Hello all,
I have updated OH 2.1 to 2.2 and I having problems with Network binding. In my setup, I’m using several MQTT sensor nodes what request their IP by DHCP so, their names are included in my local DNS server. When the host name can be resolved, OH starts correctly but if it can’t OH starts with a errors. Following you can view the log entries:
2018-01-09 10:59:33.811 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.rules'
2018-01-09 10:59:35.046 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'micasa.sitemap'
2018-01-09 10:59:35.506 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'MiCasa.things'
2018-01-09 10:59:35.993 [ERROR] [nding.network.handler.NetworkHandler] - Configuration for hostname is faulty
java.net.UnknownHostException: Sonoffxxxd: unknown error
at java.net.Inet6AddressImpl.lookupAllHostAddr(Native Method) ~[?:?]
at java.net.InetAddress$2.lookupAllHostAddr(InetAddress.java:928) [?:?]
at java.net.InetAddress.getAddressesFromNameService(InetAddress.java:1323) [?:?]
at java.net.InetAddress.getAllByName0(InetAddress.java:1276) [?:?]
at java.net.InetAddress.getAllByName(InetAddress.java:1192) [?:?]
at java.net.InetAddress.getAllByName(InetAddress.java:1126) [?:?]
at java.net.InetAddress.getByName(InetAddress.java:1076) [?:?]
at org.openhab.binding.network.internal.PresenceDetection.setHostname(PresenceDetection.java:96) [225:org.openhab.binding.network:2.2.0]
at org.openhab.binding.network.handler.NetworkHandler.initialize(NetworkHandler.java:156) [225:org.openhab.binding.network:2.2.0]
at org.openhab.binding.network.handler.NetworkHandler.initialize(NetworkHandler.java:202) [225:org.openhab.binding.network:2.2.0]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:497) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [109:org.eclipse.smarthome.core:0.10.0.b1]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [109:org.eclipse.smarthome.core:0.10.0.b1]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:?]
at java.lang.Thread.run(Thread.java:745) [?:?]
2018-01-09 10:59:37.551 [INFO ] [b.core.service.AbstractActiveService] - HTTP Refresh Service has been started
Also I’m using text file to configure Things as following:
network:pingdevice:Sonoff
hostname="Sonoffxxxd",
retry=2
In 2.1 version I didn’t experiment this problem and if a host name could not be resolved, Network binding considered that it was offline.
Could anyone help me?
Thanks in advance,
