Yep, thanks, I noticed that already and looking into getting it back…
myopenhab.org is really a great differentiator. As projects go that piece really makes this stand out. Its a bit unbelievable this level of availability can be achieved for an infrastructure with thousands of clients i.e. the equivalent of a commercial service without it being a regimented for profit service. Hats off to you all.
Update: The status page is up and running again.
@Gordon_Geist Thanks for your positive feedback!
FTR, all kudos go to @digitaldan and @MARZIMA, who are doing an awesome job in making sure the servers are running smooth, analysing issues any time of day and scaling it if it runs under too heavy load. Impressive and wonderful to have such professional volunteers in the community.
Would it be practical or possible to develop a “status” binding, with the three monitored services as channels that connect to a switch item?
That way, real time changes in availability could be captured by persistence on the local level. It would also allow for rules based notifications of problems.
We are using AppBeat.io as a service and I just checked that there is no public REST API to get the status from.
So all that would be available is the webpage itself, which could be scraped - easiest solution would probably be the HTTP binding with some Xpath transformation…
I think the key here is that the engine behind the myopenhab.org is available to be run independently and we should consider the myopenhab.org service as an ephemeral service. Those that want committed reliability should choose a commercial notification service such as Pushover or spin up and maintain your own myopenhab.org (have fun patching and being your own CISO) or VPN when you want to change something.
Grateful for the wonderful opportunity that this project affords.
Sounds like a fun challenge I’ll add it to my openHAB to do list!
For me the following item configuration works:
String MY_OH2_STATUS "my.openhab.org" {http="<[https://www.appbeat.io/status/openHAB:60000:XPATH(//div[@class='components']/div[1]/span[@class='component-status']/text())]"}
Is there a [s%] missing in the name of the item for showing the status?
It doesn´t work, i get only this displayed on my sitemap (i added the [s%]):
“ openHAB Infrastructure…”
Any idea?
Ok, it works now, had to install xpath-transformation first.
To get the status of the forum, do i only have to change /div[1] to /div[2] ?
You are right in both!
This xpath worked for me:
/html/body/div[@class='status-layout']/div[@class='components']/div[1]/span[@class='component-status']/text()
I have been looking at the IFTTT status page, as we use it for some of our triggers/items
String IFTTTStatus "IFTTT.COM" {http="<[https://status.ifttt.com/:600000:XPATH(//div[@class='components-container.one-column']/div[1]/span[@class='data-component-status']/text())]"}
I appear to be getting a massive string of the whole page rather than the section i think I am isolating
Maybe it has something to do with the fact that the IFTTT status page produces invalid XML, even invalid HTML. For examlpe there are a lot of unclosed <span>-tags in there
maybe a sh script and a grep would suffice
I have also added this too my setup do you know if there is a way too link something like this too my OH specifically as this only reports if there is a problem with the actual cloud server and not if my oh server disconnects from the cloud connector i was pointed here by a different person from my post
when using the item posted it reports operational what exactly does it report as operational is it a collective result or a specific cloud server as checking the site there are 3 OH servers
I risk offending someone but I mean the following in an honest way. Doesn’t it seem ironic that an automation framework wouldn’t have an official way to allow monitoring of its public services or push notifications Yes, I read above that it’s the service that is used that has the constraints but that doesn’t lessen the irony.
Or perhaps kludges to make things work is part of the ‘experience’ we all love
The real irony would be the self-monitoring-all-in-one system because the OH system can fail too.
An OH-based automation system may reach significant complexity very fast. Typically for each bound hardware system it depends on a specific gateway added by a number of external services (Weather, Location etc.).
All these things should be monitored if you want to determine the reason of some malfunction in no time -
or you will earn sarcastic comments from your family …
So I use check_mk as separate monitoring system and configured it not only to check the functional aspects of my OH implementation but monitoring the involved components system health too (Available updates, network infrastructure services etc.). The third main component is an Ansible-based IT automation system for setting up and maintaining the involved systems (initial setup, apply updates, do backup and restore jobs).
The inclusion of the OH cloud status monitoring item in my setup is needed because I want to have some rules to react on a non-functional OH cloud connection.
that’s why I limited my statement to the public services. These are independent of the local system. If the local system is down then all bets are off of course but for openhab official public services it would be nice (nay, essential) for the framework to lead by example and provide out of the box monitoring for its own stuff. I write this as someone who doesn’t need it now.
