New Sun Synk Connect Account and Inverter Binding
Update 19 October 2025
New and improved version now available here latest .jar
Here is the pull request for openHAB 5.1.0
Update 21 Sept 2024
The binding will be included with the next 4.3 milestone. Releases
Thanks @lsiepel for your patience.
I have written a binding for the Sun Synk Connect Web services.
You can find the .jar file and the README.md at my GitHub.
This is my first binding and so I’m very much in the learning stage myself.
Please install and test if you wish and get back here with problems or feature requests.
I will do my best to assist, although can not promise to be speedy, so be patient please.
SunSynk Binding
This binding integrates the Sun Synk Connect web services.
This binding is used to connect your openHAB system with Sun Synk Connect (where you log in and find Your Inverters). The binding supports discovery via configuring your login and password in an openHAB bridge. From the binding, you will get status of your inverters and also command channels where you can control them. Since the binding uses a polling mechanism, there may be some latency depending on your setting regarding refresh time.
Sun Synk Connect
Introduction
You will require to have installed a Sun Synk inverter with a WiFi Data logger e-linter connected to the Sun Synk App or Connect. See Data Logger set up or Sun Synk Web. It is recommended, but not necessary that the “data interval” of your Gateway is set via Sun Synk Connect to 60s for best time latency. If you do not have that setting avaailable you can request it set via Sun Synk or your installer or you can ask for an User Level Access Change Request
This binding uses your Sun Synk Connect credentials to access Sun Synk’s web services via an OpenHAB Bridge (SunSynk Account). The bridge manages the account authentication and the discovery of SunSynk Inverter Things. Only the Inverter Thing is currently supported.
Acknowledgements:
Supported Things
Name Thing type Supported Thing
SunSynk Account Bridge Thing account
SunSynk Inverter Thing inverter
Discovery
  1. Add the sunsynk binding.
  2. Add a new thing of type SunSynk Account via the SunSynk Binding and configure with username and password.
  3. Go to Inbox press [+] and via the SunSynk Account start discovery [Scan] of inverters.
  4. Inverters should appear in your inbox!
The SunSynk Account bridge thing will discover connected inverters through the UI Scan service.
When using the UI Scan service all the parameters for an Inverter Thing are discovered.
  • Inverter Serial maps to the Sun Synk Connect inverter serial number
  • Inverter Name maps to the Sun Synk Connect inverter alias
  • Refresh time (advanced) default 60s; determines the interval between polls of Sun Synk Connect. A value above 60 is enforced. When setting this remember your inverter values are only published to Sun Synk Connect at the rate set by “data interval”.
The refresh rate is limited to once every 60s to prevent too many requests from the Sun Synk Connect API, although there is no rate limit, the Sun Synk data is fully refreshed at the “data interval” set in Sun Synk Connect, at best that is every 60s. This can mean the data in openHAB is more than 1 minute delayed from real-time. Commands sent (from openHAB) to Sun Synk are buffered up until the next refresh interval and as they take a while to propagate through to your inverter, some channels are not refreshed (read back) from Sun Synk Connect until the next minute.
The SunSynk Account requires the user e-mail address and password used to login to Sun Synk Connect.
  • The bridge Thing UID is of the form sunsynk:account:abcdef1234
  • The inverter Thing UID is of the form sunsynk:inverter:abcdef1234:
where and are discovered from Sun Synk Connect.
Thing Configuration
sunsynkaccount Bridge Thing Configuration
Name Type Description Default Required Advanced
email text Email address used to login Sun Synk Connect N/A yes no
password text Password to access the Sun Synk Connect account N/A yes no
sunsynk:inverter: Thing Configuration
alias text The Sun Synk Connect inverter alias N/A yes no
sn text The Sun Synk Connect inverter serial number N/A yes no
refresh integer Interval the device is polled in sec 60 yes yes
Channels
The SunSynkAccount has no channels.
The SunSynk Inverter has the following channels
Channel Type R/W Description Advanced
battery-SOC Number R Inverter battery % charge no
battery-grid-voltage Number R Battery dc electric-voltage no
battery-grid-current Number R Battery dc electric-current no
battery-grid-power Number R Battery dc electric-power no
battery-temperature Number R Battery temperature no
inverter-ac-temperature Number R Inverter ac temperature no
inverter-dc-temperature Number R Inverter dc temperature no
inverter-grid-power Number R Inverter ac electric-power no
inverter-grid-voltage Number R Inverter ac electric-voltage no
inverter-grid-current Number R Inverter ac electric-current no
inverter-solar-energy-today Number R Solar dc energy generated today no
inverter-solar-energy-total Number R Solar dc energy generated to date no
inverter-solar-power-now Number R Solar dc electric-current no
interval-1-grid-charge Switch R/W Interval 1 grid charge on/off yes
interval-1-grid-time DateTime R/W Interval 1 start grid charge time yes
interval-1-grid-capacity Number R/W Interval 1 battery charge target yes
interval-1-grid-power-limit Number R/W Interval 1 charge power limit yes
interval-2-grid-charge Switch R/W Interval 2 grid charge on/off yes
interval-2-grid-time DateTime R/W Interval 2 start grid charge time yes
interval-2-grid-capacity Number R/W Interval 2 battery charge target yes
interval-2-grid-power-limit Number R/W Interval 2 charge power limit yes
interval-3-grid-charge Switch R/W Interval 3 grid charge on/off yes
interval-3-grid-time DateTime R/W Interval 3 start grid charge time yes
interval-3-grid-capacity Number R/W Interval 3 battery charge target yes
interval-3-grid-power-limit Number R/W Interval 3 charge power limit yes
interval-4-grid-charge Switch R/W Interval 4 grid charge on/off yes
interval-4-grid-time DateTime R/W Interval 4 start grid charge time yes
interval-4-grid-capacity Number R/W Interval 4 battery charge target yes
interval-4-grid-power-limit Number R/W Interval 4 charge power limit yes
interval-5-grid-charge Switch R/W Interval 5 grid charge on/off yes
interval-5-grid-time DateTime R/W Interval 5 start grid charge time yes
interval-5-grid-capacity Number R/W Interval 5 battery charge target yes
interval-5-grid-power-limit Number R/W Interval 5 charge power limit yes
interval-6-grid-charge Switch R/W Interval 6 grid charge on/off yes
interval-6-grid-time DateTime R/W Interval 6 start grid charge time yes
interval-6-grid-capacity Number R/W Interval 6 battery charge target yes
interval-6-grid-power-limit Number R/W Interval 6 charge power limit yes
interval-1-gen-charge Number R/W Interval 1 generator charge on/of yes
interval-2-gen-charge Switch R/W Interval 2 generator charge on/of yes
interval-3-gen-charge Switch R/W Interval 3 generator charge on/of yes
interval-4-gen-charge Switch R/W Interval 4 generator charge on/of yes
interval-5-gen-charge Switch R/W Interval 5 generator charge on/of yes
interval-6-gen-charge Switch R/W Interval 6 generator charge on/of yes
inverter-control-timer Switch R/W Inverter control timer on/off yes
inverter-control-work-mode String R/W Inverter work mode 1, 2 or 3 yes
inverter-control-energy-pattern String R/W Inverter energy pattern 1 or 2 yes
Thing Configuration
sunsynk.things
Bridge sunsynk:account: xxx @ "Loft" [email= "user.symbol@domain.", password="somepassword"]{
    Thing inverter E1234567R1231234567890 @ "Loft" [alias= "My Inverter", sn= "1234567890", refresh= 60]
Item Configuration
sunsynk.items
Switch                      Interval1GridCharge         "Switch on Grid Charge for Interval 1"         {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-1-grid-charge"}
Switch                      Interval2GridCharge         "Switch on Grid Charge for Interval 2"         {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-2-grid-charge"}
Switch                      Interval3GridCharge         "Switch on Grid Charge for Interval 3"         {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-3-grid-charge"}
Switch                      Interval4GridCharge         "Switch on Grid Charge for Interval 4"         {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-4-grid-charge"}
Switch                      Interval5GridCharge         "Switch on Grid Charge for Interval 5"         {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-5-grid-charge"}
Switch                      Interval6GridCharge         "Switch on Grid Charge for Interval 6"         {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-6-grid-charge"}
Switch                      Interval1GenCharge          "Switch on Generator Charge for Interval 1"    {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-1-gen-charge"}
Switch                      Interval2GenCharge          "Switch on Generator Charge for Interval 2"    {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-2-gen-charge"}
Switch                      Interval3GenCharge          "Switch on Generator Charge for Interval 3"    {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-3-gen-charge"}
Switch                      Interval4GenCharge          "Switch on Generator Charge for Interval 4"    {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-4-gen-charge"}
Switch                      Interval5GenCharge          "Switch on Generator Charge for Interval 5"    {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-5-gen-charge"}
Switch                      Interval6GenCharge          "Switch on Generator Charge for Interval 6"    {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-6-gen-charge"}
DateTime                    Interval1GridTime           "Time for Interval 1"                          {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-1-grid-time", widget="widget:rlk_datetime_standalone"[label="Time Picker"]}
DateTime                    Interval2GridTime           "Time for Interval 2"                          {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-2-grid-time", widget="widget:rlk_datetime_standalone"[label="Time Picker"]}
DateTime                    Interval3GridTime           "Time for Interval 3"                          {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-3-grid-time", widget="widget:rlk_datetime_standalone"[label="Time Picker"]}
DateTime                    Interval4GridTime           "Time for Interval 4"                          {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-4-grid-time", widget="widget:rlk_datetime_standalone"[label="Time Picker"]}
DateTime                    Interval5GridTime           "Time for Interval 5"                          {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-5-grid-time", widget="widget:rlk_datetime_standalone"[label="Time Picker"]}
DateTime                    Interval6GridTime           "Time for Interval 6"                          {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-6-grid-time", widget="widget:rlk_datetime_standalone"[label="Time Picker"]}
Number:Dimensionless        Interval1GridCapacity       "Charge Target Interval 1"                     {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-1-grid-capacity", widget="oh-slider-card",listWidget="oh-slider-item"[title="Target SOC",subtitle="Set % SOC"]}
Number:Dimensionless        Interval2GridCapacity       "Charge Target Interval 2"                     {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-2-grid-capacity", widget="oh-slider-card",listWidget="oh-slider-item"[title="Target SOC",subtitle="Set % SOC"]}
Number:Dimensionless        Interval3GridCapacity       "Charge Target Interval 3"                     {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-3-grid-capacity", widget="oh-slider-card",listWidget="oh-slider-item"[title="Target SOC",subtitle="Set % SOC"]}
Number:Dimensionless        Interval4GridCapacity       "Charge Target Interval 4"                     {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-4-grid-capacity", widget="oh-slider-card",listWidget="oh-slider-item"[title="Target SOC",subtitle="Set % SOC"]}
Number:Dimensionless        Interval5GridCapacity       "Charge Target Interval 5"                     {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-5-grid-capacity", widget="oh-slider-card",listWidget="oh-slider-item"[title="Target SOC",subtitle="Set % SOC"]}
Number:Dimensionless        Interval6GridCapacity       "Charge Target Interval 6"                     {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-6-grid-capacity", widget="oh-slider-card",listWidget="oh-slider-item"[title="Target SOC",subtitle="Set % SOC"]}
Number:Power                Interval1GridPowerLimit     "Max Charge Power Interval 1"                  {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-1-grid-power-limit", listWidget="oh-slider-item"[title="Target Power Limit",subtitle="Set Limit in Watts", min=0, max=8000,step=1000]}
Number:Power                Interval2GridPowerLimit     "Max Charge Power Interval 2"                  {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-2-grid-power-limit", listWidget="oh-slider-item"[title="Target Power Limit",subtitle="Set Limit in Watts", min=0, max=8000,step=1000]}
Number:Power                Interval3GridPowerLimit     "Max Charge Power Interval 3"                  {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-3-grid-power-limit", listWidget="oh-slider-item"[title="Target Power Limit",subtitle="Set Limit in Watts", min=0, max=8000,step=1000]}
Number:Power                Interval4GridPowerLimit     "Max Charge Power Interval 4"                  {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-4-grid-power-limit", listWidget="oh-slider-item"[title="Target Power Limit",subtitle="Set Limit in Watts", min=0, max=8000,step=1000]}
Number:Power                Interval5GridPowerLimit     "Max Charge Power Interval 5"                  {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-5-grid-power-limit", listWidget="oh-slider-item"[title="Target Power Limit",subtitle="Set Limit in Watts", min=0, max=8000,step=1000]}
Number:Power                Interval6GridPowerLimit     "Max Charge Power Interval 6"                  {channel="sunsynk:inverter:xxx:1234567R1231234567890:interval-6-grid-power-limit", listWidget="oh-slider-item"[title="Target Power Limit",subtitle="Set Limit in Watts", min=0, max=8000,step=1000]}
Number:Dimensionless        BatterySOC                  "Battery SOC [%s]"                             {channel ="sunsynk:inverter:xxx:1234567R1231234567890:battery-SOC"}
Number:ElectricPotential    BatteryGridVoltage          "Battery Grid Voltage"                         {channel="sunsynk:inverter:xxx:1234567R1231234567890:battery-grid-voltage"}
Number:ElectricCurrent      BatteryGridCurrent          "Battery Grid Current"                         {channel="sunsynk:inverter:xxx:1234567R1231234567890:battery-grid-current"}
Number:Power                BatteryGridPdower           "Battery Grid Power"                           {channel="sunsynk:inverter:xxx:1234567R1231234567890:battery-grid-power"}
Number:Temperature          BatteryTemperature          "Battery Temperatue "                          {channel="sunsynk:inverter:xxx:1234567R1231234567890:battery-temperature"}
Number:Temperature          InverterACTemperature       "Inverter AC Temperature"                      {channel="sunsynk:inverter:xxx:1234567R1231234567890:inverter-ac-temperature"}
Number:Temperature          InverterDCTemperature       "Inverter DC Temperature"                      {channel="sunsynk:inverter:xxx:1234567R1231234567890:inverter-dc-temperature"}
Number:Power                InverterGridPower           "Inverter Grid Power"                          {channel="sunsynk:inverter:xxx:1234567R1231234567890:inverter-grid-power"}
Number:ElectricPotential    InverterGridVoltage         "Inverter Grid Voltage"                        {channel="sunsynk:inverter:xxx:1234567R1231234567890:inverter-grid-voltage"}
Number:ElectricCurrent      InverterGridCurrent         "Inverter Grid Current"                        {channel="sunsynk:inverter:xxx:1234567R1231234567890:inverter-grid-current"}
Number:Energy               InverterSolarEnergyToday    "Inverter Energy Today"                        {channel="sunsynk:inverter:xxx:1234567R1231234567890:inverter-solar-energy-today"}
Number:Energy               InverterSolarEnergyTotal    "Inverter Enery Gross"                         {channel="sunsynk:inverter:xxx:1234567R1231234567890:inverter-solar-energy-total"}
Number:Power                InverterSolarPowerNow       "Inverter Power"                               {channel="sunsynk:inverter:xxx:1234567R1231234567890:inverter-solar-power-now"}
Switch                      Interval6ControlTimer       "Switch on System Mode Timer"                  {channel="sunsynk:inverter:xxx:1234567R1231234567890:inverter-control-timer"}
String                      InverterControlWorkMode     "System Work Mode 0, 1 or 2"                   {channel="sunsynk:inverter:a1a6340bc0:E4701229R3312211229948:inverter-control-work-mode"}
String                      InverterControlPattern      "System Mode Energy Pattern 0 or 1"            {channel="sunsynk:inverter:a1a6340bc0:E4701229R3312211229948:inverter-control-energy-pattern"}
DateTime Widget
The items file above adds Metadata: Default Standalone widget: rlk_datetime_standalone to the DateTime items. Only the time portion of the DateTime item is important.
Be sure to understand the time zone set up for the inverter, this can either be synchronised with Sun Synk servers, which in the UK at least applies daylight saving, or free-wheeling locally. The times set in the DateTime items using the widget are not adjusted to any time zone and are sent to the SunSynk API as Strings where they will be applied directly to your inverter. This is in contrast to other solar / energy APIs that use Zulu (GMT) time.
Installation
Place the .jar file into your addons directory. See the “Through manually provided add-on” section of Installation of Add-ons.
Trouble Shooting
This first version of the binding has been built against 4.2.0-SNAPSHOT - Build #3989, currently its only available as a .jar file
org.openhab.binding.sunsynk-4.2.0-SNAPSHOT
Although the binding is written to find multiple Inverters for each Sun Synk Connect account, testing has been against an account with a single inverter.
Sun Synk account and inverter versions are:
  • Gateway Model EESW-D205
  • Gateway COMM Type Wi-Fi
  • Gateway HW AEW2-0005-03
  • Gateway SW 4790123B24R
  • Inverter 8.0 kW
  • Inverter Type Energy Storage
  • Inverter SW M 5.3.8.4 / S 1.5.1.5 / C E.4.3.0
  • Connect App Version 1.11.12
Debugging
After installation, to gain further information on any issues you encounter you can turn on Debug Logging either through the karaf console or through the openHAB UI.
Via Console:
log:set DEBUG org.openhab.binding.sunsynk
Via UI:
Log on to your local openHAB as admin and follow the menus.
  • Settings > Add-on-Store > Bindings
  • Scroll down to find the binding and click on its title, click the cog and select the level “Debug” on the right.
You should now be able to see debug data in the openhab.log.
Source Code
For those that are interested the source code is here.
Hi @LeeC77
Thank you for this. Good to see a Binding for SunSynk.
Just wondered if you ever considered doing all of this via ModBus? This would remove the reliance on the SunSynk cloud services (which have been a bit flaky of late)?
I have a pretty decent widget interface directly with my SunSynk via Modbus and cal poll for data at whatever interval I choose. I mostly never notice when the cloud services are unavailable (other that when they reset the time repeatedly).
Will atek a look at your binding when I get a chance out of interest.
Mark
I’ve not had too much of a problem with the web services, but it’s not quite been a year for me.
I had a quick look at the ModBus option, but could not determine the hardware that would definitely work, what do you use?
Are you able to send commands to your inverter via ModBus?
I would consider doing a Sun Synk ModBus binding if provides advantages, do you have any idea of the latency between the real-time and the ModBus Sun Synk values?
Thanks @LeeC77
I use a Waveshare USB to RS485 adapter with a network cable to my openHAB server.
The pinout is pretty simple and I can dig that up again if you need.
I have not setup any commands to send to the inverter. Though using ModBus this is certainly possible. There are a few links around about doing that.
The latency between Inverter and SunSynk is by default 5 minutes, but you can request this be reduced to 1 minute if you request that from installer/SunSync
Happy to share the modbus registers etc I use if you would like.
EDIT: As far as i have seen yiu coukd actually do add ons to modbus with specific midel support.
Would be interesting to share the pin outs and a link to the hardware thanks?
This hardware or something more capable?
Hum the ‘data interval’ I’m able to control as I have installer privilege, but I thought that just controlled the API refresh via the gateway not the inverter send / ModBus update. This one–>
So are you saying even with ModBus you don’t get closer than 1 min to the real-time values?
Are you able to use the ModBus and Gateway (e-linter) at the same time?
Hi @LeeC77
The following thread has tons of information which is what I used for the most part - other than setting up my widgets and finding more specific ModBus registers and converting them etc.
https://powerforum.co.za/topic/8646-my-sunsynk-8kw-data-collection-setup/
My cable is pinned out as follows:
1    Orange/White     --->B
8    Brown            --->B
2    Orange           --->A
7    Brown/White      --->A
3     Green/White    --->GND
That is the hardware I am using. Also linked in the thread above.
Sorry, no that is not what I meant… Using ModBus you can poll the inverter as often as you like. Though I did find that if you poll too often that some responses get missed. You can also poll at different rates for different registers. I use anything from 30 seconds to 60 minutes - depending on the value
So glad you are ok too look into the modbus route.
Some samples of my widgets:
SunSynk Widget
The problem for me with the USB to RS485 is the need to have CPU with USB support close to the inverter. I think, if I was to do this, I would be more likely to use ethernet to RS485. May be
USR-TCP232-306 Serial to Ethernet Converter Lan Ethernet TCP/IP to RS232 RS485 RS422 Converter
or
Waveshare RS232/485/422 to RJ45 Ethernet Module, TCP/IP to Serial, with POE Function, Bi-directional Transparent Transmission, Suitable for Data Acquisition, Intelligent Instrument Monitoring
or
Waveshare RS485 to Ethernet Converter
Anyone have any experience with these devices?
I have completed the initial implementation of the SunSynk Connect Binding:
I’m a little late to the party here, but have installed the SunSynk Connect binding from the market place (v4.3.5) and added all items (including the advanced ones) and it’s nearly working perfectly. Many thanks!!
The issue I have is that all the items have values, apart from
  • Battery Current
  • Battery Power
  • Battery Voltage
which are all just showing as NULL. I can happily live without the battery voltage, but the power and current are really needed, Any suggestions?
Also there is an item for Solar Power (Amps), but not the Wattage - can this also be accessed through the binding?
Hi Dave
Great you have installed the Sunsynk Connect Binding. I note your issue and will work with you to try to resolve. Just to ensure expectations are all aligned, I have a lot on so it may take a while for me to progress this with you.
So let’s kick off with some questions.
  1. Is the binding giving any errors in the log viewer?
  2. What type of Sunsynk Connect account do you have?
  3. How many inverters do you have?
  4. How do you access your battery values in Sunsynk Connect; Login, select ‘Equipment’ icon at the bottom banner, then select your inverter, then ‘Battery’ on the top menu?
  5. Can you access the values you need there on the Connect App below charts?
  6. Please can you screen shot one of these charts?
  7. Please can you send me the channel details for each failing item? You could screen shot this.
  8. On the Solar Amps question, I may not have exposed that data if it exists as my setup isn’t DC coupled. Again send me a screenshot shot of the parameter in the Connect App and we can start there. As testing this may require account access or test builds I suggest we try to resolve this after the battery items issue.
Happy if you want to DM responses.
Thanks for the reply, my apologies for not replying sooner but I did not see an email for the reply.
No - The Account and the Inverter things are connected and online and I do not see any errors in the log viewer
Not sure, I had not realised that there were different ones? I downloaded the SunSynk connect app on my phone and created the account / plant from there. The data logging is done with a WiFi Data Logger attached to he inverter
Only the one currently: a SYNK-3.6K-SG04LP1, attached to 1 SunSynk-W5.3 battery
Yes. It shows me Power (W), SOC (%), Current (A), Voltage (v), Battery Temp (C) and then other addition information which is probably not required on Charge and Discharge Limits, Battery Alerts. The App shows ‘Master’ and ‘Pack’ under the Battery heading (these show slightly different values which is strange as I believed the ‘Master’ was the overall stats and the ‘Pack’ was for each battery installed.)
Yes.
Thanks, although this may not be required is I can get the power readings from both he the battery and solar separately, as then I will be able to determine the power flow correctly.
Hi Dave
Thanks for the responses. The channel details were most illuminating.
There is a bug in the binding itself, That’s what you get when the only person to test the code is yourself. So Thanks for being a Beta tester :smiling_face: . I can fix this when I have time, but the fix will go into the next release of openHAB. I notice you said you are on 4.3.5 so you would need to move up to 5.1 on release.
If I have time I’ll see if I can do a test build against OH 5.0, never done that before; a new learning curve for me. Then you could test the new binding, if I implement some specific trace logging we should be able to add that solar Amps for you also.
At the moment I request a realtime data reponse from the inverter that includes solar parameter, but as I do not have solar panels connected I do not get a fully populated response it would be useful to see a populated response. Here are the parameters that are in the response so far.
@SuppressWarnings("unused")
class Data {
    private int pac;
    @SerializedName("grid_tip_power")
    private String gridTipPower = "";
    private double etoday;
    private double etotal;
    private List<PVIV> pvIV = new ArrayList<PVIV>();
    private List<MPPTIV> mpptIV = new ArrayList<MPPTIV>();
private class PVIV {
    private String id = "";
    private int pvNo;
    private double vpv;
    private double ipv;
    private double ppv; // sum for all power
    private double todayPv;
    private String sn = "";
    private String time = "";
It looks like MPPTIV is not returning a response, perhaps your inverter will.
I’m guessing you need vpv and ipv in addtion to the sum of ppv. If I can make you an OH 5.0 test binding you can use the trace level of logging to work out what parameters you need.
How do you want to do this?
Lee,
Many many thanks - I really do appreciate your assistance and updating of the binding.
Yes, at present my OpenHAB is a 4.3.5 Release Build and I have not yet done the migration to OpenHAB 5, however I could set up a new instance on another Pi with OH5 so that any changes could be tested in the mean time - would that help?
All updates should be in the 5.1.0 update.
Pull Request now merged.
Breaking changes have been made to the Sun Synk Connect server.
Sun Synk have released a new App that uses the same server, as a consequence (since Thursday 13th November) the client application now needs to authorise before user credential can be submitted for login authorisation.
Note: If your sunsynk account Thing is already logged in I believe it will continue to operate until its session expires (e.g. the sunsynk account Thing is modified or re-enabled or Sun Synk server goes offline) If its not broken don’t touch it until the pull request has completed.
I have add a new openHAB.jar for testing.
Afternoon Lee,
Have replaced the .jar with the new testing 5.0.0 version and the account comes back online, however the Inverter will not initialize, and errors with:
Registration resp. initialization of child 'sunsynk:inverter:866a4013d8:E47W248005422502132030' of bridge 'sunsynk:account:a46ea9a7a6' has been failed: Duplicate channels sunsynk:inverter:866a4013d8:E47W248005422502132030:inverter-grid-frequency
Any ideas? Many thanks.
Looks like the id of the inverter and sunsynk account are incorrect. Establish what you originally did by looking at the channel details of your items. Do they match your inverter: 866a4013d8:E47W248005422502132030.
Note: the first part of the id ( here: 866a4013d8) should be the Thing Id of the sunsunk account Thing and the second part the Inverter and gateway Id is from Sunsynk Connect.
If the account doesn’t match your channel details then removed the account Thing and Inverter Thing ( and any duplicates) and start again but give the account the correct id (from your item channel details)
Run discover again to find your inverter E47W248005422502132030.
It should come back online and connect to your items.
Lee,
Thanks. In the end had to remove all Items & Things, clear the cache and then start again. Account came back online without any issues and inverter was found. Inverter no longer has the channel/item for inverter capacity, but otherwise everything else looks like its working again.
Is now called “Inverter Rated Output” and the channel data looks like
sunsynk:inverter:xxxxxx:Exxxxxxxx:inverter-rated-ac-output
I’m aware of another breaking change rolled out last night to the log in procedure of Sun Synk Connect. I have being testing a prototype.
Note: If your sunsynk account Thing is already logged in I believe it will continue to operate until its session expires (e.g. the sunsynk account Thing is modified or re-enabled or Sun Synk server goes offline) If its not broken don’t touch it.
Here is the pull request to fix it.
There is a new openHAB.jar for testing please feed back any issues.
Morning @LeeC77
Have been using the binding for quite some time now, as you are aware, and it has been working without a fault to get the values / log / display / etc however I am now trying to create some rules so that during ‘PeakSave’ events the system will change to allow charging from the Grid as the power is slightly less expensive. I am trying to change the grid charge and charge target via DSL rule with:
  SunSynk_Inverter_Interval_4_Grid_Charge.postUpdate(ON)
  SunSynk_Inverter_Interval_4_Charge_Target.postUpdate(100)
And can see that the Log file shows that these are changed without an issues, howeve the change does not appear to be propergated to the Inverter and as soon as the refresh period occurs the values in OpenHAB revert back to the previous values.
Extract from the log:
info_circle 09:42:52.365	INFO
openhab.event.ItemStateChangedEvent
Item 'SunSynk_Inverter_Interval_4_Grid_Charge' changed from OFF to ON
info_circle 09:42:52.367	INFO
Item 'SunSynk_Inverter_Interval_4_Charge_Target' changed from 15 % to 100 %
info_circle 09:43:23.520	INFO
Item 'SunSynk_Inverter_Interval_4_Grid_Charge' changed from ON to OFF
info_circle 09:43:23.525	INFO
Item 'SunSynk_Inverter_Interval_4_Charge_Target' changed from 100 % to 15 %
Any ideas? Thanks.
