Hi Guys,
I also aquired some of the new Neo Coolcam wall plugs with the new device ID. (type/ID 0200:1027). With the latest z-wave binding all the basic functionality works okay. I have however 2 issues:
- KWH usage sometimes reports a large negative number and some hours later it switches back:
PWR_SW_TVLR_KWH changed from -21474834.58 to -21474834.57
2019-02-11 22:24:55.621 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-02-11 22:24:55.621 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DYNAMIC_VALUES)
2019-02-11 22:24:55.621 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_METER, endpoint 0
2019-02-11 22:24:55.621 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2019-02-11 22:24:55.622 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_METER V3 METER_REPORT
2019-02-11 22:24:55.622 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 3: Meter: Type=Electric(1), Scale=kWh(0), Value=-21474766.37
2019-02-11 22:24:55.622 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveMeterValueEvent
2019-02-11 22:24:55.622 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_METER, value = -21474766.37
2019-02-11 22:24:55.623 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:cda3604b:node3:meter_kwh to -21474766.37 [DecimalType]
2019-02-11 22:24:55.623 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2019-02-11 22:24:55.623 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@344a62a6.
2019-02-11 22:24:55.623 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@344a62a6.
2019-02-11 22:24:55.623 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: notifyTransactionResponse TID:184 DONE
2019-02-11 22:24:55.624 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
Looks a bit like an singed/unsigned issue.
Did anyone experience this, and have any clue on how to fix it?
The other issue I encountered that the switches do not seem to react to any configuration parameter I send. Tried to switch of the lights, tried to disable the on/off button. All is ignored.
Did anyone encounter/experience this?
