New standard widget: Timeline
With the 2.0.0 release behind us, new features can be added again :wink:
I’d like to ask for help testing the new standard widget I just added: the Timeline, which is basically another type of chart but with colored bars in “swimlanes” - useful to display the state of non-numerical items like switches, contacts and shutters over time.
Wait for the next snapshot build, It should be included in it.
I didn’t test it thoroughly because don’t have a lot of relevant data to graph, therefore I’m looking forward to examples of real-world uses for it (and potential issues here or on GitHub). But it’s looking quite good already :stuck_out_tongue:
The color palette can be configured per state (for the whole widget, not per item). If the state isn’t in that list, a random color is chosen.
The series are configured similarly to the Chart widget.
Enjoy!
Let’s wait the next update … I will help you testing.
Is it necessary to use any persistance ?
Yes you need a persistence service, rrd4j can store numbers, ON/OFF values and maybe others (OPEN/CLOSED etc.), but not strings. I hear influxdb works well and can store strings too.
Very useful. I will try it.
I have a very good potential use for it. To visualise the power source of the house and show the moment it will switch back to the grid from solar and battery storage. Worked without problem with influxdb.
I only have my usual concern :slight_smile: In order to use it on the tablet i need to be able to make it bigger and set the size of the labels below the timeline. Seting the height of the bar would be great as well
On my tablets they are minuscule and hard to read. from any further then 15cm.
Can someone explain me how to install it on an existing OH2 installation ? I Try to update with daily snapshot of OH2.1 but doesn’t see it in widgets menu.
sudo apt-get update the sudo apt-get upgrade did the trick
What build you are on? OH2 #771 does have it.
I use zip file for my dev environment.
Question/New Request:
  1. Possibility to set the text and bar size as request by xsherlock
  2. Possibility to add a group items instead of single item (low priority)
  3. Possibility to assign a colour for a range for example for the temperature I would like to have a range degree from blue to red.
    I.e. 0-16 °C dark blue - 16-18 light blue 18-20 dark green 20-22 green 22-24 green … 30-40 red
I added an experimental dashboard option to scale the text for all widgets in a given dashboard. There is some measurement issue with the timeline labels though (that’s why it’s experimental :stuck_out_tongue: )
You’ll find it in the dashboard tile settings, Advanced tab.
Ranges and groups, no ETA.
That would actually be a really nice Ui for a scheduler as well. Basically just working the other way around. Instead of receiving an item state sending it with the right value at the beginning of a new period/ colour.
Is that something that this widget can be refactored into?
There is a desperate need for a nice scheduler Ui.
Im just getting started with Habpanel - Wow..Amazing Job!
I want to use the Timeline widget for showing my homes power usage , similar to how @xsherlock has done.
How can set the colours so that
RED: is > 4000
Yellow is 1000 - 4000
Green is <1000
you would need to do the rule that would evaluate power use on every change. and assigne color o the item variable and then use this variable on the timeline. I do similar thing to determine the power source.
rule "Power Source check"
    Item  B_Power_PV_String1 changed or
	Item  B_Power_PV_String2 changed or
	Item  B_Power_AC_Load changed or
	Item  B_Power_Battery_Current_Sum changed
	var Number ac = B_Power_AC_Load.state
	var Number pv1 = B_Power_PV_String1.state
	var Number pv2 = B_Power_PV_String2.state
	var Number bt =  B_Power_Battery_Current_Sum.state
	var Number pv_sum = pv1.floatValue + pv2.floatValue
	if (pv_sum == 0 && bt.floatValue == 0) 			postUpdate(Power_source,"Grid")
	if (pv_sum == 0 && bt.floatValue < 0) 			postUpdate(Power_source, "Battery")
	if (ac.floatValue < pv_sum) 					postUpdate(Power_source, "Solar!")
	if ( bt.floatValue < 0 &&  pv_sum > 0) 		    postUpdate(Power_source, "Battery+Solar")
	if (ac.floatValue > pv_sum && pv_sum > 0 && bt.floatValue >= 0 ) 	postUpdate(Power_source, "Grid+Solar")
Hello!
Cool stuff!
What is missing:
  1. Ability to change series in places
  2. Ability to set a title
    Thank you!
Hi, ! is it compatible with mysql persistence ?
I guess, as long as the data is retrieved and accessible with the REST API it should work.
+1 on this.
/Mike
It seems like the timeline widget is not refreshing on its own. Can anybody else confirm this? Other widgets refresh, so I assume there is no broken data stream.
Could you add the ability to specify a title?
Yep, done.
