New Jeelink Openhab2 Binding
Volker please revert your LGW changes, the pcaTest version works very good with this:
Thing jeelink:jeelinkUsb:lgwusb [ serialPort="/dev/ttyUSB02", initCommands="20000#2r;3,868950,5i" ]
Thing jeelink:lacrosse:46 "Thermometer Bad" (jeelink:jeelinkUsb:lgwusb) [ sensorId="46", updateInterval=5, sensorTimeout=60, bufferSize=0, minTemp=-40, maxTemp=60, maxDiff=0]
Thing jeelink:lacrosse:13 "Thermometer Balkon" (jeelink:jeelinkUsb:lgwusb) [ sensorId="13", updateInterval=5, sensorTimeout=60, bufferSize=0, minTemp=-40, maxTemp=60, maxDiff=0]
Thing jeelink:lacrosse:16 "Thermometer Kuehlschrank" (jeelink:jeelinkUsb:lgwusb) [ sensorId="16", updateInterval=5, sensorTimeout=60, bufferSize=0, minTemp=-40, maxTemp=60, maxDiff=0]
Thing jeelink:lacrosse:29 "Thermometer Schlafzimmer" (jeelink:jeelinkUsb:lgwusb) [ sensorId="29", updateInterval=5, sensorTimeout=60, bufferSize=0, minTemp=-40, maxTemp=60, maxDiff=0]
Thing jeelink:ec3k:5828 "PC Ecke" (jeelink:jeelinkUsb:lgwusb) [ sensorId="5828", updateInterval=0, sensorTimeout=60, bufferSize=0 ]
Thing jeelink:ec3k:591E "TV Ecke" (jeelink:jeelinkUsb:lgwusb) [ sensorId="591E", updateInterval=0, sensorTimeout=60, bufferSize=0 ]
Thing jeelink:ec3k:BC81 "TV Schlafzimmer" (jeelink:jeelinkUsb:lgwusb) [ sensorId="BC81", updateInterval=0, sensorTimeout=60, bufferSize=0 ]
Thing jeelink:ec3k:B0A7 "Technik Kueche" (jeelink:jeelinkUsb:lgwusb) [ sensorId="B0A7", updateInterval=0, sensorTimeout=60, bufferSize=0 ]
Now i try to get pca301 working…
Why have your pca301 example id’s 7 chars?
My sockets id’s having all 6 chars (230645 in decimal (standard) or 0384F5 in hex (LGW)).
Have you seen this old pca301 binding? https://github.com/ribbeck/openhab-binding-pca301
Maybe you can get some code from there.
Hi Volker,
thanks for your reply. I used the latest SNAPSHOT releases (they were from 20171202, 20171203 and 20171204). None of them worked. I thought i damaged something during my upgrade from 2.1 to 2.2, thats why I reinstalled everything yesterday night (redownloaded OpenHabian, reflashed, used UNSTABLE branch again). Result was:
Exact same (bad) behaviour of JeeLink PLUS this error: https://github.com/openhab/openhab-distro/issues/571
I guess I reinstall OpenHAB again tonight and use the Stable release.
Thank you very much anyway.
Best regards
Edit 20171207: Iam on OpenHAB 2.1 now and everything works like a charm.
Hey guys,
I’ve got the same problem with the 2.2 snapshot here. Stable 2.1 runs, but i needed to update to version 2.2 because of an error in the astro-binding (Astro not updating every day) in 2.1. Now it’s a clean installation of Debian 9 and Openhab.
2017-12-09 00:53:39.641 [thome.event.ExtensionEvent] - Extension 'binding-jeelink' has been installed.
2017-12-09 00:54:13.307 [hingStatusInfoChangedEvent] - 'jeelink:jeelinkUsb:acfdd6f5' changed from UNINITIALIZED to INITIALIZING
2017-12-09 00:54:13.307 [ERROR] [ore.thing.internal.ThingRegistryImpl] - Could not inform the ThingTracker 'org.eclipse.smarthome.core.thing.internal.ThingManager@6138fe5f' about the 'THING_ADDED' event!
java.lang.IllegalArgumentException: repeated interface: org.eclipse.smarthome.core.thing.binding.BridgeHandler
        at java.lang.reflect.Proxy$ProxyClassFactory.apply(Proxy.java:597) [?:?]
        at java.lang.reflect.Proxy$ProxyClassFactory.apply(Proxy.java:557) [?:?]
        at java.lang.reflect.WeakCache$Factory.get(WeakCache.java:230) [?:?]
        at java.lang.reflect.WeakCache.get(WeakCache.java:127) [?:?]
        at java.lang.reflect.Proxy.getProxyClass0(Proxy.java:419) [?:?]
        at java.lang.reflect.Proxy.newProxyInstance(Proxy.java:719) [?:?]
        at org.eclipse.smarthome.core.internal.common.SafeCallerBuilderImpl.build(SafeCallerBuilderImpl.java:65) [109:org.eclipse.smarthome.core:0.9.0.201712011551]
        at org.eclipse.smarthome.core.thing.internal.ThingManager.doInitializeHandler(ThingManager.java:630) [116:org.eclipse.smarthome.core.thing:0.9.0.201712011551]
        at org.eclipse.smarthome.core.thing.internal.ThingManager.initializeHandler(ThingManager.java:557) [116:org.eclipse.smarthome.core.thing:0.9.0.201712011551]
        at org.eclipse.smarthome.core.thing.internal.ThingManager.registerAndInitializeHandler(ThingManager.java:914) [116:org.eclipse.smarthome.core.thing:0.9.0.201712011551]
        at org.eclipse.smarthome.core.thing.internal.ThingManager.thingAdded(ThingManager.java:370) [116:org.eclipse.smarthome.core.thing:0.9.0.201712011551]
        at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyTrackers(ThingRegistryImpl.java:213) [116:org.eclipse.smarthome.core.thing:0.9.0.201712011551]
        at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutAddedElement(ThingRegistryImpl.java:132) [116:org.eclipse.smarthome.core.thing:0.9.0.201712011551]
        at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutAddedElement(ThingRegistryImpl.java:1) [116:org.eclipse.smarthome.core.thing:0.9.0.201712011551]
        at org.eclipse.smarthome.core.common.registry.AbstractRegistry.added(AbstractRegistry.java:136) [109:org.eclipse.smarthome.core:0.9.0.201712011551]
        at org.eclipse.smarthome.core.common.registry.AbstractRegistry.added(AbstractRegistry.java:1) [109:org.eclipse.smarthome.core:0.9.0.201712011551]
        at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:56) [109:org.eclipse.smarthome.core:0.9.0.201712011551]
        at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:74) [109:org.eclipse.smarthome.core:0.9.0.201712011551]
        at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListenersAboutAddedElement(AbstractProvider.java:78) [109:org.eclipse.smarthome.core:0.9.0.201712011551]
        at org.eclipse.smarthome.core.common.registry.AbstractManagedProvider.add(AbstractManagedProvider.java:64) [109:org.eclipse.smarthome.core:0.9.0.201712011551]
        at org.eclipse.smarthome.core.common.registry.AbstractRegistry.add(AbstractRegistry.java:210) [109:org.eclipse.smarthome.core:0.9.0.201712011551]
        at org.eclipse.smarthome.io.rest.core.internal.thing.ThingResource.create(ThingResource.java:213) [126:org.eclipse.smarthome.io.rest.core:0.9.0.201712011551]
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
        at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
        at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
        at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
        at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [87:org.eclipse.jetty.server:9.3.22.v20171030]
        at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [85:org.eclipse.jetty.security:9.3.22.v20171030]
        at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [87:org.eclipse.jetty.server:9.3.22.v20171030]
        at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [87:org.eclipse.jetty.server:9.3.22.v20171030]
        at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
        at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
        at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [87:org.eclipse.jetty.server:9.3.22.v20171030]
        at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [87:org.eclipse.jetty.server:9.3.22.v20171030]
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [87:org.eclipse.jetty.server:9.3.22.v20171030]
        at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
        at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [87:org.eclipse.jetty.server:9.3.22.v20171030]
        at org.eclipse.jetty.server.Server.handle(Server.java:534) [87:org.eclipse.jetty.server:9.3.22.v20171030]
        at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [87:org.eclipse.jetty.server:9.3.22.v20171030]
        at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [87:org.eclipse.jetty.server:9.3.22.v20171030]
        at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [79:org.eclipse.jetty.io:9.3.22.v20171030]
        at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [79:org.eclipse.jetty.io:9.3.22.v20171030]
        at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [79:org.eclipse.jetty.io:9.3.22.v20171030]
        at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [90:org.eclipse.jetty.util:9.3.22.v20171030]
        at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [90:org.eclipse.jetty.util:9.3.22.v20171030]
        at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [90:org.eclipse.jetty.util:9.3.22.v20171030]
        at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [90:org.eclipse.jetty.util:9.3.22.v20171030]
        at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [90:org.eclipse.jetty.util:9.3.22.v20171030]
Maybe it helps to sort out the issue.
Which build number of openHAB have you installed? From where did you take the binding jar? Did you use this one:
https://openhab.jfrog.io/openhab/libs-pullrequest-local/org/openhab/binding/org.openhab.binding.jeelink/2.2.0-SNAPSHOT/
If not, can you please check if this jar behaves identically to the one you have currently installed?
Edit: what exactly did you do when the exception was raised? Did you try to discover sensors, did you define the thing for the bridge, or did you just start the binding without having things defined?
Hey,
same issue here. Five weeks since installing OH 2.2.0 the Jeelink Bindings works fine. But after apt-get update/upgrade three days before it shows: ā€œJeeLink USB EmpfƤnger Status: INITIALIZINGā€ Thing removal or uninstall/install of the Bindings in PaperUI does not help.
In PaperUI the configuration parameters / serial settings are shown: ā€œ/dev/ttyUSB0, /dev/ttyUSB0ā€. I think it was only one ā€œ/dev/ttyUSB0ā€ before.
openhab2 version: (2.2.0~20171209104822-1), Binding installed with PaperUI (binding-jeelink - 2.2.0.SNAPSHOT) openhab.binding.jeelink:2.2.0.201712062218.
Thanks,
Tobias
Hi Volker,
i installed openhab with the snapshot ppa:
2.2.0.201712041513 │ openHAB Core
and the jeelink-binding by adding it to the addons.cfg
2.2.0.201712081653 │ JeeLink Binding
And your question what i’ve done:
I installed openhab, added the astro-binding (in addons.cfg) after that i added the jeelink-binding (as well through the addons.cfg):
Then I tried to set up the usb-receiver, put my /dev/ttyUSB0 in it and saved. On this moment the error was raised.
So from my point of view, the installation worked well, but the setup of the USB-bridge is broken. I rebooted the system, unplugged the USB-receiver, removed the thing, tried everything again and again. The error was always the same.
Michael
I have no idea what the problem is. I just updated openHAB and do now also have the same problem. I asked for help in another thread: Problems after upgrade to 2.2 (CircularReference, bindings no longer work)
Hi guys,
I can confirm that this is a bug on the framework side, I have created https://github.com/eclipse/smarthome/issues/4713 for it.
Latest distro #1130 should have the fix included - please retest and report back!
Binding is working again. Thanks.
I can confirm this, its working again.
Thanks guys.
Hey,
it’s working again… Thanks.
Hi Volker,
I see in the log sporadically (once per 30min) the following message:
11:18:21.180 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ā€˜jeelink:jeelinkUsb:15d71c67’ changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): propagate: Underlying input stream returned zero bytes
11:18:21.180 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ā€˜jeelink:lacrosse:52’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
I am using the LaCrosse sketch and a Technoline TX 29 DTH-IT sensor which are actually working without any problems, but everytime the error occurs the things go offline and after a while online again.
I am using the latest snapshot on Windows 10.
Do you have any clue what is going wrong?
Thanks!
This sounds as if there is a problem reading from the stick. If the binding gets an exception reading from the stick, it closes the connection and reopens it 5 seconds later.
Is this a known issue? Is it possible to modify the error handling to simply suppress this kind of error?
You are the first one to report such a problem. And modifying the error handling would only hide a problem, as these exceptions should not occur on a normal installation.
I have updated the binding. It have added some bug fixes for pca301 and reworked the mechanism that detects which sensors are connected. So If you have pca301 sockets, test the new version:
https://github.com/vbier/openhab2-addons/blob/pca301/addons/binding/org.openhab.binding.jeelink/org.openhab.binding.jeelink-2.2.0-SNAPSHOT.jar
Hello Volker
I just updated to openhab 2.2.
Now I see the JeeLink binding at bindings in the paperUI, but it is not marked as installed.
I am afraid what happens if I install it via paperUI now. Will I loos all configuration and items of that binding?
On the other hand, if I do not install it via paperUI I will miss all further updates of that binding.
How to proceed now with openhab 2.2 and manual installation of the binding?
Thank you in advance.
BR
Matthias
Dear fellow OpenHABers,
I seem to have the same (or similar) issue as Matze:
I’m running OpenHabian on a Raspi Model 3. After updating to OpenHAB2.2 the Jeelink Binding was not installed. So I re-installed it using PaperUI. Now my Jeelink Devices show up in the PaperUI as ā€œUNINITIALIZEDā€. I took a look in the logs an found the following error:
 [ERROR] [org.openhab.binding.jeelink         ] - FrameworkEvent ERROR - org.openhab.binding.jeelink
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.jeelink [239]
  Another singleton bundle selected: osgi.identity; type="osgi.bundle"; version:Version="2.2.0"; osgi.identity="org.openhab.binding.jeelink"; si
ngleton:="true"
        at org.eclipse.osgi.container.Module.start(Module.java:444) [?:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620) [?:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600) [?:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571) [?:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514) [?:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
        at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
        at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
Since another deinstall and reinstall via PaperUI did not help, I tried a ā€œlocate jeelinkā€ to find out, where the related components are installed. I got:
# locate jeelink
/srv/openhab2-addons/org.openhab.binding.jeelink-2.1.0-SNAPSHOT.jar
/srv/openhab2-sys/addons/org.openhab.binding.jeelink-2.1.0-SNAPSHOT.jar
/srv/openhab2-userdata/tmp/mvn/org/openhab/binding/org.openhab.binding.jeelink
/srv/openhab2-userdata/tmp/mvn/org/openhab/binding/org.openhab.binding.jeelink/2.2.0
/srv/openhab2-userdata/tmp/mvn/org/openhab/binding/org.openhab.binding.jeelink/2.2.0/org.openhab.binding.jeelink-2.2.0.jar
/srv/openhab2-userdata/tmp/mvn/org/openhab/binding/org.openhab.binding.jeelink/2.2.0/org.openhab.binding.jeelink-2.2.0.jar.sha1
/usr/share/openhab2/addons/org.openhab.binding.jeelink-2.1.0-SNAPSHOT.jar
/var/lib/openhab2/tmp/mvn/org/openhab/binding/org.openhab.binding.jeelink
/var/lib/openhab2/tmp/mvn/org/openhab/binding/org.openhab.binding.jeelink/2.2.0
/var/lib/openhab2/tmp/mvn/org/openhab/binding/org.openhab.binding.jeelink/2.2.0/org.openhab.binding.jeelink-2.2.0.jar
/var/lib/openhab2/tmp/mvn/org/openhab/binding/org.openhab.binding.jeelink/2.2.0/org.openhab.binding.jeelink-2.2.0.jar.sha1
So it seems that there are some leftovers from OpenHAB 2.1 in /usr/share/openhab2/addons/ and /srv/openhab2-sys/addons/
Can I simply remove the jars and replace them with the 2.2 versions to resolve the issue or is there another canonical way to deal with such issues?
Thanks in advance and Merry Christmas,
Roland
If you do not have pca301 sockets, remove the jar that you have manually installed, and after that install using the paper ui.
Use the jar that i linked a few posts back If you have pca301 sockets.
