What do you see in the logs when you save home.sitemap?
Is it just a typo in the posting or does your sitemap really start with “itemap”? It should start with “sitemap” and if it doesn’t you should see errors in openhab.log.
I instelled from one of the tutorials, but it didnt have the best instructions, had to work out installing JAVA myself and one or two other things
sitemap is in etc/openhab2/sitemaps
steve@ubuntu2:/etc/openhab2/sitemaps$ ls
_default home.sitemap readme.txt
There is nothing really in the logs
OPENHAB.LOG
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1233) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$0(FeaturesServiceImpl.java:1132) ~[?:?]
2017-11-18 18:20:29.636 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2017-11-18 18:20:29.688 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2017-11-18 18:20:29.885 [WARN ] [org.apache.karaf.main.Main ] - Lock lost. Setting startlevel to 1
2017-11-18 18:20:31.844 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
SYSLOG
Nov 21 10:47:35 ubuntu2 systemd[1]: Started Session 52 of user steve.
Nov 21 10:47:35 ubuntu2 systemd[34590]: Reached target Paths.
Nov 21 10:47:35 ubuntu2 systemd[34590]: Reached target Sockets.
Nov 21 10:47:35 ubuntu2 systemd[34590]: Reached target Timers.
Nov 21 10:47:35 ubuntu2 systemd[34590]: Reached target Basic System.
Nov 21 10:47:35 ubuntu2 systemd[34590]: Reached target Default.
Nov 21 10:47:35 ubuntu2 systemd[34590]: Startup finished in 12ms.
Nov 21 10:47:35 ubuntu2 systemd[1]: Started User Manager for UID 1000.
Nov 21 10:50:43 ubuntu2 systemd[1]: Started Session 53 of user steve.
Nov 21 10:52:03 ubuntu2 systemd[1]: Started Session 54 of user steve.
Nov 21 10:55:20 ubuntu2 systemd[1]: Started Session 55 of user steve.
Nov 21 10:56:21 ubuntu2 sudo: pam_ecryptfs: pam_sm_authenticate: /home/steve is already mounted
However when I do the same exercise on my Raspberry pi3, then there is a “refresh” entry in the openhab.log file
Also. As you get setup with Ubuntu, I find it best and easiest to setup Samba, and then you can access your OH2 files from your windows or other machine and use any text editor or the recommended VS Code program to create your sitemaps, item files, etc.
Did you follow the install docs found here entirely? I run OH2 on Ubuntu Server 16 and things run quite well.
That line (substituted with my IP adress returns the following error
HTTP ERROR 500
Problem accessing /classicui/app. Reason:
Server Error
Caused by:
javax.servlet.ServletException: Sitemap 'home' could not be found
at org.eclipse.smarthome.ui.classic.internal.servlet.WebAppServlet.service(WebAppServlet.java:169)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:812)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:587)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:287)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
at org.eclipse.jetty.server.Server.handle(Server.java:499)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:311)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:544)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)
at java.lang.Thread.run(Thread.java:748)
Caused by: org.eclipse.smarthome.ui.classic.render.RenderException: Sitemap 'home' could not be found
at org.eclipse.smarthome.ui.classic.internal.servlet.WebAppServlet.service(WebAppServlet.java:130)
... 21 more
Caused by:
It largely depends on which version of Ubuntu you are running. If it is 16 or 17 (maybe 15 or 14 as well, I don’t remember when Ubuntu switched to systemd)
sudo systemctl stop openhab2 # Stops the service
sudo systemctl start openhab2 # Starts the service
sudo systemctl restart openhab2 # Restarts the service
sudo systemctl status openhab2 # Shows the most recent output and running status of the service
Would you know the directory for the cache folder (ive found /var/cache but there are a few directories in that. Also any idea where the tmp directory is?
Can you put your BasicUI settings back to using the _default sitemap and see if it loads? I noticed when you showed that directory it showed without the sitemap extension.
We’ll get this worked out. Perhaps since your just getting started on the system as well, to do a reinstall of OH2 to ensure no issues.
Also, do you know what version of Java your running? it should be something like the below
ptmuldoon@OpenHab2:/etc/openhab2/sitemaps$ java -version
java version "1.8.0_151"
Java(TM) SE Runtime Environment (build 1.8.0_151-b12)
Java HotSpot(TM) 64-Bit Server VM (build 25.151-b12, mixed mode)
What does the default site map contain? You can replace what that file has with the demo sitemap if you would like. I think its the same, but the demo sitemap info can be found here.
I still get the same. I copied the demo sitemap to both _default & home. _default loads a blank sitemap and home, loads a page saying that there are no sitemaps available, I am no linux expert but im wondering if it is a permissions problem. Unfortunately i have to disappear for a bit i have a course to go on (Speed Awareness I’ve been a naughty boy)
