Hi, the device works for me now. With the “including” there were problems at the beginning. The device always appeared as an “unkown device”. It was finally recognized with a new node number, everything works so well. Here is the node.xml: network_ee7b3ad4__node_9.xml (13.9 KB). I’m on the latest z-wave snapshot binding.
I tested it with my device, and I see the new clear kwh channel. However I am still not able to change the configuration values. It seems that there is a real difference between the manual and the real device.
Both should work fine with a Number item linked to the sensor_temperature channel.
Make sure you have the correct settings for your temperature reading interval.
I have the same sensor, but it does not appear to support temperature. The channel is never updated and it’s not mentioned in the manual I have either. Everything else works as expected.
Does your manual mention PIR2? For ref, mine doesn’t - I’m wondering if you’ve been sent the wrong device. i.e. a PIR1 device with a PIR2 manual? You may be able to return it if you bought the PIR2?
Looking at my manual again and i find that you are absolutely right. It was the promotional wording on Aliexpress seller that stated that it was a PIR 2. The manual is generic. But my does physically look at the “golf ball” PIR 2, with the simple magnetic attachment.
These Neo Cam PIR´s are a mess. I have seen three different versions, and none of them seems to have a manual which relate to the actual device…
Look at this manual:
This version does not have temperature sensor (according to the manual), but it has a light/lux sensor.
I have seen the very same PIR (golf ball alike) and that one had a temperature sensor.
My Neo Coolcam sensor (the round one not looking golf ball alike) is detected with a temperature sensor from openhab. But it doesnt have one. It has a light/lux sensor. But it´s manual claim it does have a temperature sensor, and not the light/lux sensor…
No wonder if these PIR´s are beeing mixed up in the z-wave database. Sheshen (company of Neo Coolcam) hasn´t done a great job descriping their real features.
one last thing regarding the v2.32 Wall Plug…
Measuring the kilowatt hours still behaves a little strange for me. The values always jump between a normal, plausible value and a large negative value. However, I think this is a bug in the firmware.
2019-03-05 02:38:14.916 [vent.ItemStateChangedEvent] - Socket_Bedroom_Desk_Kwh changed from 2.87 to 2.89
2019-03-05 04:18:15.250 [vent.ItemStateChangedEvent] - Socket_Bedroom_Desk_Kwh changed from 2.89 to 2.91
2019-03-05 05:53:14.585 [vent.ItemStateChangedEvent] - Socket_Bedroom_Desk_Kwh changed from 2.91 to 2.93
2019-03-05 07:28:15.007 [vent.ItemStateChangedEvent] - Socket_Bedroom_Desk_Kwh changed from 2.93 to -21474833.53
2019-03-05 09:03:14.348 [vent.ItemStateChangedEvent] - Socket_Bedroom_Desk_Kwh changed from -21474833.53 to -21474833.51
2019-03-05 10:33:14.745 [vent.ItemStateChangedEvent] - Socket_Bedroom_Desk_Kwh changed from -21474833.51 to -21474833.49
2019-03-05 12:08:14.078 [vent.ItemStateChangedEvent] - Socket_Bedroom_Desk_Kwh changed from -21474833.49 to -21474833.47
2019-03-05 13:43:14.382 [vent.ItemStateChangedEvent] - Socket_Bedroom_Desk_Kwh changed from -21474833.47 to -21474833.45
2019-03-05 15:18:14.680 [vent.ItemStateChangedEvent] - Socket_Bedroom_Desk_Kwh changed from -21474833.45 to -21474833.43
2019-03-05 16:53:13.968 [vent.ItemStateChangedEvent] - Socket_Bedroom_Desk_Kwh changed from -21474833.43 to -21474833.41
2019-03-05 17:38:38.611 [vent.ItemStateChangedEvent] - Socket_Bedroom_Desk_Kwh changed from -21474833.41 to -21474833.4
2019-03-05 17:45:20.563 [vent.ItemStateChangedEvent] - Socket_Bedroom_Desk_Kwh changed from -21474833.4 to -21474833.39
2019-03-05 17:51:28.527 [vent.ItemStateChangedEvent] - Socket_Bedroom_Desk_Kwh changed from -21474833.39 to -21474833.38
2019-03-05 17:58:50.457 [vent.ItemStateChangedEvent] - Socket_Bedroom_Desk_Kwh changed from -21474833.38 to -21474833.37
2019-03-05 18:03:46.435 [vent.ItemStateChangedEvent] - Socket_Bedroom_Desk_Kwh changed from -21474833.37 to -21474833.36
2019-03-05 18:11:44.359 [vent.ItemStateChangedEvent] - Socket_Bedroom_Desk_Kwh changed from -21474833.36 to 3.14
2019-03-05 18:15:16.507 [vent.ItemStateChangedEvent] - Socket_Bedroom_Desk_Kwh changed from 3.14 to 3.15
2019-03-05 18:18:12.321 [vent.ItemStateChangedEvent] - Socket_Bedroom_Desk_Kwh changed from 3.15 to 3.16
2019-03-05 18:19:16.305 [vent.ItemStateChangedEvent] - Socket_Bedroom_Desk_Kwh changed from 3.16 to 3.17
2019-03-05 18:25:36.264 [vent.ItemStateChangedEvent] - Socket_Bedroom_Desk_Kwh changed from 3.17 to -21474833.28
2019-03-05 18:27:28.246 [vent.ItemStateChangedEvent] - Socket_Bedroom_Desk_Kwh changed from -21474833.28 to -21474833.27
2019-03-05 18:30:36.229 [vent.ItemStateChangedEvent] - Socket_Bedroom_Desk_Kwh changed from -21474833.27 to -21474833.26
2019-03-05 18:32:06.226 [vent.ItemStateChangedEvent] - Socket_Bedroom_Desk_Kwh changed from -21474833.26 to -21474833.25
2019-03-05 18:34:32.194 [vent.ItemStateChangedEvent] - Socket_Bedroom_Desk_Kwh changed from -21474833.25 to -21474833.24
