Nello.IO is a pretty nifty device that adds remote capabilities to your old in-building intercom. In lieu of writing a full binding I built a small MQTT bridge that allows you to buzz people in using a MQTT message.
By simply running this bridge in a Docker container and using the OpenHAB MQTT binding you can buzz people in.
I tried it today.
But I´ve problem, docker container is always restarting.
Log
2018-01-07T10:02:04.859555090Z Traceback (most recent call last):
2018-01-07T10:02:04.859603991Z File "nello.py", line 41, in <module>
2018-01-07T10:02:04.859609192Z client.connect(os.environ['MQTT_BROKER'], port, 60)
2018-01-07T10:02:04.859612592Z File "/usr/local/lib/python2.7/site-packages/paho/mqtt/client.py", line 768, in connect
2018-01-07T10:02:04.859618292Z return self.reconnect()
2018-01-07T10:02:04.859621492Z File "/usr/local/lib/python2.7/site-packages/paho/mqtt/client.py", line 895, in reconnect
2018-01-07T10:02:04.859725496Z sock = socket.create_connection((self._host, self._port), source_address=(self._bind_address, 0))
2018-01-07T10:02:04.859736996Z File "/usr/local/lib/python2.7/socket.py", line 557, in create_connection
2018-01-07T10:02:04.859783397Z for res in getaddrinfo(host, port, 0, SOCK_STREAM):
2018-01-07T10:02:04.859789398Z socket.gaierror: [Errno -2] Name or service not known
2018-01-07T10:02:09.114746167Z Traceback (most recent call last):
2018-01-07T10:02:09.114781969Z File "nello.py", line 41, in <module>
2018-01-07T10:02:09.114786469Z client.connect(os.environ['MQTT_BROKER'], port, 60)
2018-01-07T10:02:09.114789569Z File "/usr/local/lib/python2.7/site-packages/paho/mqtt/client.py", line 768, in connect
2018-01-07T10:02:09.114795269Z return self.reconnect()
2018-01-07T10:02:09.114798369Z File "/usr/local/lib/python2.7/site-packages/paho/mqtt/client.py", line 895, in reconnect
2018-01-07T10:02:09.114904173Z sock = socket.create_connection((self._host, self._port), source_address=(self._bind_address, 0))
2018-01-07T10:02:09.114917173Z File "/usr/local/lib/python2.7/socket.py", line 557, in create_connection
2018-01-07T10:02:09.114956174Z for res in getaddrinfo(host, port, 0, SOCK_STREAM):
2018-01-07T10:02:09.114988675Z socket.gaierror: [Errno -2] Name or service not known
That looks like it can’t connect to your mqtt broker. Do you have one set up? Otherwise you can get one up by simply docker run --restart=always --name mosquitto -t -d -p 1883:1883 -p 9001:9001 eclipse-mosquitto. Then set MQTT_BROKER to the IP of your machine, localhost should also work.
I am also trying to use this binding but I’m not successful. The container is always restarting
(seems the underlying pynello has some problems with unicode characters).
File "nello.py", line 43, in <module>
client.loop_forever()
File "/usr/local/lib/python2.7/site-packages/paho/mqtt/client.py", line 1481, in loop_forever
rc = self.loop(timeout, max_packets)
File "/usr/local/lib/python2.7/site-packages/paho/mqtt/client.py", line 1003, in loop
rc = self.loop_read(max_packets)
File "/usr/local/lib/python2.7/site-packages/paho/mqtt/client.py", line 1284, in loop_read
rc = self._packet_read()
File "/usr/local/lib/python2.7/site-packages/paho/mqtt/client.py", line 1849, in _packet_read
rc = self._packet_handle()
File "/usr/local/lib/python2.7/site-packages/paho/mqtt/client.py", line 2311, in _packet_handle
return self._handle_connack()
File "/usr/local/lib/python2.7/site-packages/paho/mqtt/client.py", line 2372, in _handle_connack
self.on_connect(self, self._userdata, flags_dict, result)
File "nello.py", line 12, in on_connect
data = { "type": "location", "location_id": location.location_id, "address": location.address }
File "/usr/local/lib/python2.7/site-packages/pynello/nello.py", line 115, in address
country)
UnicodeEncodeError: 'ascii' codec can't encode character u'\xdf' in position 13: ordinal not in range(128)
Connected to MQTT with result code 0
{"location_id": "redacted-752b-4dea-9c6d-redactedfbb4", "type": "location", "address": "redactedStr 123a 12345 Entenhausen, Deutschland"}
Someone knows what to do?
Also are there any plans to implement the new API?
Hi =) I have a Nello here and would be interessted in a solution to see if someone rings and where I can buzz people in =). Did someone make A binding therefore? =)
