a new Telegram Action is now available. It allows sending messages to chats in Telegram (https://telegram.org)
Documentation is available in the wiki page
I have implemented and tested the action. It works great but I would like to report a bug:
When I have a German Umlaut in the message I want to send, the message won’t be delivered with an error in the log
2015-12-10 19:05:43.521 [WARN ] [o.a.telegram.internal.Telegram] - Method failed: HTTP/1.1 400 Bad Request
Best regards,
Jens
Te API says it needs UTF-8 encoding. Perhaps something needs to be added to the HTTP request header?
Hi Jens,
I will address the issue as soon as possible. I guess the problem will appear with every “extended” unicode character.
A fix has been posted: [Telegram action] UTF-8 messages bug fix by paolodenti · Pull Request #3533 · openhab/openhab1-addons · GitHub
rule "Send telegram with Fixed Message"
Item Light_FF_Bed_Ceiling changed
sendTelegram("bot1", "item Light_FF_Bed_Ceiling with umlaut Ă„ changed")
And merged, should be in tonight’s jenkins build. Could you please retest with the next build?
I would love to test it.
Where can I find the ready to use addon?
Thanks.
You should download the addons bundle. It is a zip file containing the telegram action.
Hi Paolo,
I have configured openhab.cfg and created a rule according to the wiki.
I have struggled finding the right zip (I am running 1.7.1, which does not contain telegram in the addons.zip).
Anyway, I found it in 1.8.0 and checked it out.
By the way, my “chat” ID is the same like my “from” ID on https://api.telegram.org/bot…
Is this always the case?
And I get an error in the openhab.log:
In general my confusion is related to “botname” “botusername” (I have chosen both to be the same ;-). Which one to define in openhab.cfg.
Furthermore the botusername in my telegram App (iPhone) is named “@MYBOTUSERNAME”.
So what is the right one to choose?
Apart from the correct addon version, 1.7, 1.8, … (about which I cannot help you, telegram action is just included in 1.8 and later …) you should just follow the instruction written here: Actions · openhab/openhab1-addons Wiki · GitHub
Just follow step by step in order to get your token and chatId, it is very easy to get the telegram token and chatId
The bot name in the openhab.cfg can be any name. And that will be used as first parameter for the sendTelegram method.
Thanks for your quick response.
Actually I followed the step by step thoroughly and I got the token and chatID.
So you mean, just adding the org.openhab.action.telegram-1.8.0-SNAPSHOT.jar to my distribution-1.7.1 will not work?
Honestly, I would be very very surprised if this did work. But then again, I have seen stranger things ![]()
If you want to experiment with the daily builds, please download the 1.8.0-SNAPSHOT archive from https://openhab.ci.cloudbees.com/job/openHAB/
If not, @teichsta proposed a tentative schedule for the 1.8.0 release, please read about it at his posting at Upcoming 1.8 Release
Hi Hakan,
I would like to test the snapshot, but I am afraid, that I mess my system up completely. ![]()
Before I start trying, I need to clone my micro SD.
Thanks for your help.
I will also check out the official release discussion.
I don’t know why placing org.openhab.action.telegram-1.8.0-SNAPSHOT.jar in your openHAB 1.7.1 runtime’s addons folder would be a problem. It ought to work under usual circumstances. Your openHAB Designer from 1.7.1 won’t consider it a valid action, but you can ignore that complaint in Designer.
OH Designer is not the problem (currently I use 1.8. designer as well and it recognizes the “sendTelegram” action).
However after Telegram bot configuration I get the following message in openhab.log.
Any idea?
probably wrong chatid or token, hard to say without additional information.
how do you call sendTelegram? by a rule? can you post the rule?
Same here,
My rule:
rule “Send telegram with Formatted Message”
Item TemperaturaEnergy changed
sendTelegram(“bot1”, “prova prova”)
Are you sure that configuration is correct? Here all is working fine.
