The log does not show that discovery has been started?
I deleted the stick and run it again
2018-03-07 20:59:24.664 [DEBUG] [l.connection.JeeLinkSerialConnection] - Closing serial connection to port /dev/ttyUSB0...
2018-03-07 20:59:24.758 [DEBUG] [org.openhab.binding.jeelink ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=324, service.bundleid=188, service.scope=singleton} - org.openhab.binding.jeelink
2018-03-07 20:59:34.334 [DEBUG] [core.karaf.internal.FeatureInstaller] - Running scheduled sync job
2018-03-07 20:59:52.138 [DEBUG] [elink.internal.JeeLinkHandlerFactory] - creating JeeLinkHandler for thing 70432608...
2018-03-07 20:59:52.139 [DEBUG] [elink.internal.JeeLinkHandlerFactory] - registering sensor discovery service...
2018-03-07 20:59:52.143 [DEBUG] [org.openhab.binding.jeelink ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=325, service.bundleid=188, service.scope=singleton} - org.openhab.binding.jeelink
2018-03-07 20:59:52.160 [DEBUG] [l.connection.JeeLinkSerialConnection] - Creating serial connection for port /dev/ttyUSB0 with baud rate 57600...
2018-03-07 20:59:52.163 [DEBUG] [l.connection.JeeLinkSerialConnection] - Opening serial connection to port /dev/ttyUSB0 with baud rate 57600...
2018-03-07 20:59:52.492 [TRACE] [connection.AbstractJeeLinkConnection] - Read line from port /dev/ttyUSB0: OK 24 8 4 5 86 62 1 2 131 68 76
2018-03-07 20:59:52.883 [TRACE] [connection.AbstractJeeLinkConnection] - Read line from port /dev/ttyUSB0: OK 24 6 4 6 200 255 1 2 4 60 154
2018-03-07 20:59:53.075 [TRACE] [connection.AbstractJeeLinkConnection] - Read line from port /dev/ttyUSB0: OK 24 7 4 5 64 16 1 0 0 0 0
2018-03-07 21:00:09.369 [TRACE] [connection.AbstractJeeLinkConnection] - Read line from port /dev/ttyUSB0: OK 24 7 5 5 64 16 1 170 170 170 170
2018-03-07 21:00:09.977 [TRACE] [connection.AbstractJeeLinkConnection] - Read line from port /dev/ttyUSB0: OK 24 7 4 5 64 16 0 0 0 0 0
2018-03-07 21:00:11.560 [TRACE] [connection.AbstractJeeLinkConnection] - Read line from port /dev/ttyUSB0: OK 24 7 5 5 64 16 0 170 170 170 170
Did you start discovery for the jeelink binding in the inbox of the paper ui?
Inbox > JeeLink Binding > Search
Did you paste the wrong part of the log? A discovery should look like this:
2018-03-06 19:55:49.601 [DEBUG] [nal.discovery.SensorDiscoveryService] - discovery started for bridge jeelink:jeelinkUsb:4c6d16fd
2018-03-06 19:55:50.410 [DEBUG] [nal.discovery.SensorDiscoveryService] - discovery for bridge jeelink:jeelinkUsb:4c6d16fd found already known sensor id 30
2018-03-06 19:55:54.151 [DEBUG] [nal.discovery.SensorDiscoveryService] - discovery for bridge jeelink:jeelinkUsb:4c6d16fd found already known sensor id 58
2018-03-06 19:55:54.642 [DEBUG] [nal.discovery.SensorDiscoveryService] - discovery for bridge jeelink:jeelinkUsb:4c6d16fd found already known sensor id 30
2018-03-06 19:55:57.894 [DEBUG] [nal.discovery.SensorDiscoveryService] - discovery for bridge jeelink:jeelinkUsb:4c6d16fd found already known sensor id 38
2018-03-06 19:56:02.411 [DEBUG] [nal.discovery.SensorDiscoveryService] - discovery for bridge jeelink:jeelinkUsb:4c6d16fd found unknown sensor of type jeelink:pca301 with id 1-160-236
2018-03-06 19:56:02.445 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing βjeelink:pca301:1-160-236β to inbox.
2018-03-06 19:56:03.059 [DEBUG] [nal.discovery.SensorDiscoveryService] - discovery for bridge jeelink:jeelinkUsb:4c6d16fd found already known sensor id 58
2018-03-06 19:56:06.487 [DEBUG] [nal.discovery.SensorDiscoveryService] - discovery for bridge jeelink:jeelinkUsb:4c6d16fd found already known sensor id 38
2018-03-06 19:56:11.582 [DEBUG] [nal.discovery.SensorDiscoveryService] - discovery for bridge jeelink:jeelinkUsb:4c6d16fd found already known sensor id 30
2018-03-06 19:56:11.963 [DEBUG] [nal.discovery.SensorDiscoveryService] - discovery for bridge jeelink:jeelinkUsb:4c6d16fd found already known sensor id 58
2018-03-06 19:56:15.082 [DEBUG] [nal.discovery.SensorDiscoveryService] - discovery for bridge jeelink:jeelinkUsb:4c6d16fd found already known sensor id 38
2018-03-06 19:56:19.600 [DEBUG] [nal.discovery.SensorDiscoveryService] - discovery stopped for bridge jeelink:jeelinkUsb:4c6d16fd
It should at least contain the discovery started and stopped messages.
Hm,
openhab> log:get
Logger β Level
ββββββββββββββββββββββββββββββββββββββββββββββββββββΌββββββ
ROOT β INFO
javax.jmdns β ERROR
org.apache.karaf.jaas.modules.audit β INFO
org.apache.karaf.kar.internal.KarServiceImpl β ERROR
org.apache.karaf.shell.support β OFF
org.eclipse.smarthome β INFO
org.jupnp β ERROR
org.openhab β TRACE
org.openhab.binding.jeelink β TRACE
org.ops4j.pax.url.mvn.internal.AetherBasedResolver β ERROR
org.ops4j.pax.web.pax-web-runtime β OFF
smarthome.event β DEBUG
smarthome.event.InboxUpdatedEvent β ERROR
smarthome.event.ItemAddedEvent β ERROR
smarthome.event.ItemRemovedEvent β ERROR
smarthome.event.ItemStateEvent β ERROR
smarthome.event.ThingAddedEvent β ERROR
smarthome.event.ThingRemovedEvent β ERROR
smarthome.event.ThingStatusInfoEvent β ERROR
And the content from the openhab.log
(you see the removed jeelink and the rest of entries above"
It is not a logging configuration problem. It looks like the discovery is not started, but I have no idea why.
Can you check that you only have one version of the binding installed? Type
bundle:list |grep Jeelink
Into the console.
I found 2 entries
188 β Active β 80 β 2.3.0.201802111802 β JeeLink Binding
199 β Installed β 80 β 2.3.0.201803022259 β JeeLink Binding
That might be the reason. Try uninstalling the older one. Have you installed the binding through paper ui? Then try uninstalling from there.
Or try
bundle:remove 188
In the console. The command might be different, I am currently not in front of my PC.
Ahh,
now i have under
Inbox > JeeLink Binding > Choose Thing
Jeelink USB Receiver and PCA301
For PCA301 i should input a sensor ID??
Do not create the things manually, use the discovery.
Thx Volker for your help
Now my sockets were found
2018-03-07 22:31:38.815 [DEBUG] [nal.discovery.SensorDiscoveryService] - discovery started for bridge jeelink:jeelinkUsb:92155c70
2018-03-07 22:31:41.348 [TRACE] [connection.AbstractJeeLinkConnection] - Read line from port /dev/ttyUSB0: OK 24 7 5 5 64 16 1 170 170 170 170
2018-03-07 22:31:41.972 [TRACE] [connection.AbstractJeeLinkConnection] - Read line from port /dev/ttyUSB0: OK 24 7 4 5 64 16 0 0 0 0 0
2018-03-07 22:31:41.974 [TRACE] [ternal.pca301.Pca301ReadingConverter] - Creating reading from: OK 24 7 4 5 64 16 0 0 0 0 0
2018-03-07 22:31:41.980 [DEBUG] [nal.discovery.SensorDiscoveryService] - discovery for bridge jeelink:jeelinkUsb:92155c70 found unknown sensor of type jeelink:pca301 with id 5-64-16
2018-03-07 22:31:41.989 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'jeelink:pca301:5-64-16' to inbox.
But i cant switch the sockets.
Under
Configuration > Things
I see JeeLink USB Receiver and my sockets as UNINITIALIZED
EDIT:
First Day User Post reached so:
Thx for your time & help
They will stay uninitialised until the first reading has been received and then should come online. At that point you should be able to switch them.
I am not sure what the polling interval is, but if my memory serves me right it can be configured with an init command. You can specify an init command in the stick configuration.
Thatβs it for today. More tomorrow.
I have updated the jar once again. I forgot one file yesterday, have now created dedicated thing types for LaCrosseGateways and also updated the README to reflect the changes:
Hi Volker,
after your last Update the sockets works perfect.
Thx for intensiv help
Now itΒ΄s time for the 2nd Jeelink & Lacrosse
Dear Volker
I just installed the latest jar you published in this thread.
I just copied it into /usr/share/openhab2/addons/
Now I got the following error in the openhab log:
2018-03-11 11:45:12.871 [ERROR] [org.openhab.binding.jeelink ] - FrameworkEvent ERROR - org.openhab.binding.jeelink org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.jeelink [217] Another singleton bundle selected: osgi.identity; type="osgi.bundle"; version:Version="2.2.0"; osgi.identity="org.openhab.binding.jeelink"; singleton:="true" at org.eclipse.osgi.container.Module.start(Module.java:444) [?:?] at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620) [?:?] at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600) [?:?] at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571) [?:?] at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514) [?:?] at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?] at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?] at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
Do I need to unsintall the βoldβ 2.2.0 binding that was installed via PaperUI?
Thank you in advance.
Best regards,
Matthias
Yes.
Dear volker!
Thank you for that advice! i was not aware about this possibility! After doing that everything works fine again! Thank you again!
best regards
Walter
Hello Everybody,
Iβve my openhab system working for more than one year on raspebrry pi 3 and openhabian config, with the zwave binding. i bought a jeelink stick in order to collect the data from my lacrosse weather station. in order to make the both stick working together, i used Symlinks for the Zwave Stick and the JeeLink stick. now the both are recognised and online.
unfortunately it seems that i canβt discover any lacrosse sensors (TX29DTH-IT). i followed this topic others and try to solve the problem by my self. but for the moment it still do not work for me.
below you have the log for the jeelink binding:
2018-04-23 11:08:27.304 [hingStatusInfoChangedEvent] - 'jeelink:jeelinkUsb:1dbffc92' changed from ONLINE to OFFLINE
2018-04-23 11:08:27.310 [me.event.ThingUpdatedEvent] - Thing 'jeelink:jeelinkUsb:1dbffc92' has been updated.
2018-04-23 11:08:27.320 [hingStatusInfoChangedEvent] - 'jeelink:jeelinkUsb:1dbffc92' changed from OFFLINE to ONLINE
2018-04-23 11:11:18.646 [hingStatusInfoChangedEvent] - 'jeelink:jeelinkUsb:1dbffc92' changed from ONLINE to OFFLINE
2018-04-23 11:11:18.668 [me.event.ThingUpdatedEvent] - Thing 'jeelink:jeelinkUsb:1dbffc92' has been updated.
2018-04-23 11:11:18.688 [hingStatusInfoChangedEvent] - 'jeelink:jeelinkUsb:1dbffc92' changed from OFFLINE to ONLINE
2018-04-23 11:13:45.498 [hingStatusInfoChangedEvent] - 'jeelink:jeelinkUsb:1dbffc92' changed from ONLINE to OFFLINE
2018-04-23 11:13:45.506 [me.event.ThingUpdatedEvent] - Thing 'jeelink:jeelinkUsb:1dbffc92' has been updated.
2018-04-23 11:13:45.523 [hingStatusInfoChangedEvent] - 'jeelink:jeelinkUsb:1dbffc92' changed from OFFLINE to ONLINE
2018-04-23 11:36:11.596 [DEBUG] [nal.discovery.SensorDiscoveryService] - discovery started for bridge jeelink:jeelinkUsb:1dbffc92
2018-04-23 11:36:41.595 [DEBUG] [nal.discovery.SensorDiscoveryService] - discovery stopped for bridge jeelink:jeelinkUsb:1dbffc92
log list:
openhab> log:list
Logger β Level
ββββββββββββββββββββββββββββββββββββββββββββββββββββΌββββββββ
ROOT β WARN
javax.jmdns β ERROR
org.jupnp β ERROR
org.openhab β INFO
org.openhab.binding.zwave β DEFAULT
org.oprnhab.binding.jeelink β
smarthome.event β INFO
and binding version:
bundle:list|grep -i jeeLink
220 β Active β 80 β 2.3.0.201803081647 β JeeLink Binding
does anyone of you already face this issue, or can help me to solve it?
thanks
Have you flashed the sketch onto the stick? If yes, are you sure you configured the stick thing with the correct usb device? You logs show that nothing at all can be read from the stick, not even the line identifying the sketch.
