gdolfen
(Guido Dolfen)
May 1, 2020, 7:48pm
1
I developed a binding for enigma2 devices.
Because this is my first openhab contribution, please give me some hints if there is something missing.
Here is the PR: https://github.com/openhab/openhab-addons/pull/7514
You can download a snapshot-version of the binding here: JFrog
Here you can find the readme: https://github.com/gdolfen/openhab-addons/blob/enigma2/bundles/org.openhab.binding.enigma2/README.md
Greetings
Guido
rlkoshak
(Rich Koshak)
May 1, 2020, 7:52pm
2
I recommend updating the title and tags to make it more clear what this new binding is all about. No one will be able to tell apart 100 postings all named “[New Binding]”. Maybe “New Enigma2 Binding”
gdolfen
(Guido Dolfen)
May 1, 2020, 7:57pm
3
Sorry,I changed the title. Which taggings should I use?
sihui
(SiHui)
May 2, 2020, 6:02am
4
Thank you very much for this great binding
I have tested the snapshot with a Vu+ Duo2 (firmware VTi 14.0.6): everything is working as expected.
I checked all channels, items and rules from your readme, no issues.
Is there any chance to change the duration of the screen messages like in the old openwebif action ?
sendOpenWebIfNotification("main", "Hello World!\n\nThis is a message sent from openHab!", "WARNING", 10)
sihui
(SiHui)
May 2, 2020, 6:05am
5
I would recommend: enigma2, openwebif, dreambox, vu+
sihui
(SiHui)
May 2, 2020, 6:30am
6
Found a workaround:
sending an “EXIT” to the rcButton channel stops the message. In this way it is easy to implement this with a timer in a rule.
Edit:
One more suggestion: I would change the handler messages from INFO to DEBUG as it floods the openhab.log:
2020-05-02 08:23:36.403 [INFO ] [nding.enigma2.handler.Enigma2Handler] - sendRcCommand(MUTE)
2020-05-02 08:23:37.747 [INFO ] [nding.enigma2.handler.Enigma2Handler] - sendRcCommand(KEY_3)
2020-05-02 08:23:42.515 [INFO ] [nding.enigma2.handler.Enigma2Handler] - sendRcCommand(KEY_1)
2020-05-02 08:23:42.811 [INFO ] [nding.enigma2.handler.Enigma2Handler] - sendRcCommand(KEY_2)
2020-05-02 08:23:52.556 [INFO ] [nding.enigma2.handler.Enigma2Handler] - sendRcCommand(KEY_2)
2020-05-02 08:23:53.015 [INFO ] [nding.enigma2.handler.Enigma2Handler] - sendRcCommand(KEY_5)
2020-05-02 08:24:01.140 [INFO ] [nding.enigma2.handler.Enigma2Handler] - sendRcCommand(KEY_1)
2020-05-02 08:24:11.312 [INFO ] [nding.enigma2.handler.Enigma2Handler] - sendRcCommand(UP)
2020-05-02 08:24:15.721 [INFO ] [nding.enigma2.handler.Enigma2Handler] - sendRcCommand(EXIT)
2020-05-02 08:24:18.636 [INFO ] [nding.enigma2.handler.Enigma2Handler] - sendRcCommand(DOWN)
2020-05-02 08:24:22.083 [INFO ] [nding.enigma2.handler.Enigma2Handler] - sendRcCommand(EXIT)
gdolfen
(Guido Dolfen)
May 2, 2020, 12:55pm
7
Thank you for your feedback.
The action now has three additional methods for sending infos, warnings and errors with a custom timeout. I also changed the handler logging to debug level. Can you try it out, please?
sihui
(SiHui)
May 2, 2020, 3:16pm
8
Wow, lightning fast, thanks a lot !
Custom timeout is working and log is not flooded anymore.
Now I can put my old, no longer maintained openwebif action to rest
Good luck for your PR.
sihui
(SiHui)
May 3, 2020, 5:24am
9
Found one little glitch overnight: if the receiver is switched to deep sleep you’ll get this in the log:
2020-05-03 04:31:20.548 [WARN ] [nding.enigma2.internal.Enigma2Client] - Error on transmit http://192.168.2.25/web/powerstate.
2020-05-03 04:31:35.561 [WARN ] [nding.enigma2.internal.Enigma2Client] - Error on transmit http://192.168.2.25/web/powerstate.
2020-05-03 04:31:48.623 [WARN ] [nding.enigma2.internal.Enigma2Client] - Error on transmit http://192.168.2.25/web/powerstate.
2020-05-03 04:32:01.711 [WARN ] [nding.enigma2.internal.Enigma2Client] - Error on transmit http://192.168.2.25/web/powerstate.
2020-05-03 04:32:14.799 [WARN ] [nding.enigma2.internal.Enigma2Client] - Error on transmit http://192.168.2.25/web/powerstate.
2020-05-03 04:32:27.887 [WARN ] [nding.enigma2.internal.Enigma2Client] - Error on transmit http://192.168.2.25/web/powerstate.
2020-05-03 04:32:40.975 [WARN ] [nding.enigma2.internal.Enigma2Client] - Error on transmit http://192.168.2.25/web/powerstate.
2020-05-03 04:32:54.063 [WARN ] [nding.enigma2.internal.Enigma2Client] - Error on transmit http://192.168.2.25/web/powerstate.
2020-05-03 04:33:07.151 [WARN ] [nding.enigma2.internal.Enigma2Client] - Error on transmit http://192.168.2.25/web/powerstate.
2020-05-03 04:33:20.239 [WARN ] [nding.enigma2.internal.Enigma2Client] - Error on transmit http://192.168.2.25/web/powerstate.
2020-05-03 04:33:33.327 [WARN ] [nding.enigma2.internal.Enigma2Client] - Error on transmit http://192.168.2.25/web/powerstate.
2020-05-03 04:33:46.415 [WARN ] [nding.enigma2.internal.Enigma2Client] - Error on transmit http://192.168.2.25/web/powerstate.
2020-05-03 04:33:59.503 [WARN ] [nding.enigma2.internal.Enigma2Client] - Error on transmit http://192.168.2.25/web/powerstate.
Although this message is correct because of deep sleep mode it floods the openhab.log with a warning every refresh interval.
gdolfen
(Guido Dolfen)
May 3, 2020, 8:44am
10
I don‘t know the openhab way to deal with this.
I think there are the following alternatives:
Supress this log => there is no logging for Troubleshooting
Change the level to debug => you only get problem warnings in debug mode and it will flood the debug log every 5 seconds
Caching the log and print it only the first time ist occurs
In my opinion option 3 is the best one, but which level should use for it.
Are there any suggestions of other openhab contributors?
sihui
(SiHui)
May 3, 2020, 9:01am
11
From a users perspective I would prefer option 2.
I don’t think that’s a problem: for example the zwave binding produces megabytes of log data within minutes in debug mode.
ggaljoen
(Ggaljoen)
May 3, 2020, 10:21am
12
Thank you @gdolfen for this new binding.
Just noticed my system ‘bouquet’ for the request does not respond in the timeout of 5 seconds, it needs more like 8 to 10 seconds.
2020-05-03 12:14:42.301 [WARN ] [nding.enigma2.internal.Enigma2Client] - Error on transmit http://vu-duo2/web/getallservices.
java.io.IOException: java.util.concurrent.TimeoutException: Total timeout 5000 ms elapsed
What further processing do you perform with this information anyway?
Ambo
(Jo)
May 3, 2020, 12:00pm
13
Thank you very much for this nice binding - works fine with vu+Solo2
One question to send info message with a rule:
rule "Enigma2_SendInfo"
when Item Enigma2_SendInfo received command
Enigma2_Info.sendCommand("This is a info")
This would send “This is a info” for 30 sec.
Enigma2_Info.sendCommand(“This is a info”, 5)
should this have the effect to show the info only for 5 sec? it’s not working
I tried this in the rules, but no effect
actions.sendInfo(“Hello World”, 10)
sihui
(SiHui)
May 3, 2020, 12:07pm
14
You will need something like this:
val actions = getActions("enigma2","enigma2:device:vuduo2")
if(null === actions) {
logInfo("actions", "Actions not found, check thing ID")
return
actions.sendInfo("Testmessage!",5)
druciak
(druciak)
May 3, 2020, 12:08pm
15
Log only when state is “online”, ignore when it is already “offline”.
But definitely debug level is the right one.
Ambo
(Jo)
May 3, 2020, 12:20pm
16
sihui:
val actions = getActions(“enigma2”,“enigma2:device:vuduo2”) if(null === actions) { logInfo(“actions”, “Actions not found, check thing ID”) return } actions.sendInfo(“Testmessage!”,5)
thank you very much - that really works fine
and thanks for this really quick answer !!!
gdolfen
(Guido Dolfen)
May 3, 2020, 1:00pm
17
@sihui :
@druciak :
4. Log only when state is “online”, ignore when it is already “offline”.
I changed the logging to debug level only if state is “online”, thanks for your advice.
@ggaljoen :
I added a config parameter, so you can customize the timeout. But you should also change your refresh interval.
ggaljoen
(Ggaljoen)
May 3, 2020, 1:29pm
18
Timeout solved with the additional parameter!
Great improvement on the logging approach as well.
Do you plan the question input ‘getanswer’ ?
druciak
(druciak)
May 3, 2020, 3:52pm
19
With your changes I think nothing will be logged when the configuration is incorrect. It should be logged at least once at the beginning.
gdolfen
(Guido Dolfen)
May 3, 2020, 4:15pm
20
@druciak :
You are right. I fixed it with commit https://github.com/gdolfen/openhab-addons/commit/2ca982e190ac5fcf4a519c691ebe29e77267de98 (I hope so)
