I configured thing in PaperUI, because didn’t found syntax for textual configuration at the binding site.
But would be interested too
Thing telegram:telegramBot:gbot "Telegram" @ "Internet" [chatIds="xxxxx", botToken="yyyyy", parseMode="Markdown"]
and
String Telegram_MessageText "Last Message Text [%s]" { channel = "telegram:telegramBot:gbot:lastMessageText" }
DateTime Telegram_MessageDate "Last Message Date [%1$td.%1$tm.%1$tY, %1$tH:%1$tM]" { channel = "telegram:telegramBot:gbot:lastMessageDate" }
String Telegram_MessageName "Last Message Name [%s]" { channel = "telegram:telegramBot:gbot:lastMessageName" }
String Telegram_MessageUser "lastMessageUsername [%s]" { channel = "telegram:telegramBot:gbot:lastMessageUsername" }
String Telegram_ChatID "Chat ID [%s]" { channel = "telegram:telegramBot:gbot:chatId" }
String Telegram_ReplyID "Reply ID [%s]" { channel = "telegram:telegramBot:gbot:replyId" }
With more than one chat Id: Komma separated?
For me this worked with multiple chat Ids:
Thing telegram:telegramBot:bot1 "Telegram Bot" [ botToken="token", chatIds="123","456", parseMode="Markdown" ]
Thanks a lot.
If it works finde, ich hope I will remember to put Example in Binding-Documentation Site
As far as i understand the binding compared to the action, i can only add one bot, right?
I could use one bot with multiple chatIds but that would send the message to both chats when just using telegramAction.sendTelegram("<message>")
So i need to use the chatId everytime i want to send a message to only one chat.
Is there any smarter way for this?
I already tried to create an val String bot1 = <chatID>
but i´m not able to use it in telegramAction.sendTelegram(bot1, "<message>")
It was a lot easier to build a rule with sendTelegram actions compared to the new binding
You can use a variable for chat I’d as long value.
var long NameChatId = 12345L
Then use NameChatId as variable to send
is the L character required after the chatid?
edit: ahh it is.
Is there a way to add a port to the image URL?
I always get the following error message when using an image URL with a port:
2020-02-19 22:08:08.310 [WARN ] [binding.telegram.bot.TelegramActions] - Download from http://192.168.178.91:18188/ipcamera.jpg failed with exception: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: bad response on HttpConnectionOverHTTP@b2d0d8::SocketChannelEndPoint@a92176{/192.168.178.91:18188<->/192.168.178.91:40426,OPEN,fill=-,flush=-,to=15/0}{io=0/0,kio=0,kro=1}->HttpConnectionOverHTTP@b2d0d8(l:/192.168.178.91:40426 <-> r:/192.168.178.91:18188,closed=false)=>HttpChannelOverHTTP@da3e61(exchange=HttpExchange@1ca6a0e req=TERMINATED/null@null res=PENDING/null@null)[send=HttpSenderOverHTTP@19cf9e0(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@bdc574{s=START}],recv=HttpReceiverOverHTTP@129c534(rsp=IDLE,failure=null)[HttpParser{s=CLOSE,0 of -1}]]
I am using the below rule:
rule "Gefrierschrank Timer"
Item ug_tuer_gefrier_Timer received command OFF
val telegramAction = getActions("telegram","telegram:telegramBot:abcd")
logWarn("Gefrierschrank","Gefrierschrank seit 3 Minuten offen!")
ug_tuer_gefrier_3min_offen.sendCommand(ON)
telegramAction.sendTelegramPhoto("http://192.168.178.91:18188/ipcamera.jpg", "Gefrierschrank ist seit 3 min offen")
Thank you!
Hi, im using this binding for sending WeatherIcons with Description.
Now I’am wondering that using Markup or Html is not working in this additional Textes.
Is this not working in general from TelegramAPI for sending Photos or is it not implemented.
May someone check this?
I updated to the latest version of the binding and now it is working properly.
Thanks guys, this is really cool that telegram binding!
Just started using it and I would like to use a triggeringItem.name when sending the text message.
Is this possible, cause I can´t find this in the binding description.
What would be the correct usage?
like:
val telegramAction = getActions(“telegram”,“telegram:telegramBot:xxxx”)
telegramAction.sendTelegram(“triggeringItem.name”)
Maybe it should be somehow like
telegramAction.sendTelegram("Movement triggered on", triggeringItem.name.toString)
Try this:
telegramAction.sendTelegram("Movement triggered on" + triggeringItem.name.toString)
Just tried this but no success.
The message gets send but the part for triggeringItem.name gets ignored.
Tried also without the+ and without toString, but in all cases no triggeringItem.name
Does the binding support this functionality?
In parallel in the same rule I use the mail binding, here all working perfectly
You only send one line, the syntax I wrote is ok, but seems truggeringItem.name is empty then. Please post full rule
Hi, got it working, must be
telegramAction.sendTelegram(“Movement triggered on %s” triggeringItem.name)
I think such an example could be added to the official description as well, I wasn’t able to understand the current description of the new binding delivering this information.
I’m trying to configure the new binging on OH 2.5.2 using Paper UI … but, after editing all attributes (Think ID, Bot token, Chat id and Parse mode) … the blue “Add” button is disabled (!)
What’s my mistake ?
Can anyone post a “telegram.things” file example ?
Thanks.
You have to press the enter after you entered the ChatId.
Oh, yes !
Sorry.
