It worked, and as a newbie, this whole story is a kind of mess, i didn’t even use this binding, i was using the “default/official” one, because i haven’t find markus’s work. The others outdated.
Thanks for the reply, and for this awesome binding.
I see. Just take your time
I also would like to create some short of power off timer with OpenHab, but i can’t really find any relevant topic. So like when i say “Turn off AC in 30 minutes” it’ll trigger some type of item that triggers a rule, that’s my imagination. Would that be a difficult task?
Well… All of the sudden it just started acting weird. When i try to control the AC from Google Home/Voice, the events.log contains all of them that they were successful, but nothing happens with the AC:
2021-05-31 17:34:29.325 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'GreeMode_GA' received command off
2021-05-31 17:34:29.325 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'GreeMode_GA' changed from heat to off
or
2021-05-31 17:37:16.723 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'GreeMode_GA' received command cool
2021-05-31 17:37:16.725 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'GreeMode_GA' changed from off to cool
I’ve reinstalled the whole OpenHAB, with new UUID, etc.
GreeMode_GA is a group item. When it receives order from google must trigger your local orders. I have forgotten to share one thing sorry. There is a rule behind:
No it wouldn’t. It is more google topic but you can make a workaround. If you create a virtual switch item, link to google and it triggers your rule what turn ac down delayed your’re done.
Thanks, but i guess the rule isn’t necessary, at least from my experience. Something might be changed since you did this setup.
There was some type of communication error with my AC, i reset the WiFi, and reconnected.
It isn’t really important, but i still didn’t manage to get it working for the fan speed. Could you look at it?
Yes I’m going to look at it. Google connection still under developing. When I created this rule this change was at the beginning about 2020 spring as I remember. When Google had introduced thermostat and HVAC traits. Mode channel was handelable only this tricky way this time. It still works for me, but I will check it over the weekend. If mode channel works, fan speed should work as well as I remember that it was working for me. Now nothing works at me with voice (AC on/off and modes are working from Google app, but fan speed was working only with voice) but I have issue on Google side with naming. So let me fix it and I come back how it does work.
I have started to play with that. My rule modification was not necessary, but at the moment, on/off/cool modes are working with Google, so I need to work on that. It is connected the Google Assistant connection definately. Solution for fan speed change is to use fan speed trait what is not part of thermostat trait anymore. That’s why my solution stopped to work. Here is my solution:
At the moment auto/low/medium/high orders are working. The two middle is not, but reason is that google does not recognises words well I think. So if we play with the names in the trait we will have solution. Pls bare in mind that trick is fan speeed became dimmer channel. so here 0,1…,5 equals percentage to google but it is equivalent of the names in the binding. So target is that we need to get exact number from google to change fan speed. Verbal order change Fanspeed higher and lower works so if you have speed on high it will step one leve back to order “lower” what will be mmediumhigh anyway. But lets play and have a 100% solution.
“Increase/decrease the fan” steps one up/down works.
“Increase/decrease the fan” gives me this response from Google Assistant: “Actually, Fanspeed doesn’t support that functionality.”, and doesn’t do anything.
“Change fan speed to[number/string]” works, but only with a similar rule that you shared with GreeMode_GA:
Your welcome, but for fanspeed you do not need this rule.
For mode change and on/off you need it as Google changes your group item: Group Gree_Modechannel but binding mode item is String GreeMode therefore the link between Google group item and binding mode item is made by the rule. Here we have one Fanspeed item and Google can set it direct without rule. In a meantime I’m trying to change my items accoding to the new Google settings. It looks like now:
Thanks for keeping this binding alive! Please help me set up the SafeHeat option. I installed the “org.openhab.binding.gree-3.1.0-SNAPSHOT” but the SafeHeat option just won’t respond. It works fine from the official GREE app.
OH 3.0.2
Hi Guys,
This binding is very solid, and I really like it.
But… My AC is one of these portable ones, which I move/connect as needed. So most of the year, it is not powered, and therefore I get constant log items; (one every 12’th second, normally)
2021-07-02 08:08:32.329 [INFO ] [ng.gree.internal.handler.GreeHandler] - f4911e6fae19: Unable to connect to air conditioner
Thanks, two good solutions! I choosed the binding OFF method, so I don’t have to go into oh when I plug it the next time. Just hope I remember this, if I am chasing down a malfunction…
