do you already use openhab 2.3? This quantity type is a new feature which was introduced in openhab just a few days/weeks ago. I use this feature to connect a measurement unit (Celcius Grad, Watt, Watt/h, Lux etc) to the item states. In openhab 2.3 you have to define which measurement system ( SI units (metric system), anglo american units) you use and all states a transformed into the right units automatically (celcius <-> fahrenheit for example)
I use a nightly build in my productive system for months now and do not have any problems.
thanks a lot for your words. I am glad to hear that this binding works well for you.
Using my rocker switches without any rules is possible because of the openhab 2.2 feature “profiles”. You can connect my rocker switches to a any switch (or even dimmer) item through a profile. This profile translates then the rocker switch messages (UP/DOWN pressed, LONG/SHORT press) to ON/OFF (or DIM UP/DIM DOWN) commands.
For example I use some rocker switches to control hue lights (on/off, dim up/down) or play/pause my sonos without any rule
What kind of nodon actuator do you own? The in wall actuators or the smart meter plugs? Currently my binding just supports the smart meter plugs (I even own them). However supporting the in wall actuators should not be big thing.
i have actually the in wall actuators, if you could integrate them as well would be great.
Just let me know which details you need and ill check them later.
for the dimmer integration i did, most likely exactly the same you did with my hue lights.
on/off works quite good, but for dimming its a bit tricky to use.
in my setup it seems to be quite delayed, meaning if i long press the rocker it takes some time until the light gets dimmed. and if i press it a bit to long, even already released, its still dimming or even switch off.
with my previous setup, enocean binding and rules, it was more responsive, not sure if this is something related to the binding or my setup.
maybe I find some time today to do the first implementation for your in wall actuator. Do you own the one or two channel actuator?
Yes you are right, dimming is a bit tricky. As enocean rocker switches do not know long/short press, the openhab dimming profile uses some time dependent mechanics to differ between short and long press. A press is recognized as a long press when you hold the button at least 500 ms. So the first dimming command is send after 550 ms, subsequent dimming commands are send after 200 ms. If you used tighter timings or used smaller increasing/decreasing steps in your rule, the system was more responsive. Maybe you should ask the developer (jaykay) of this profile to modify it a little bit for you.
I implemented the EEP profiles D2-01-0F and D2-01-12 which are used by the one and two channel in wall actuators. Currently I just support the switching functions, advanced features like auto off timers are not implemented yet. If you need them too leave a comment here.
As I am currently developing this binding against the OH 2.3 version and use some new features which are not backward compatible to version 2.2, I created a new branch “OH2.3_Mods” in github. To be able to use this new version of this binding, you have to switch to the unstable/nightly build of OH. If this is a problem for you, I can look if I can merge these changes to the OH 2.2 compatible branch.
However I would be very happy, if you could test these changes and tell me if it works for you setup. Thanks a lot in advance.
actually i made use of the commands INCREASE and DECREASE the rocker switch was sending, which i then used to send to my dimmer items.
Therefore no need of any timings in the rules.
When I press the switch the “Receiving” item shown RSSI and repeating information. But I don’t see a state change for the two other items. What have I done wrong.
I do not know why but sometime the automatic item profile assignment is strange. So maybe a false profile (for example my state updating profile) is choosen for your switch item.
Could you try this item definition
This profile should be the default one if you really want to send a ON/OFF command to the item. May I come to know what you are planning to do? Do you also want to switch something with your item?
thanks for your help. Actually I think my problem is that the switch sends 0x10/0x00 for pressed/received.I have tried another switch which sends 0x70/0x00 resp. 0x50/0x00. In this case I see “triggered DIR1/2_PRESSED” and “triggered DIR1/2_RELEASED”.
The only thing I want to do with the switch is to trigger a rule.
That could also be the reason What kind of switch do you use here? Do know which EEP it uses? If I look into the EEP docs, I just find a wind speed threshold detector (F6-05-00), which sends such messages.
EnOcean received via EUL: EnOcean:1:F6:10:0082EB6D:20:01FFFFFFFF4400
EnOcean received via EUL: EnOcean:1:F6:00:0082EB6D:20:01FFFFFFFF4400
Best regards,
Thorsten
… I have tested another “single” switch which also sends 0x10/0x00. It is the voltage controlled transmitter PEHA 455 FU-S2. In FHEM both switched can be simply defined as standard switch and 0x10 is interpreted as “pressed” and “0x00” as “released”. Daniel, if you could implement something similar I would be really glad. Or do you think there is another way to get the information?
my binding does not identify these messages as rocker switch messages because of the status byte (0x20). According to the EEP doc, the bits 5 and 6 of the status byte should be set (for example 0x30).
When I drop this check, your rocker switches should work as well. Let me see what other implications this change could have.
Is it possible to use the binding in a wired setup? Currently I am using an USB300, but I would prefere to connect the FAM14 over USB to the openhab-server (raspberry).
I could use the long weekend to test the wired setup of my binding. It is possible to send and receive messages with an USB connected FAM14 after some modifications (FAM14 does not have a base id). However the guys at the fhem forum do not recommend this kind of setup as the FAM14 is not intended to send/receive messages. Some guys mention message loss.
I hope I can clean up the prototyp implementation and release a updated version of my binding during the next week.
when i try installing the bundle i recieve a failure message:
Unable to install bundle org.openhab.binding.openocean: org.osgi.framework.BundleException: Error reading bundle content
The bundle package is readable and has correct rights. I tried the installation for 3 times with the same result!
A little bit later im startet the PaperUi and found the openocean binding.
After adding the bridge and doing the steps from the manual they found my nodon sin-2-2-01 switch and an eltako double switch.
All klicks from the eltako will be recieved from the nodon “receiving status”, but all my tries to send any signal with the nodon switch or a manually created virtual switch has no result.
normally these messages are send when you release a button of your rocker switch. The problem with this message is, that you cannot identify which button (up/down, left/right) is pressed or released.
Is this button which sends these messages a single button or a two channel rocker switch?
I think you are the first one (or at least the first one who tells it) with these kind of problems during installation. Could you please give me some more infos regarding you system:
Which openhab version do you use 2.2 or the nightly build 2.3?
How do you install the binding? Through IoT market or manually from github?
If you used the github way, from which branch did you downloaded the binding?
The support for your NodOn 2-2-01 i really fresh and not yet tested, as I do not own these in wall switches. So you are the first one who owns such a device I know. If you want, you can send me a PM to solve this problem (I speak german).
