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:41:04.304 [update notice] received unknown MS cmd: 1076b5040100 / 0a0335402029100622fe0c
2022-10-29 19:41:04.543 [update notice] received unknown MS cmd: 1008b507020937 / 02b002
2022-10-29 19:41:04.728 [bus error] send to 08: ERR: arbitration lost
2022-10-29 19:41:04.728 [main error] direct: ERR: arbitration lost
2022-10-29 19:41:04.731 [main notice] direct cmd: ff76070400
2022-10-29 19:41:04.782 [update notice] received unknown BC cmd: 10feb516080032402029100622
2022-10-29 19:41:05.047 [update notice] received unknown MS cmd: 1008b5110100 / 09e0010c320409000000
2022-10-29 19:41:05.291 [update notice] received unknown MS cmd: 1076b51303040d00 / 020d00
2022-10-29 19:41:05.516 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:41:05.524 [bus error] send to 76: ERR: arbitration lost, retry
2022-10-29 19:41:05.558 [update notice] received unknown BC cmd: 10feb5160301fe0c
2022-10-29 19:41:08.992 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:41:10.561 [update notice] received unknown MS cmd: 7108b5120e11e101c101bd0140020ca9050000 / 020232
2022-10-29 19:41:12.413 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:41:12.773 [bus error] send to 76: ERR: arbitration lost, retry
2022-10-29 19:41:12.854 [update notice] received unknown MS cmd: 1008b5110101 / 093c380080ffff0100ff
2022-10-29 19:41:13.118 [update notice] received unknown MS cmd: 1076b5110101 / 093c38fe0cff530000ff
2022-10-29 19:41:13.384 [update notice] received unknown MS cmd: 1076b512030f0201 / 07990200e7010cff
2022-10-29 19:41:13.649 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:41:13.833 [bus error] send to 76: ERR: arbitration lost
2022-10-29 19:41:13.833 [main error] direct: ERR: arbitration lost
2022-10-29 19:41:13.914 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:41:15.898 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:41:17.774 [update notice] received unknown MS cmd: 7108b51a03047332 / 0e7307c0cfc07b3c00b01b20000000
2022-10-29 19:41:18.200 [update notice] received unknown MS cmd: 7108b51a03047433 / 0e740000008a000000000000000000
2022-10-29 19:41:18.582 [update notice] received unknown MS cmd: 7108b51a03047534 / 0e75cf2000c0022101001800061800
2022-10-29 19:41:18.766 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:41:18.872 [update notice] received unknown MS cmd: 7108b5120e11e101c101be0144020c9e050000 / 020232
2022-10-29 19:41:19.165 [update notice] received unknown MS cmd: 7108b51a03047635 / 0e7600000000000100b00100000000
2022-10-29 19:41:19.547 [update notice] received unknown MS cmd: 7108b51a03047736 / 0e7700000000000000000000000000
2022-10-29 19:41:20.036 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:41:22.895 [update notice] received unknown MS cmd: 1008b5110101 / 093c380080ffff0100ff
2022-10-29 19:41:23.160 [update notice] received unknown MS cmd: 1076b5110101 / 093d38fe0cff530000ff
2022-10-29 19:41:23.425 [update notice] received unknown MS cmd: 1076b512030f0201 / 07990200e8010cff
2022-10-29 19:41:23.434 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:41:23.518 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:41:23.739 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:41:24.003 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:41:24.007 [bus notice] max. symbols per second: 118
2022-10-29 19:41:26.624 [update notice] received unknown MS cmd: 7108b5120e11e301c101be0146020c9e050000 / 020232
2022-10-29 19:41:26.937 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:41:30.371 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:41:32.886 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:41:32.966 [update notice] received unknown MS cmd: 1008b5110101 / 093c380080ffff0100ff
2022-10-29 19:41:33.231 [update notice] received unknown MS cmd: 1076b5110101 / 093d38fe0cff530000ff
2022-10-29 19:41:33.497 [update notice] received unknown MS cmd: 1076b512030f0201 / 07990200e9010cff
2022-10-29 19:41:33.762 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:41:33.854 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:41:34.075 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:41:34.628 [update notice] received unknown MS cmd: 7108b5120e11e301c101be0149020c9e050000 / 020232
2022-10-29 19:41:37.316 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:41:40.751 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:41:42.623 [update notice] received unknown MS cmd: 7108b5120e11e301c101be014b020c9e050000 / 020232
2022-10-29 19:41:43.064 [update notice] received unknown MS cmd: 1008b5110101 / 093c380080ffff0100ff
2022-10-29 19:41:43.328 [update notice] received unknown MS cmd: 1076b5110101 / 093d38fe0cff530000ff
2022-10-29 19:41:43.513 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:41:43.594 [update notice] received unknown MS cmd: 1076b512030f0201 / 07990200ea010cff
2022-10-29 19:41:43.859 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:41:44.124 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:41:44.216 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:41:47.651 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:41:50.667 [update notice] received unknown MS cmd: 7108b5120e11d801c101be014b020c9c050000 / 020232
2022-10-29 19:41:51.112 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:41:53.055 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:41:53.135 [update notice] received unknown MS cmd: 1008b5110101 / 093b380080ffff0000ff
2022-10-29 19:41:53.400 [update notice] received unknown MS cmd: 1076b5110101 / 093c38fe0cff530000ff
2022-10-29 19:41:53.665 [update notice] received unknown MS cmd: 1076b512030f0201 / 07990200e0010cff
2022-10-29 19:41:53.930 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:41:54.195 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:41:54.552 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:41:58.030 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:41:58.672 [update notice] received unknown MS cmd: 7108b5120e11ca01c101be0144020c96050000 / 020232
2022-10-29 19:42:01.491 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:42:03.126 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:42:03.207 [update notice] received unknown MS cmd: 1008b5110101 / 0939380080ffff0000ff
2022-10-29 19:42:03.471 [update notice] received unknown MS cmd: 1076b5110101 / 093a38fe0cff530000ff
2022-10-29 19:42:03.736 [update notice] received unknown MS cmd: 1076b512030f0201 / 07990200d3010cff
2022-10-29 19:42:04.218 [update notice] received unknown BC cmd: 10feb505025c00
2022-10-29 19:42:04.483 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:42:04.748 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:42:04.929 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:42:05.066 [update notice] received unknown MS cmd: 1076b5040100 / 0a0335412029100622fe0c
2022-10-29 19:42:05.305 [update notice] received unknown MS cmd: 1008b507020937 / 02b002
2022-10-29 19:42:05.545 [update notice] received unknown BC cmd: 10feb516080033412029100622
2022-10-29 19:42:05.809 [update notice] received unknown MS cmd: 1008b5110100 / 09ca010c000508000000
2022-10-29 19:42:06.053 [update notice] received unknown MS cmd: 1076b51303040d00 / 020d00
2022-10-29 19:42:06.271 [update notice] received unknown BC cmd: 10feb5160301fe0c
2022-10-29 19:42:06.692 [update notice] received unknown MS cmd: 7108b5120e11c601c101be013b020ca2050000 / 020232
2022-10-29 19:42:08.368 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:42:11.847 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:42:13.299 [update notice] received unknown MS cmd: 1008b5110101 / 0938380080ffff0000ff
2022-10-29 19:42:13.564 [update notice] received unknown MS cmd: 1076b5110101 / 093938fe0cff530000ff
2022-10-29 19:42:13.748 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:42:13.829 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200cd010cff
2022-10-29 19:42:14.094 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:42:14.359 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:42:14.692 [update notice] received unknown MS cmd: 7108b5120e11c601c101be0134020c9e050000 / 020232
2022-10-29 19:42:15.313 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:42:17.014 [update notice] received unknown MS cmd: 7108b51a03047d32 / 0e7d07c0cfc07b3c00b01b20000000
2022-10-29 19:42:17.395 [update notice] received unknown MS cmd: 7108b51a03047e33 / 0e7e0000008a000000000000000000
2022-10-29 19:42:17.777 [update notice] received unknown MS cmd: 7108b51a03047f34 / 0e7fcf2000c0022101001800061800
2022-10-29 19:42:18.049 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:42:18.159 [update notice] received unknown MS cmd: 7108b51a03048035 / 0e8000000000000100b00100000000
2022-10-29 19:42:18.585 [update notice] received unknown MS cmd: 7108b51a03048136 / 0e8100000000000000000000000000
2022-10-29 19:42:19.029 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:42:22.508 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:42:22.798 [update notice] received unknown MS cmd: 7108b5120e11c601c201be012f020c9e050000 / 020232
2022-10-29 19:42:23.370 [update notice] received unknown MS cmd: 1008b5110101 / 0938380080ffff0000ff
2022-10-29 19:42:23.555 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:42:23.635 [update notice] received unknown MS cmd: 1076b5110101 / 093938fe0cff530000ff
2022-10-29 19:42:23.900 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200cc010cff
2022-10-29 19:42:24.165 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:42:24.430 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:42:25.930 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:42:29.409 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:42:30.709 [update notice] received unknown MS cmd: 7108b5120e11c701c301be012a020c9d050000 / 020232
2022-10-29 19:42:32.869 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:42:33.442 [update notice] received unknown MS cmd: 1008b5110101 / 0938380080ffff0000ff
2022-10-29 19:42:33.707 [update notice] received unknown MS cmd: 1076b5110101 / 093938fe0cff530000ff
2022-10-29 19:42:33.891 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:42:33.971 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200ce010cff
2022-10-29 19:42:34.236 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:42:34.500 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:42:36.308 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:42:38.708 [update notice] received unknown MS cmd: 7108b5120e11c801c301bc0127020c95050000 / 020232
2022-10-29 19:42:39.769 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:42:43.119 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:42:43.204 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:42:43.512 [update notice] received unknown MS cmd: 1008b5110101 / 0939380080ffff0000ff
2022-10-29 19:42:43.777 [update notice] received unknown MS cmd: 1076b5110101 / 093938fe0cff530000ff
2022-10-29 19:42:44.042 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200ce010cff
2022-10-29 19:42:44.307 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:42:44.572 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:42:46.687 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:42:46.977 [update notice] received unknown MS cmd: 7108b5120e11c701c201b80124020c9e050000 / 020232
2022-10-29 19:42:50.148 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:42:53.498 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:42:53.579 [update notice] received unknown MS cmd: 1008b5110101 / 0938380080ffff0000ff
2022-10-29 19:42:53.843 [update notice] received unknown MS cmd: 1076b5110101 / 093938fe0cff530000ff
2022-10-29 19:42:54.108 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200cd010cff
2022-10-29 19:42:54.201 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:42:54.423 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:42:54.687 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:42:54.801 [update notice] received unknown MS cmd: 7108b5120e11c701c201b60122020cb1050000 / 020232
2022-10-29 19:42:55.025 [bus notice] max. symbols per second: 124
2022-10-29 19:42:57.049 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:43:00.483 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:43:02.751 [update notice] received unknown MS cmd: 7108b5120e11c701c201b2011f020cb1050000 / 020232
2022-10-29 19:43:03.676 [update notice] received unknown MS cmd: 1008b5110101 / 0938380080ffff0000ff
2022-10-29 19:43:03.941 [update notice] received unknown MS cmd: 1076b5110101 / 093938fe0cff530000ff
2022-10-29 19:43:03.993 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:43:04.078 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:43:04.255 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200ce010cff
2022-10-29 19:43:04.469 [update notice] received unknown BC cmd: 10feb505025c00
2022-10-29 19:43:04.734 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:43:04.998 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:43:05.267 [update notice] received unknown MS cmd: 1076b5040100 / 0a0335422029100622fe0c
2022-10-29 19:43:05.507 [update notice] received unknown MS cmd: 1008b507020937 / 02b002
2022-10-29 19:43:05.746 [update notice] received unknown BC cmd: 10feb516080034422029100622
2022-10-29 19:43:06.010 [update notice] received unknown MS cmd: 1008b5110100 / 09c7010c000808000000
2022-10-29 19:43:06.254 [update notice] received unknown MS cmd: 1076b51303040d00 / 020d00
2022-10-29 19:43:06.473 [update notice] received unknown BC cmd: 10feb5160301fe0c
2022-10-29 19:43:06.703 [update notice] received unknown MS cmd: 1008b512020000 / 00
2022-10-29 19:43:06.887 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:43:06.934 [update notice] received unknown MS cmd: 1008b512020464 / 00
2022-10-29 19:43:07.169 [update notice] received unknown MS cmd: 1008b513020528 / 0101
2022-10-29 19:43:07.394 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:43:07.432 [update notice] received unknown BC cmd: 10feb510020601
2022-10-29 19:43:07.646 [update notice] received unknown BC cmd: 10feb508020900
2022-10-29 19:43:10.793 [update notice] received unknown MS cmd: 7108b5120e11c701c301b0011d020c98050000 / 020232
2022-10-29 19:43:11.062 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:43:13.745 [update notice] received unknown MS cmd: 1008b5110101 / 0938380080ffff0000ff
2022-10-29 19:43:13.930 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:43:14.010 [update notice] received unknown MS cmd: 1076b5110101 / 093938fe0cff530000ff
2022-10-29 19:43:14.275 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200ce010cff
2022-10-29 19:43:14.368 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:43:14.589 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:43:14.854 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:43:16.203 [update notice] received unknown MS cmd: 7108b51a03048732 / 0e8707c0cfc07b3c00b01b20000000
2022-10-29 19:43:16.585 [update notice] received unknown MS cmd: 7108b51a03048833 / 0e880000008a000000000000000000
2022-10-29 19:43:17.010 [update notice] received unknown MS cmd: 7108b51a03048934 / 0e89cf2000c0022101001800061800
2022-10-29 19:43:17.392 [update notice] received unknown MS cmd: 7108b51a03048a35 / 0e8a00000000000100b00100000000
2022-10-29 19:43:17.774 [update notice] received unknown MS cmd: 7108b51a03048b36 / 0e8b00000000000000000000000000
2022-10-29 19:43:18.263 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:43:18.772 [update notice] received unknown MS cmd: 7108b5120e11c701c201af011c020c9e050000 / 020232
2022-10-29 19:43:21.723 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:43:23.835 [update notice] received unknown MS cmd: 1008b5110101 / 0938380080ffff0000ff
2022-10-29 19:43:24.100 [update notice] received unknown MS cmd: 1076b5110101 / 093938fe0cff530000ff
2022-10-29 19:43:24.365 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200ce010cff
2022-10-29 19:43:24.549 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:43:24.630 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:43:24.895 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:43:25.163 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:43:26.816 [update notice] received unknown MS cmd: 7108b5120e11c601c201ad0119020caf050000 / 020232
2022-10-29 19:43:28.624 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:43:32.059 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:43:33.826 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:43:33.906 [update notice] received unknown MS cmd: 1008b5110101 / 0938380080ffff0000ff
2022-10-29 19:43:34.171 [update notice] received unknown MS cmd: 1076b5110101 / 093938fe0cff530000ff
2022-10-29 19:43:34.436 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200cd010cff
2022-10-29 19:43:34.701 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:43:34.814 [update notice] received unknown MS cmd: 7108b5120e11c601c201ac0117020cb1050000 / 020232
2022-10-29 19:43:35.036 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:43:35.525 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:43:38.960 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:43:42.439 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:43:42.816 [update notice] received unknown MS cmd: 7108b5120e11c601c201ac0114020cb1050000 / 020232
2022-10-29 19:43:43.880 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:43:43.960 [update notice] received unknown MS cmd: 1008b5110101 / 0938380080ffff0000ff
2022-10-29 19:43:44.226 [update notice] received unknown MS cmd: 1076b5110101 / 093938fe0cff530000ff
2022-10-29 19:43:44.491 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200cc010cff
2022-10-29 19:43:44.756 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:43:45.021 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:43:45.905 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:43:49.339 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:43:50.864 [update notice] received unknown MS cmd: 7108b5120e11c501c201ab0112020cab050000 / 020232
2022-10-29 19:43:52.804 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:43:54.036 [update notice] received unknown MS cmd: 1008b5110101 / 0938380080ffff0000ff
2022-10-29 19:43:54.301 [update notice] received unknown MS cmd: 1076b5110101 / 093938fe0cff530000ff
2022-10-29 19:43:54.485 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:43:54.566 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200cc010cff
2022-10-29 19:43:54.831 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:43:55.096 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:43:56.245 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:43:58.865 [update notice] received unknown MS cmd: 7108b5120e11c501c101ab010f020c9e050000 / 020232
2022-10-29 19:43:59.706 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:44:03.140 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:44:04.072 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:44:04.152 [update notice] received unknown MS cmd: 1008b5110101 / 0938380080ffff0000ff
2022-10-29 19:44:04.417 [update notice] received unknown MS cmd: 1076b5110101 / 093938fe0cff530000ff
2022-10-29 19:44:04.682 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200cb010cff
2022-10-29 19:44:04.896 [update notice] received unknown BC cmd: 10feb505025c00
2022-10-29 19:44:05.161 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:44:05.425 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:44:05.694 [update notice] received unknown MS cmd: 1076b5040100 / 0a0336432029100622fe0c
2022-10-29 19:44:05.934 [update notice] received unknown MS cmd: 1008b507020937 / 02b002
2022-10-29 19:44:06.174 [update notice] received unknown BC cmd: 10feb516080034432029100622
2022-10-29 19:44:06.438 [update notice] received unknown MS cmd: 1008b5110100 / 09c5010c000808000000
2022-10-29 19:44:06.619 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:44:06.731 [update notice] received unknown MS cmd: 1076b51303040d00 / 020d00
2022-10-29 19:44:06.827 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:44:06.936 [update notice] received unknown MS cmd: 7108b5120e11c401c101aa010d020c9e050000 / 020232
2022-10-29 19:44:07.023 [update notice] received unknown BC cmd: 10feb5160301fe0c
2022-10-29 19:44:10.062 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:44:13.496 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:44:14.201 [update notice] received unknown MS cmd: 1008b5110101 / 0938380080ffff0000ff
2022-10-29 19:44:14.466 [update notice] received unknown MS cmd: 1076b5110101 / 093938fe0cff530000ff
2022-10-29 19:44:14.731 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200cb010cff
2022-10-29 19:44:14.892 [update notice] received unknown MS cmd: 7108b5120e11c501c101a9010b020cb1050000 / 020232
2022-10-29 19:44:15.070 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:44:15.334 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:44:15.452 [update notice] received unknown MS cmd: 7108b51a03049132 / 0e9107c0cfc07b3c00b01b20000000
2022-10-29 19:44:15.680 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:44:15.790 [update notice] received unknown MS cmd: 7108b51a03049233 / 0e920000008a000000000000000000
2022-10-29 19:44:16.215 [update notice] received unknown MS cmd: 7108b51a03049334 / 0e93cf2000c0022101001800061800
2022-10-29 19:44:16.597 [update notice] received unknown MS cmd: 7108b51a03049435 / 0e9400000000000100b00100000000
2022-10-29 19:44:16.979 [update notice] received unknown MS cmd: 7108b51a03049536 / 0e9500000000000000000000000000
2022-10-29 19:44:17.468 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:44:20.903 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:44:22.911 [update notice] received unknown MS cmd: 7108b5120e11c601c101a90109020c9f050000 / 020232
2022-10-29 19:44:24.275 [update notice] received unknown MS cmd: 1008b5110101 / 0938380080ffff0000ff
2022-10-29 19:44:24.284 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:44:24.367 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:44:24.588 [update notice] received unknown MS cmd: 1076b5110101 / 093938fe0cff530000ff
2022-10-29 19:44:24.853 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200cc010cff
2022-10-29 19:44:25.118 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:44:25.383 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:44:27.806 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:44:30.914 [update notice] received unknown MS cmd: 7108b5120e11c601c101a90107020cb1050000 / 020232
2022-10-29 19:44:31.271 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:44:34.269 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:44:34.349 [update notice] received unknown MS cmd: 1008b5110101 / 0938380080ffff0000ff
2022-10-29 19:44:34.614 [update notice] received unknown MS cmd: 1076b5110101 / 093938fe0cff530000ff
2022-10-29 19:44:34.751 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:44:34.927 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200cc010cff
2022-10-29 19:44:35.193 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:44:35.457 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:44:38.188 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:44:38.926 [update notice] received unknown MS cmd: 7108b5120e11c601c101a90105020caa050000 / 020232
2022-10-29 19:44:41.657 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:44:44.428 [update notice] received unknown MS cmd: 1008b5110101 / 0938380080ffff0000ff
2022-10-29 19:44:44.693 [update notice] received unknown MS cmd: 1076b5110101 / 093938fe0cff530000ff
2022-10-29 19:44:44.958 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200cc010cff
2022-10-29 19:44:45.010 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:44:45.095 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:44:45.272 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:44:45.537 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:44:46.930 [update notice] received unknown MS cmd: 7108b5120e11c501c001aa0103020ca0050000 / 020232
2022-10-29 19:44:48.562 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:44:51.997 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:44:54.504 [update notice] received unknown MS cmd: 1008b5110101 / 0938380080ffff0000ff
2022-10-29 19:44:54.689 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:44:54.769 [update notice] received unknown MS cmd: 1076b5110101 / 093938fe0cff530000ff
2022-10-29 19:44:54.931 [update notice] received unknown MS cmd: 7108b5120e11c501c001aa0102020cab050000 / 020232
2022-10-29 19:44:55.108 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200cb010cff
2022-10-29 19:44:55.373 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:44:55.466 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:44:55.687 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:44:58.902 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:45:02.380 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:45:02.978 [update notice] received unknown MS cmd: 7108b5120e11c501c001ab0101020c9e050000 / 020232
2022-10-29 19:45:04.525 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:45:04.606 [update notice] received unknown MS cmd: 1008b5110101 / 0938380080ffff0000ff
2022-10-29 19:45:04.870 [update notice] received unknown MS cmd: 1076b5110101 / 093938fe0cff530000ff
2022-10-29 19:45:05.136 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200cb010cff
2022-10-29 19:45:05.349 [update notice] received unknown BC cmd: 10feb505025c00
2022-10-29 19:45:05.615 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:45:05.839 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:45:05.929 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:45:06.198 [update notice] received unknown MS cmd: 1076b5040100 / 0a0336442029100622fe0c
2022-10-29 19:45:06.437 [update notice] received unknown MS cmd: 1008b507020937 / 02b002
2022-10-29 19:45:06.677 [update notice] received unknown BC cmd: 10feb516080034442029100622
2022-10-29 19:45:06.941 [update notice] received unknown MS cmd: 1008b5110100 / 09c5010c000008000000
2022-10-29 19:45:07.185 [update notice] received unknown MS cmd: 1076b51303040d00 / 020d00
2022-10-29 19:45:07.403 [update notice] received unknown BC cmd: 10feb5160301fe0c
2022-10-29 19:45:09.255 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:45:10.952 [update notice] received unknown MS cmd: 7108b5120e11c401c001ab01ff010cb1050000 / 020232
2022-10-29 19:45:12.716 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:45:14.636 [update notice] received unknown MS cmd: 7108b51a03049b32 / 0e9b07c0cfc07b3c00b01b20000000
2022-10-29 19:45:14.725 [update notice] received unknown MS cmd: 1008b5110101 / 0938380080ffff0000ff
2022-10-29 19:45:14.910 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:45:14.990 [update notice] received unknown MS cmd: 1076b5110101 / 093937fe0cff530000ff
2022-10-29 19:45:15.240 [update notice] received unknown MS cmd: 7108b51a03049c33 / 0e9c0000008a000000000000000000
2022-10-29 19:45:15.329 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200cb010cff
2022-10-29 19:45:15.594 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:45:15.859 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:45:16.196 [update notice] received unknown MS cmd: 7108b51a03049d34 / 0e9dcf2000c0022101001800061800
2022-10-29 19:45:16.578 [update notice] received unknown MS cmd: 7108b51a03049e35 / 0e9e00000000000100b00100000000
2022-10-29 19:45:17.004 [update notice] received unknown MS cmd: 7108b51a03049f36 / 0e9f00000000000000000000000000
2022-10-29 19:45:17.449 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:45:18.969 [update notice] received unknown MS cmd: 7108b5120e11c401bf01ac01fe010c9e050000 / 020232
2022-10-29 19:45:20.909 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:45:24.303 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:45:24.388 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:45:24.740 [update notice] received unknown MS cmd: 1008b5110101 / 0938370080ffff0000ff
2022-10-29 19:45:25.005 [update notice] received unknown MS cmd: 1076b5110101 / 093937fe0cff530000ff
2022-10-29 19:45:25.270 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200ca010cff
2022-10-29 19:45:25.536 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:45:25.800 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:45:27.013 [update notice] received unknown MS cmd: 7108b5120e11c301bf01ac01fe010c9e050000 / 020232
2022-10-29 19:45:27.810 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:45:31.288 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:45:34.639 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:45:34.723 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:45:34.812 [update notice] received unknown MS cmd: 1008b5110101 / 0938370080ffff0000ff
2022-10-29 19:45:35.058 [update notice] received unknown MS cmd: 7108b5120e11c301bf01ac01fc010cb1050000 / 020232
2022-10-29 19:45:35.147 [update notice] received unknown MS cmd: 1076b5110101 / 0939370b0dff530000ff
2022-10-29 19:45:35.412 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200ca010cff
2022-10-29 19:45:35.677 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:45:35.941 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:45:38.189 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:45:41.624 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:45:43.012 [update notice] received unknown MS cmd: 7108b5120e11c301bf01ac01fb010c9e050000 / 020232
2022-10-29 19:45:44.860 [update notice] received unknown MS cmd: 1008b5110101 / 0938370080ffff0000ff
2022-10-29 19:45:45.085 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:45:45.094 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:45:45.174 [update notice] received unknown MS cmd: 1076b5110101 / 093937fe0cff530000ff
2022-10-29 19:45:45.439 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200ca010cff
2022-10-29 19:45:45.704 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:45:45.969 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:45:48.568 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:45:51.056 [update notice] received unknown MS cmd: 7108b5120e11c301bf01ad01fa010c9e050000 / 020232
2022-10-29 19:45:51.985 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:45:53.400 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:45:53.497 [update notice] received unknown MS cmd: 7108b509022802 / 0c020005165f0100484d553031
2022-10-29 19:45:54.949 [update notice] received unknown MS cmd: 1008b5110101 / 0938370080ffff0000ff
2022-10-29 19:45:55.213 [update notice] received unknown MS cmd: 1076b5110101 / 093937fe0cff530000ff
2022-10-29 19:45:55.438 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:45:55.526 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200c9010cff
2022-10-29 19:45:55.792 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:45:56.056 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:45:58.835 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:45:58.919 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:45:59.209 [update notice] received unknown MS cmd: 7108b5120e11c201be01ad01f9010c8a050000 / 020232
2022-10-29 19:46:02.380 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:46:05.019 [update notice] received unknown MS cmd: 1008b5110101 / 0938370080ffff0000ff
2022-10-29 19:46:05.284 [update notice] received unknown MS cmd: 1076b5110101 / 093937fe0cff530000ff
2022-10-29 19:46:05.548 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200c9010cff
2022-10-29 19:46:05.762 [update notice] received unknown BC cmd: 10feb505025c00
2022-10-29 19:46:05.899 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:46:06.076 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:46:06.341 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:46:06.609 [update notice] received unknown MS cmd: 1076b5040100 / 0a0336452029100622fe0c
2022-10-29 19:46:06.849 [update notice] received unknown MS cmd: 1008b507020937 / 02b002
2022-10-29 19:46:07.051 [update notice] received unknown MS cmd: 7108b5120e11c201be01ad01f9010c9e050000 / 020232
2022-10-29 19:46:07.158 [update notice] received unknown BC cmd: 10feb516080035452029100622
2022-10-29 19:46:07.423 [update notice] received unknown MS cmd: 1008b5110100 / 09c2010c000008000000
2022-10-29 19:46:07.607 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:46:07.667 [update notice] received unknown MS cmd: 1076b51303040d00 / 020d00
2022-10-29 19:46:07.885 [update notice] received unknown BC cmd: 10feb5160301fe0c
2022-10-29 19:46:09.297 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:46:12.731 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:46:13.860 [update notice] received unknown MS cmd: 7108b51a0304a532 / 0ea507c0cfc07b3c00b01b20000000
2022-10-29 19:46:14.242 [update notice] received unknown MS cmd: 7108b51a0304a633 / 0ea60000008a000000000000000000
2022-10-29 19:46:14.515 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:46:14.624 [update notice] received unknown MS cmd: 7108b51a0304a734 / 0ea7cf2000c0022101001800061800
2022-10-29 19:46:15.006 [update notice] received unknown MS cmd: 7108b51a0304a835 / 0ea800000000000100b00100000000
2022-10-29 19:46:15.094 [update notice] received unknown MS cmd: 1008b5110101 / 0938370080ffff0000ff
2022-10-29 19:46:15.340 [update notice] received unknown MS cmd: 7108b5120e11c201be01ad01f8010cb1050000 / 020232
2022-10-29 19:46:15.429 [update notice] received unknown MS cmd: 1076b5110101 / 093937fe0cff530000ff
2022-10-29 19:46:15.686 [update notice] received unknown MS cmd: 7108b51a0304a936 / 0ea900000000000000000000000000
2022-10-29 19:46:15.775 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200c9010cff
2022-10-29 19:46:16.006 [bus notice] max. symbols per second: 143
2022-10-29 19:46:16.040 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:46:16.177 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:46:16.354 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:46:19.657 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:46:23.068 [update notice] received unknown MS cmd: 7108b5120e11c201be01ae01f7010cb1050000 / 020232
2022-10-29 19:46:23.337 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:46:25.105 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:46:25.185 [update notice] received unknown MS cmd: 1008b5110101 / 0938370080ffff0000ff
2022-10-29 19:46:25.450 [update notice] received unknown MS cmd: 1076b5110101 / 093937fe0cff530000ff
2022-10-29 19:46:25.715 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200c8010cff
2022-10-29 19:46:25.980 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:46:26.245 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:46:26.557 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:46:29.992 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:46:31.117 [update notice] received unknown MS cmd: 7108b5120e11c101be01ae01f6010cb1050000 / 020232
2022-10-29 19:46:33.453 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:46:35.256 [update notice] received unknown MS cmd: 1008b5110101 / 0938370080ffff0000ff
2022-10-29 19:46:35.521 [update notice] received unknown MS cmd: 1076b5110101 / 093937fe0cff530000ff
2022-10-29 19:46:35.706 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:46:35.786 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200c8010cff
2022-10-29 19:46:36.051 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:46:36.316 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:46:36.893 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:46:39.118 [update notice] received unknown MS cmd: 7108b5120e11c101be01af01f5010c9e050000 / 020232
2022-10-29 19:46:40.354 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:46:43.833 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:46:45.248 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:46:45.329 [update notice] received unknown MS cmd: 1008b5110101 / 0938370080ffff0000ff
2022-10-29 19:46:45.594 [update notice] received unknown MS cmd: 1076b5110101 / 093937fe0cff530000ff
2022-10-29 19:46:45.859 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200c8010cff
2022-10-29 19:46:46.124 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:46:46.389 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:46:47.118 [update notice] received unknown MS cmd: 7108b5120e11c101be01af01f4010c98050000 / 020232
2022-10-29 19:46:47.388 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:46:50.734 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:46:54.169 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:46:55.013 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:46:55.118 [update notice] received unknown MS cmd: 7108b5120e11c101bd01af01f4010ca8050000 / 020232
2022-10-29 19:46:55.383 [update notice] received unknown MS cmd: 1008b5110101 / 0938370080ffff0000ff
2022-10-29 19:46:55.648 [update notice] received unknown MS cmd: 1076b5110101 / 093937fe0cff530000ff
2022-10-29 19:46:55.913 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200c8010cff
2022-10-29 19:46:56.178 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:46:56.443 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:46:57.635 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:47:01.070 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:47:03.162 [update notice] received unknown MS cmd: 7108b5120e11c101bd01af01f3010cb1050000 / 020232
2022-10-29 19:47:04.530 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:47:05.454 [update notice] received unknown MS cmd: 1008b5110101 / 0938370080ffff0000ff
2022-10-29 19:47:05.719 [update notice] received unknown MS cmd: 1076b5110101 / 093837fe0cff530000ff
2022-10-29 19:47:05.904 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:47:05.984 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200c7010cff
2022-10-29 19:47:06.198 [update notice] received unknown BC cmd: 10feb505025c00
2022-10-29 19:47:06.464 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:47:06.728 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:47:06.997 [update notice] received unknown MS cmd: 1076b5040100 / 0a0337462029100622fe0c
2022-10-29 19:47:07.236 [update notice] received unknown MS cmd: 1008b507020937 / 02b002
2022-10-29 19:47:07.476 [update notice] received unknown BC cmd: 10feb516080034462029100622
2022-10-29 19:47:07.740 [update notice] received unknown MS cmd: 1008b5110100 / 09c1010c000008000000
2022-10-29 19:47:07.984 [update notice] received unknown MS cmd: 1076b51303040d00 / 020d00
2022-10-29 19:47:08.165 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:47:08.251 [update notice] received unknown BC cmd: 10feb5160301fe0c
2022-10-29 19:47:11.179 [update notice] received unknown MS cmd: 7108b5120e11c001bd01af01f2010c9f050000 / 020232
2022-10-29 19:47:11.363 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:47:11.448 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:47:13.061 [update notice] received unknown MS cmd: 7108b51a0304af32 / 0eaf07c0cfc07b3c00b01b20000000
2022-10-29 19:47:13.442 [update notice] received unknown MS cmd: 7108b51a0304b033 / 0eb00000008a000000000000000000
2022-10-29 19:47:13.824 [update notice] received unknown MS cmd: 7108b51a0304b134 / 0eb1cf2000c0022101001800061800
2022-10-29 19:47:14.250 [update notice] received unknown MS cmd: 7108b51a0304b235 / 0eb200000000000100b00100000000
2022-10-29 19:47:14.631 [update notice] received unknown MS cmd: 7108b51a0304b336 / 0eb300000000000000000000000000
2022-10-29 19:47:14.992 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:47:15.077 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:47:15.561 [update notice] received unknown MS cmd: 1008b5110101 / 0938370080ffff0000ff
2022-10-29 19:47:15.826 [update notice] received unknown MS cmd: 1076b5110101 / 093837fe0cff530000ff
2022-10-29 19:47:16.090 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200c7010cff
2022-10-29 19:47:16.355 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:47:16.619 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:47:18.559 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:47:19.156 [update notice] received unknown MS cmd: 7108b5120e11c001bc01af01f1010ca2050000 / 020232
2022-10-29 19:47:22.020 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:47:25.455 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:47:25.631 [update notice] received unknown MS cmd: 1008b5110101 / 0938370080ffff0000ff
2022-10-29 19:47:25.896 [update notice] received unknown MS cmd: 1076b5110101 / 093837fe0cff530000ff
2022-10-29 19:47:26.081 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:47:26.161 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200c6010cff
2022-10-29 19:47:26.426 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:47:26.691 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:47:27.200 [update notice] received unknown MS cmd: 7108b5120e11c001bd01b001f0010cb0050000 / 020232
2022-10-29 19:47:28.921 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:47:32.355 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:47:35.195 [update notice] received unknown MS cmd: 7108b5120e11c001bc01b001f0010c9e050000 / 020232
2022-10-29 19:47:35.599 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:47:35.680 [update notice] received unknown MS cmd: 1008b5110101 / 0938370080ffff0000ff
2022-10-29 19:47:35.817 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:47:35.994 [update notice] received unknown MS cmd: 1076b5110101 / 093837fe0cff530000ff
2022-10-29 19:47:36.258 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200c6010cff
2022-10-29 19:47:36.523 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:47:36.788 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:47:39.255 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:47:42.733 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:47:43.203 [update notice] received unknown MS cmd: 7108b5120e11bf01bc01b001ef010ca9050000 / 020232
2022-10-29 19:47:45.674 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:47:45.754 [update notice] received unknown MS cmd: 1008b5110101 / 0937370080ffff0000ff
2022-10-29 19:47:46.019 [update notice] received unknown MS cmd: 1076b5110101 / 093837fe0cff530000ff
2022-10-29 19:47:46.200 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:47:46.333 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200c6010cff
2022-10-29 19:47:46.598 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:47:46.863 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:47:49.638 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:47:51.203 [update notice] received unknown MS cmd: 7108b5120e11bf01bb01b001ee010cb1050000 / 020232
2022-10-29 19:47:53.099 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:47:55.825 [update notice] received unknown MS cmd: 1008b5110101 / 0937370080ffff0000ff
2022-10-29 19:47:56.091 [update notice] received unknown MS cmd: 1076b5110101 / 093837fe0cff530000ff
2022-10-29 19:47:56.356 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200c6010cff
2022-10-29 19:47:56.452 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:47:56.536 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:47:56.670 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:47:56.934 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:47:59.246 [update notice] received unknown MS cmd: 7108b5120e11bf01bb01b001ed010ca1050000 / 020232
2022-10-29 19:47:59.999 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:48:03.434 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:48:05.817 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:48:05.897 [update notice] received unknown MS cmd: 1008b5110101 / 0937370080ffff0000ff
2022-10-29 19:48:06.161 [update notice] received unknown MS cmd: 1076b5110101 / 093837fe0cff530000ff
2022-10-29 19:48:06.425 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200c5010cff
2022-10-29 19:48:06.640 [update notice] received unknown BC cmd: 10feb505025c00
2022-10-29 19:48:06.905 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:48:07.129 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:48:07.219 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:48:07.464 [update notice] received unknown MS cmd: 7108b5120e11bf01bb01b101ed010c9e050000 / 020232
2022-10-29 19:48:07.557 [update notice] received unknown MS cmd: 1076b5040100 / 0a0337472029100622fe0c
2022-10-29 19:48:07.797 [update notice] received unknown MS cmd: 1008b507020937 / 02b002
2022-10-29 19:48:08.036 [update notice] received unknown BC cmd: 10feb516080035472029100622
2022-10-29 19:48:08.300 [update notice] received unknown MS cmd: 1008b5110100 / 09bf010c000008000000
2022-10-29 19:48:08.545 [update notice] received unknown MS cmd: 1076b51303040d00 / 020d00
2022-10-29 19:48:08.729 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:48:08.763 [update notice] received unknown BC cmd: 10feb5160301fe0c
2022-10-29 19:48:08.993 [update notice] received unknown MS cmd: 1008b512020000 / 00
2022-10-29 19:48:09.224 [update notice] received unknown MS cmd: 1008b512020464 / 00
2022-10-29 19:48:09.459 [update notice] received unknown MS cmd: 1008b513020528 / 0101
2022-10-29 19:48:09.673 [update notice] received unknown BC cmd: 10feb510020601
2022-10-29 19:48:10.381 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:48:12.258 [update notice] received unknown MS cmd: 7108b51a0304b932 / 0eb907c0cfc07b3c00b01b20000000
2022-10-29 19:48:12.640 [update notice] received unknown MS cmd: 7108b51a0304ba33 / 0eba0000008a000000000000000000
2022-10-29 19:48:13.065 [update notice] received unknown MS cmd: 7108b51a0304bb34 / 0ebbcf2000c0022101001800061800
2022-10-29 19:48:13.447 [update notice] received unknown MS cmd: 7108b51a0304bc35 / 0ebc00000000000100b00100000000
2022-10-29 19:48:13.829 [update notice] received unknown MS cmd: 7108b51a0304bd36 / 0ebd00000000000000000000000000
2022-10-29 19:48:14.318 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:48:15.267 [update notice] received unknown MS cmd: 7108b5120e11bf01bb01b101ec010c9e050000 / 020232
2022-10-29 19:48:15.971 [update notice] received unknown MS cmd: 1008b5110101 / 0937370080ffff0000ff
2022-10-29 19:48:16.236 [update notice] received unknown MS cmd: 1076b5110101 / 093837fe0cff530000ff
2022-10-29 19:48:16.501 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200c5010cff
2022-10-29 19:48:16.766 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:48:17.031 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:48:17.783 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:48:21.218 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:48:23.161 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:48:23.162 [main notice] direct cmd: fffe07fe00
2022-10-29 19:48:23.267 [update notice] received unknown MS cmd: 7108b5120e11be01bb01b101eb010c95050000 / 020232
2022-10-29 19:48:24.679 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:48:26.043 [update notice] received unknown MS cmd: 1008b5110101 / 0937370080ffff0000ff
2022-10-29 19:48:26.308 [update notice] received unknown MS cmd: 1076b5110101 / 093837fe0cff530000ff
2022-10-29 19:48:26.492 [bus error] send to fe: ERR: arbitration lost, retry
2022-10-29 19:48:26.573 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200c5010cff
2022-10-29 19:48:26.838 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:48:27.103 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:48:28.119 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:48:31.161 [bus error] send to fe: ERR: arbitration lost, retry
2022-10-29 19:48:31.266 [update notice] received unknown MS cmd: 7108b5120e11be01bb01b101ea010c9e050000 / 020232
2022-10-29 19:48:31.579 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:48:35.014 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:48:36.114 [update notice] received unknown MS cmd: 1008b5110101 / 0937370080ffff0000ff
2022-10-29 19:48:36.299 [bus error] send to fe: ERR: arbitration lost
2022-10-29 19:48:36.299 [main error] direct: ERR: arbitration lost
2022-10-29 19:48:36.379 [update notice] received unknown MS cmd: 1076b5110101 / 093837fe0cff530000ff
2022-10-29 19:48:36.643 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200c5010cff
2022-10-29 19:48:36.908 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:48:37.172 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:48:38.497 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:48:39.314 [update notice] received unknown MS cmd: 7108b5120e11be01bb01b101ea010cad050000 / 020232
2022-10-29 19:48:41.958 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:48:45.308 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:48:45.392 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:48:46.185 [update notice] received unknown MS cmd: 1008b5110101 / 0937370080ffff0000ff
2022-10-29 19:48:46.453 [update notice] received unknown MS cmd: 1076b5110101 / 093837fe0cff520000ff
2022-10-29 19:48:46.718 [update notice] received unknown MS cmd: 1076b512030f0201 / 07970200c4010cff
2022-10-29 19:48:46.984 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:48:47.248 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:48:47.366 [update notice] received unknown MS cmd: 7108b5120e11be01ba01b101ea010c9e050000 / 020232
2022-10-29 19:48:48.866 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:48:52.301 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:48:55.317 [update notice] received unknown MS cmd: 7108b5120e11be01ba01b101e9010ca5050000 / 020232
2022-10-29 19:48:55.677 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:48:55.762 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:48:56.290 [update notice] received unknown MS cmd: 1008b5110101 / 0937370080ffff0000ff
2022-10-29 19:48:56.559 [update notice] received unknown MS cmd: 1076b5110101 / 093837fe0cff520000ff
2022-10-29 19:48:56.824 [update notice] received unknown MS cmd: 1076b512030f0201 / 07970200c4010cff
2022-10-29 19:48:57.089 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:48:57.354 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:48:59.205 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:49:02.684 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:49:03.325 [update notice] received unknown MS cmd: 7108b5120e11be01ba01b101e8010cb1050000 / 020232
2022-10-29 19:49:06.101 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:49:06.365 [update notice] received unknown MS cmd: 1008b5110101 / 0937370080ffff0000ff
2022-10-29 19:49:06.630 [update notice] received unknown MS cmd: 1076b5110101 / 093837fe0cff530000ff
2022-10-29 19:49:06.815 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:49:06.895 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200c4010cff
2022-10-29 19:49:07.109 [update notice] received unknown BC cmd: 10feb505025c00
2022-10-29 19:49:07.374 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:49:07.639 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:49:07.908 [update notice] received unknown MS cmd: 1076b5040100 / 0a0337482029100622fe0c
2022-10-29 19:49:08.148 [update notice] received unknown MS cmd: 1008b507020937 / 02b002
2022-10-29 19:49:08.388 [update notice] received unknown BC cmd: 10feb516080036482029100622
2022-10-29 19:49:08.652 [update notice] received unknown MS cmd: 1008b5110100 / 09be010c000008000000
2022-10-29 19:49:08.896 [update notice] received unknown MS cmd: 1076b51303040d00 / 020d00
2022-10-29 19:49:09.114 [update notice] received unknown BC cmd: 10feb5160301fe0c
2022-10-29 19:49:09.559 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:49:11.343 [update notice] received unknown MS cmd: 7108b5120e11bd01ba01b101e7010c9e050000 / 020232
2022-10-29 19:49:11.528 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:49:11.637 [update notice] received unknown MS cmd: 7108b51a0304c332 / 0ec307c0cfc07b3c00b01b20000000
2022-10-29 19:49:12.063 [update notice] received unknown MS cmd: 7108b51a0304c433 / 0ec40000008a000000000000000000
2022-10-29 19:49:12.444 [update notice] received unknown MS cmd: 7108b51a0304c534 / 0ec5cf2000c0022101001800061800
2022-10-29 19:49:12.870 [update notice] received unknown MS cmd: 7108b51a0304c635 / 0ec600000000000100b00100000000
2022-10-29 19:49:13.252 [update notice] received unknown MS cmd: 7108b51a0304c736 / 0ec700000000000000000000000000
2022-10-29 19:49:13.697 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:49:16.424 [update notice] received unknown MS cmd: 1008b5110101 / 0937370080ffff0000ff
2022-10-29 19:49:16.689 [update notice] received unknown MS cmd: 1076b5110101 / 093837fe0cff530000ff
2022-10-29 19:49:16.873 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:49:16.954 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200c4010cff
2022-10-29 19:49:17.179 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:49:17.268 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:49:17.533 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:49:19.361 [update notice] received unknown MS cmd: 7108b5120e11bd01ba01b101e6010ca1050000 / 020232
2022-10-29 19:49:20.641 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:49:24.076 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:49:26.495 [update notice] received unknown MS cmd: 1008b5110101 / 0937370080ffff0000ff
2022-10-29 19:49:26.764 [update notice] received unknown MS cmd: 1076b5110101 / 093837fe0cff520000ff
2022-10-29 19:49:27.029 [update notice] received unknown MS cmd: 1076b512030f0201 / 07970200c3010cff
2022-10-29 19:49:27.213 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:49:27.294 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:49:27.408 [update notice] received unknown MS cmd: 7108b5120e11bd01b901b101e6010c9f050000 / 020232
2022-10-29 19:49:27.629 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:49:27.722 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:49:30.980 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:49:34.459 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:49:35.364 [update notice] received unknown MS cmd: 7108b5120e11bd01b901b201e6010cb1050000 / 020232
2022-10-29 19:49:36.472 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:49:36.553 [update notice] received unknown MS cmd: 1008b5110101 / 0937370080ffff0000ff
2022-10-29 19:49:36.818 [update notice] received unknown MS cmd: 1076b5110101 / 093837fe0cff530000ff
2022-10-29 19:49:37.083 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200c3010cff
2022-10-29 19:49:37.348 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:49:37.613 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:49:37.882 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:49:41.361 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:49:43.409 [update notice] received unknown MS cmd: 7108b5120e11bd01b901b201e5010ca8050000 / 020232
2022-10-29 19:49:44.821 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:49:46.589 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:49:46.669 [update notice] received unknown MS cmd: 1008b5110101 / 0937370080ffff0000ff
2022-10-29 19:49:46.934 [update notice] received unknown MS cmd: 1076b5110101 / 093837fe0cff530000ff
2022-10-29 19:49:47.199 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200c3010cff
2022-10-29 19:49:47.464 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:49:47.729 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:49:48.261 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:49:51.409 [update notice] received unknown MS cmd: 7108b5120e11bc01b801b201e4010c9e050000 / 020232
2022-10-29 19:49:51.722 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:49:55.157 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:49:56.740 [update notice] received unknown MS cmd: 1008b5110101 / 0937370080ffff0000ff
2022-10-29 19:49:57.009 [update notice] received unknown MS cmd: 1076b5110101 / 093837fe0cff520000ff
2022-10-29 19:49:57.194 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:49:57.274 [update notice] received unknown MS cmd: 1076b512030f0201 / 07970200c3010cff
2022-10-29 19:49:57.540 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:49:57.804 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:49:58.600 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:49:59.418 [update notice] received unknown MS cmd: 7108b5120e11bb01b801b201e3010cb1050000 / 020232
2022-10-29 19:50:02.061 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:50:05.540 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:50:06.736 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:50:06.816 [update notice] received unknown MS cmd: 1008b5110101 / 0937370080ffff0000ff
2022-10-29 19:50:07.085 [update notice] received unknown MS cmd: 1076b5110101 / 093837fe0cff520000ff
2022-10-29 19:50:07.349 [update notice] received unknown MS cmd: 1076b512030f0201 / 07970200c2010cff
2022-10-29 19:50:07.463 [update notice] received unknown MS cmd: 7108b5120e11bb01b801b201e3010cb1050000 / 020232
2022-10-29 19:50:07.634 [update notice] received unknown BC cmd: 10feb505025c00
2022-10-29 19:50:07.899 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:50:08.164 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:50:08.432 [update notice] received unknown MS cmd: 1076b5040100 / 0a0338492029100622fe0c
2022-10-29 19:50:08.671 [update notice] received unknown MS cmd: 1008b507020937 / 02b002
2022-10-29 19:50:08.911 [update notice] received unknown BC cmd: 10feb516080036492029100622
2022-10-29 19:50:09.004 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:50:09.224 [update notice] received unknown MS cmd: 1008b5110100 / 09bb010c000008000000
2022-10-29 19:50:09.409 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:50:09.468 [update notice] received unknown MS cmd: 1076b51303040d00 / 020d00
2022-10-29 19:50:09.686 [update notice] received unknown BC cmd: 10feb5160301fe0c
2022-10-29 19:50:10.683 [update notice] received unknown MS cmd: 7108b51a0304cd32 / 0ecd07c0cfc07b3c00b01b20000000
2022-10-29 19:50:11.065 [update notice] received unknown MS cmd: 7108b51a0304ce33 / 0ece0000008a000000000000000000
2022-10-29 19:50:11.447 [update notice] received unknown MS cmd: 7108b51a0304cf34 / 0ecfcf2000c0022101001800061800
2022-10-29 19:50:11.873 [update notice] received unknown MS cmd: 7108b51a0304d035 / 0ed000000000000100b00100000000
2022-10-29 19:50:12.254 [update notice] received unknown MS cmd: 7108b51a0304d136 / 0ed100000000000000000000000000
2022-10-29 19:50:12.743 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:50:15.451 [update notice] received unknown MS cmd: 7108b5120e11bb01b801b201e2010c9e050000 / 020232
2022-10-29 19:50:16.160 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:50:16.864 [update notice] received unknown MS cmd: 1008b5110101 / 0937370080ffff0000ff
2022-10-29 19:50:17.129 [update notice] received unknown MS cmd: 1076b5110101 / 093837fe0cff530000ff
2022-10-29 19:50:17.394 [update notice] received unknown MS cmd: 1076b512030f0201 / 07980200c2010cff
2022-10-29 19:50:17.659 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:50:17.924 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:50:19.645 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:50:22.995 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:50:23.080 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:50:23.457 [update notice] received unknown MS cmd: 7108b5120e11bb01b701b201e2010cb1050000 / 020232
2022-10-29 19:50:26.540 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:50:26.937 [update notice] received unknown MS cmd: 1008b5110101 / 0937360080ffff0000ff
2022-10-29 19:50:27.201 [update notice] received unknown MS cmd: 1076b5110101 / 093836fe0cff520000ff
2022-10-29 19:50:27.385 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:50:27.465 [update notice] received unknown MS cmd: 1076b512030f0201 / 07970200c2010cff
2022-10-29 19:50:27.731 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:50:27.995 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:50:29.979 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:50:31.456 [update notice] received unknown MS cmd: 7108b5120e11bb01b701b201e1010c9e050000 / 020232
2022-10-29 19:50:33.440 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:50:36.834 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:50:36.918 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:50:37.051 [update notice] received unknown MS cmd: 1008b5110101 / 0937360080ffff0000ff
2022-10-29 19:50:37.316 [update notice] received unknown MS cmd: 1076b5110101 / 093836fe0cff520000ff
2022-10-29 19:50:37.580 [update notice] received unknown MS cmd: 1076b512030f0201 / 07970200c1010cff
2022-10-29 19:50:37.845 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:50:38.109 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:50:39.498 [update notice] received unknown MS cmd: 7108b5120e11bb01b701b101e1010ca0050000 / 020232
2022-10-29 19:50:40.339 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:50:43.818 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:50:47.116 [update notice] received unknown MS cmd: 1008b5110101 / 0937360080ffff0000ff
2022-10-29 19:50:47.254 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:50:47.430 [update notice] received unknown MS cmd: 1076b5110101 / 093836fe0cff520000ff
2022-10-29 19:50:47.483 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:50:47.588 [update notice] received unknown MS cmd: 7108b5120e11ba01b701b101e0010c9e050000 / 020232
2022-10-29 19:50:47.765 [update notice] received unknown MS cmd: 1076b512030f0201 / 07970200c1010cff
2022-10-29 19:50:48.030 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:50:48.295 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:50:50.423 [update notice] received unknown MS cmd: 7108b509022802 / 0c020005165f0100484d553031
2022-10-29 19:50:50.735 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:50:54.170 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:50:55.410 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:50:55.515 [update notice] received unknown MS cmd: 7108b5120e11ba01b701b101e0010c9e050000 / 020232
2022-10-29 19:50:57.187 [update notice] received unknown MS cmd: 1008b5110101 / 0937360080ffff0000ff
2022-10-29 19:50:57.452 [update notice] received unknown MS cmd: 1076b5110101 / 093836fe0cff520000ff
2022-10-29 19:50:57.633 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:50:57.766 [update notice] received unknown MS cmd: 1076b512030f0201 / 07970200c1010cff
2022-10-29 19:50:58.031 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:50:58.215 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:50:58.296 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:51:01.071 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:51:03.519 [update notice] received unknown MS cmd: 7108b5120e11ba01b701b101df010caa050000 / 020232
2022-10-29 19:51:04.535 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:51:07.262 [update notice] received unknown MS cmd: 1008b5110101 / 0937360080ffff0000ff
2022-10-29 19:51:07.528 [update notice] received unknown MS cmd: 1076b5110101 / 093836fe0cff520000ff
2022-10-29 19:51:07.793 [update notice] received unknown MS cmd: 1076b512030f0201 / 07970200c0010cff
2022-10-29 19:51:07.889 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:51:07.973 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:51:08.055 [update notice] received unknown BC cmd: 10feb505025c00
2022-10-29 19:51:08.320 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:51:08.585 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:51:08.854 [update notice] received unknown MS cmd: 1076b5040100 / 0a0338502029100622fe0c
2022-10-29 19:51:09.093 [update notice] received unknown MS cmd: 1008b507020937 / 02b002
2022-10-29 19:51:09.333 [update notice] received unknown BC cmd: 10feb516080036502029100622
2022-10-29 19:51:09.597 [update notice] received unknown MS cmd: 1008b5110100 / 09ba010c000008000000
2022-10-29 19:51:09.841 [update notice] received unknown MS cmd: 1076b51303040d00 / 020d00
2022-10-29 19:51:10.059 [update notice] received unknown BC cmd: 10feb5160301fe0c
2022-10-29 19:51:10.396 [update notice] received unknown MS cmd: 7108b51a0304d732 / 0ed707c0cfc07b3c00b01b20000000
2022-10-29 19:51:10.778 [update notice] received unknown MS cmd: 7108b51a0304d833 / 0ed80000008a000000000000000000
2022-10-29 19:51:11.051 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:51:11.160 [update notice] received unknown MS cmd: 7108b51a0304d934 / 0ed9cf2000c0022101001800061800
2022-10-29 19:51:11.537 [update notice] received unknown MS cmd: 7108b5120e11ba01b601b101df010ca0050000 / 020232
2022-10-29 19:51:11.831 [update notice] received unknown MS cmd: 7108b51a0304da35 / 0eda00000000000100b00100000000
2022-10-29 19:51:12.257 [update notice] received unknown MS cmd: 7108b51a0304db36 / 0edb00000000000000000000000000
2022-10-29 19:51:12.746 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:51:16.181 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:51:17.325 [update notice] received unknown MS cmd: 1008b5110101 / 0937360080ffff0000ff
2022-10-29 19:51:17.589 [update notice] received unknown MS cmd: 1076b5110101 / 093836fe0cff520000ff
2022-10-29 19:51:17.774 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:51:17.855 [update notice] received unknown MS cmd: 1076b512030f0201 / 07970200c0010cff
2022-10-29 19:51:18.120 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:51:18.384 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:51:19.553 [update notice] received unknown MS cmd: 7108b5120e11ba01b601b101de010cb1050000 / 020232
2022-10-29 19:51:19.822 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:51:23.081 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:51:26.560 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:51:27.396 [update notice] received unknown MS cmd: 1008b5110101 / 0937360080ffff0000ff
2022-10-29 19:51:27.554 [update notice] received unknown MS cmd: 7108b5120e11b901b601b101dd010cbe050000 / 020232
2022-10-29 19:51:27.651 [main error] scan config 08: ERR: arbitration lost
2022-10-29 19:51:27.731 [update notice] received unknown MS cmd: 1076b5110101 / 093736fe0cff530000ff
2022-10-29 19:51:27.996 [update notice] received unknown MS cmd: 1076b512030f0201 / 07970200bf010cff
2022-10-29 19:51:28.261 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:51:28.526 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:51:29.982 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:51:33.460 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:51:35.597 [update notice] received unknown MS cmd: 7108b5120e11b901b601b101dd010c9e050000 / 020232
2022-10-29 19:51:36.837 [main error] scan config 15: ERR: arbitration lost
2022-10-29 19:51:36.921 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:51:37.493 [update notice] received unknown MS cmd: 1008b5110101 / 0937360080ffff0000ff
2022-10-29 19:51:37.758 [update notice] received unknown MS cmd: 1076b5110101 / 093736fe0cff520000ff
2022-10-29 19:51:38.022 [update notice] received unknown MS cmd: 1076b512030f0201 / 07970200bf010cff
2022-10-29 19:51:38.288 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101
2022-10-29 19:51:38.552 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:51:40.360 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:51:43.595 [update notice] received unknown MS cmd: 7108b5120e11b801b601b101dd010c9e050000 / 020232
2022-10-29 19:51:43.865 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:51:47.171 [main error] scan config 76: ERR: arbitration lost
2022-10-29 19:51:47.255 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:51:47.564 [update notice] received unknown MS cmd: 1008b5110101 / 0937360080ffff0000ff
2022-10-29 19:51:47.829 [update notice] received unknown MS cmd: 1076b5110101 / 093736fe0cff520000ff
2022-10-29 19:51:48.094 [update notice] received unknown MS cmd: 1076b512030f0201 / 07970200bf010cff
2022-10-29 19:51:48.359 [update notice] received unknown MS cmd: 1008b51009000037ffffff060000 / 0101a
2022-10-29 19:51:48.624 [update notice] received unknown MS cmd: 1076b51009000000ffffff050000 / 0101
2022-10-29 19:51:50.696 [update notice] received unknown MS cmd: 7108b5110107 / 0a00d80081082400000000
2022-10-29 19:51:51.601 [update notice] received unknown MS cmd: 7108b5120e11b801b501b101dc010ca5050000 / 020232
but in the log of ebusd much less errors. But why VRC700 isn’t detected ? Maybe any Vaillant configuration for ebusd is necessary ?
The openhab config files are separate from ebusd.
For some reason the ID of your VRC700 is not being picked up and that is the only thing triggering recognition. So the only way is manually adding the VRC700 things, I am afraid. It is a little more work, but if it works, it works.
Slave address is 15, that is the only thing you need. Polling interval, might not be required as a lot of data appears to be going over the bus already. If receiving no data at all, set polling to your need (how much updates do you need for a value).
any chance ? question to ebusd producer or it’s openhab problem ?
this isn’t clear for me :
there is a lot of devices, no one with adress 15
Every device has a master and a slave address. Usually when sending a device uses its master address and sends a command or request to a slave address. On ebus the master address is 5 lower rthan the slave, so slave 15 has master 10 (which is present in the list). That you don’t see a slave 15, probably only means that nothing was sent to slave 15 and so that address has not been seen yet.
When you fill slave address 15, openhab binding automatically assumes master 10. And I notice a lot of communication from master 10 in your log.
I really have no clue…
problem is that I added several VRC700:
and added aprox 8items, and for all value is NULL
so it’s not working at all. But number of received telegrams is still increasing
still thinking what’s wrong and how to improve to get correct working. Is direct connection to gpio a solution? Is adapter ok? …
But did you set polling in the items?
yes, 10 in each
maybe slave 15 isn’t right address ? only outside temperature is working. Mabye external temp sensor on this address ?
today I reconnected to GPIO of the odroid, but I think setup must be complete different
I used pin 1 and 6 for power and 11 and 13 for RX/TX
not sure what else now must be changed and if UART0 is running
but
sudo dmesg | grep -i tty
shows me
root@DietPi:~# sudo dmesg | grep -i tty
[ 0.000000] Kernel command line: root=UUID=81343031-b96f-416b-969a-d8561349d3 e4 rootfstype=ext4 rootwait console=ttyAML0,115200 console=tty1 loglevel=4 conso leblank=0 coherent_pool=2M ubootpart=aa7c7b94-01 libata.force=noncq usb-storage. quirks=0x2537:0x1066:u,0x2537:0x1068:u net.ifnames=0
[ 0.000300] printk: console [tty1] enabled
[ 1.759321] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
[ 1.784821] printk: console [ttyAML0] enabled
Did you read this wiki for the oDroid?
https://wiki.odroid.com/odroid-n2/application_note/gpio/uart
UART must be enabled during boot.
