Yehuda
(Yehuda)
March 30, 2020, 9:50pm
1
I have 2 Neo coolcam NAS-DS01Z sensors working for months on my OH system.
They installed while I run Ver 2.4
I upgrade OH to 2.5 few weeks a go and now I try to add another new 3 sensors to my system.
All the 3 binding into my Z-wave network and recognize well but all of them can not trigger any notification either the sensor or the battery level.
I saw such issues happens to many others and I wonder if someone can advise what I should try to fix this problem.
Thanks,
Yehuda
When you upgraded, did you delete the openHAB cache? Sometimes restarting openHAB up to 3 times helps.
For Z-Wave devices it is recommended to delete (NOT disassociate) and re-discover devices to get the latest binding settings. Be sure to wake up any battery devices until they are fully discovered by the binding.
Failing that, post debug logs as instructed in the binding documentation.
Yehuda
(Yehuda)
March 30, 2020, 10:27pm
5
non of this help. I clear the cache and tmp, re-discover the sensor but still not working
Which log I should post for debug?
Thanks,
Yehuda.
When things do not go as planned. In the documentation like I said earlier.
Yehuda
(Yehuda)
March 30, 2020, 10:38pm
7
Try to put the suggested command, got the following:
log:set DEBUG org.openhab.binding.zwave
-bash: log:set: command not found
Yehuda
(Yehuda)
March 30, 2020, 10:49pm
9
How this help me? still get the error
I think I will go on downgrade to 2.4 which was stable and work fine for me.
Could you point me the which 2.4 version I should downgrade?
downgrading to 2.4
will not help you and the developer has already said he cannot support the 2.4
z-wave binding due to all the many changes since then. Search and read the fine documentation to learn.
We are here to help you learn your system. We are not a HelpDesk handing our ready made solutions.
How to ask a good question / Help Us Help You - Tutorials & Examples - openHAB Community
Yehuda
(Yehuda)
March 30, 2020, 11:07pm
11
Please try help me get the debug log.
I am not familiar with command line and has no clue why I got this error.
Welcome to __ _____ ____ _
____ ____ ___ ____ / / / / | / __ )(_)___ _____
/ __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __ / / __ `/ __ \
/ /_/ / /_/ / __/ / / / __ / ___ |/ /_/ / / /_/ / / / /
\____/ .___/\___/_/ /_/_/ /_/_/ |_/_____/_/\__,_/_/ /_/
/_/
openHAB 2.5.2-1 (Release Build)
Looking for a place to get started? Check out ‘sudo openhabian-config’ and the
documentation at https://www.openhab.org/docs/installation/openhabian.html
The openHAB dashboard can be reached at http://openhab:8080
To interact with openHAB on the command line, execute: ‘openhab-cli --help’
[01:54:15] openhabian@openhab:~$ log:set debug org.openhab.binding.zwave
Yehuda
(Yehuda)
March 31, 2020, 7:12pm
12
Hi Bruce,
Just want ot update that I downgrade back to 2.4 and now the new sensors are just binding well and can notify the sensor position and the battery level,
I would guess that the problem are related to 2.5 version and not to the new sensors that I added.
I will keep use 2.4 as long I not required to upgrade.
Thanks for your help
cris
(Cris)
May 3, 2020, 8:46am
13
It can take a long time for updating the battery level. You can force it by pressing the button in the device. Maybe repeatedly, with some pause between (30 seconds or so).
Yehuda
(Yehuda)
May 3, 2020, 10:10am
14
I found that installing the sensor binding at ver 2.4 than upgrade to 2.5 work well for me
I guess the issue is with the 2.5 sensor binding
HarryD
(Harry Deic)
May 3, 2020, 6:52pm
15
Device is working on my side.
Make sure item sensor_door is defined as contact and not as switch.
I made that mistake by myself, if defined wrongly the status remains at Null …
best regards Harry
Yehuda
(Yehuda)
May 4, 2020, 4:45pm
16
also work fine for me, but with binding form ver 2.4
Yehuda
Yehuda:
Why not update to 2.5? Staying behind will only get more painful when OH3 is released.
Derekj
(Derekj)
May 6, 2020, 5:02am
18
I’m having the same problem. I just received this sensor today so it has never worked correctly. Running OH 2.5. Ran debug (grep’d to NODE 10 which is this device.) i see that it says Manufacturer data not known and that the Node XML isn’t created, which i confirm the file isn’t there on the file system. I’ve tried to wake up the device repeatedly using the directions on the Thing description page found here . I’m sure that i’m pasting these logs wrong… sorry in advance. Any and all help is appreciated thank you!
[23:52:11] openhabian@openHABianPi:~$ less /var/log/openhab2/openhab.log | grep "NODE 10"
2020-05-05 22:06:31.400 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 10: Device discovery could not resolve to a thingType! Manufacturer data not known.
2020-05-05 23:18:39.774 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 10: Device discovery could not resolve to a thingType! Manufacturer data not known.
2020-05-05 23:36:52.209 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Handler disposed. Unregistering listener.
2020-05-05 23:36:52.243 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 10: Serialise aborted as static stages not complete
2020-05-05 23:36:52.690 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 10: Node Init transaction completed with response null
2020-05-05 23:36:52.692 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 10: Skipping initialization thread, process stopped by controller
2020-05-05 23:38:09.064 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Channel zwave:device:19f9c0a5:node10:sensor_binary linked - polling started.
2020-05-05 23:38:09.064 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Channel zwave:device:19f9c0a5:node10:alarm_tamper linked - polling started.
2020-05-05 23:38:09.068 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Channel zwave:device:19f9c0a5:node10:sensor_door linked - polling started.
2020-05-05 23:38:09.068 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Channel zwave:device:19f9c0a5:node10:battery-level linked - polling started.
2020-05-05 23:38:17.502 [DEBUG] [age.SerialApiGetInitDataMessageClass] - NODE 10: Node found
2020-05-05 23:38:17.562 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 10: Init node thread start
2020-05-05 23:38:17.941 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 10: Serializing from file /var/lib/openhab2/zwave/network_d3dc1078__node_10.xml
2020-05-05 23:38:17.956 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 10: Error serializing from file: file does not exist.
2020-05-05 23:38:18.002 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 10: Starting initialisation from EMPTYNODE
2020-05-05 23:38:18.034 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 10: Init node thread finished
2020-05-05 23:38:18.037 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 10: Node advancer - advancing to IDENTIFY_NODE
2020-05-05 23:38:18.054 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 10: Node advancer: Initialisation starting
2020-05-05 23:38:18.379 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 10: ProtocolInfo
2020-05-05 23:38:18.381 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 10: Listening = false
2020-05-05 23:38:18.383 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 10: Routing = true
2020-05-05 23:38:18.386 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 10: Beaming = true
2020-05-05 23:38:18.388 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 10: Version = 4
2020-05-05 23:38:18.390 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 10: FLIRS = false
2020-05-05 23:38:18.392 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 10: Security = false
2020-05-05 23:38:18.395 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 10: Max Baud = 40000
2020-05-05 23:38:18.397 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 10: Basic = BASIC_TYPE_ROUTING_SLAVE
2020-05-05 23:38:18.399 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 10: Generic = GENERIC_TYPE_SENSOR_NOTIFICATION
2020-05-05 23:38:18.401 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 10: Specific = SPECIFIC_TYPE_NOTIFICATION_SENSOR
2020-05-05 23:38:18.403 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 10: Creating new instance of command class COMMAND_CLASS_NO_OPERATION
2020-05-05 23:38:18.406 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 10: Command class COMMAND_CLASS_NO_OPERATION, endpoint 0 created
2020-05-05 23:38:18.408 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 10: Version = 1, version set. Enabling extra functionality.
2020-05-05 23:38:18.411 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: Adding command class COMMAND_CLASS_NO_OPERATION to the list of supported command classes.
2020-05-05 23:38:18.413 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 10: Creating new instance of command class COMMAND_CLASS_BASIC
2020-05-05 23:38:18.415 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 10: Command class COMMAND_CLASS_BASIC, endpoint 0 created
2020-05-05 23:38:18.418 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: Adding command class COMMAND_CLASS_BASIC to the list of supported command classes.
2020-05-05 23:38:18.433 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 10: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@16c181f
2020-05-05 23:38:18.435 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 10: Node Init transaction completed with response COMPLETE
2020-05-05 23:38:18.436 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 10: Node advancer - advancing to REQUEST_NIF
2020-05-05 23:38:18.438 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: sendTransaction org.openhab.binding.zwave.internal.protocol.ZWaveSerialPayload@6e8496
2020-05-05 23:38:18.440 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Bump transaction 13 priority from Controller to Immediate
2020-05-05 23:38:18.447 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Adding to device queue
2020-05-05 23:38:18.448 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Added 13 to queue - size 3
2020-05-05 23:38:23.420 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Controller status changed to ONLINE.
2020-05-05 23:38:23.422 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Controller is ONLINE. Starting device initialisation.
2020-05-05 23:38:23.430 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Updating node properties.
2020-05-05 23:38:23.433 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Updating node properties. MAN=2147483647
2020-05-05 23:38:23.438 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Properties synchronised
2020-05-05 23:38:23.442 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising Thing Node...
2020-05-05 23:38:23.446 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:19f9c0a5:node10:sensor_binary for OnOffType
2020-05-05 23:38:23.448 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising state channel zwave:device:19f9c0a5:node10:sensor_binary for OnOffType
2020-05-05 23:38:23.461 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:19f9c0a5:node10:alarm_tamper for OnOffType
2020-05-05 23:38:23.463 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising state channel zwave:device:19f9c0a5:node10:alarm_tamper for OnOffType
2020-05-05 23:38:23.470 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:19f9c0a5:node10:sensor_door for OpenClosedType
2020-05-05 23:38:23.472 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising state channel zwave:device:19f9c0a5:node10:sensor_door for OpenClosedType
2020-05-05 23:38:23.479 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:19f9c0a5:node10:battery-level for PercentType
2020-05-05 23:38:23.483 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising state channel zwave:device:19f9c0a5:node10:battery-level for PercentType
2020-05-05 23:38:23.487 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Polling initialised at 86400 seconds - start in 33696000 milliseconds.
2020-05-05 23:38:23.489 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Device initialisation complete.
Yehuda
(Yehuda)
May 6, 2020, 6:34am
19
try downgrade to 2.4, binding the sensor, upgrade to 2.5.
It works for me.
Yehuda
(Yehuda)
May 6, 2020, 6:35am
20
I am running OH 2.5.
I just downgrade to 2.4 in order to install the sensor binding, than upgrade back to 2.5
