Is it possible to send a silent message?
The Telegram API has an Option for this called disable_notification
Description:
This would be great!
However I think it is needed to change the code (the called URL for thisā¦).
@ZzetT Iām happy to look into this if you donāt want to.
I do have the new telegram binding setup and everything seems working fine.
Now my problem when I do restart my pi3b on OH2.5.2, e.g. when changed some rules or items suddenly the telegram messages arenāt send any more, when restarting again it might work or not, this is strange and I cannot find an error.
I do activate the telegram send activity with a dummy switch, but as I said sometimes it is working next restart it isnāt.
Anyone having similar problems?
I think I donāt understand, what can I do to get it stable running, the binding is the newest version.
Can I influence the behavior for the proper start of that binding or action?
Itās not entirely clear to me the circumstances that will cause a binding to restart, but when it does restart, the actions will stop working. When this happens, the only solution Iāve found is a restart of openHAB. I wish I had some better advice for you on how to prevent it.
I find this to be a REALLY annoying problem, because it usually happens silently. The only way I notice it is when I stop getting emails and telegrams. Unfortunately, since it needs to be fixed in openhab-core, it wonāt be resolved until OH3.
Yes, this is true I do have the same issue with emails sending getting stopped.
This is strange.
Something strange occured today - Iāve upgraded to latest stable OH and wanted to switch from textual config to PaperUI-config.
The thing is āonlineā and I can retrieve messages that Iām writing in the corresponding chatID. But, anything that is āoutboundā doesnāt work. Iāve declared the exact same parameters as in my textual config, but no success.
For testing purposes I adapted my textual config and put the thingID OH has created for the thing - this works as intended.
Whatās also āstrangeā is that the PaperUI-config doesnāt seem to accept a āNO socketā option as it always resets/defaults to SOCKS5 - I can avoid that via textual config of course.
I have a question for a rule.
With the preview telegram action, I can send a telegram message when a item is over a precise numeric value using item.state > x .
With a new telegram binding donāt work.
What is the correct syntax for send a message when a numeric item is over a determinate value?
Thanks.
Please Post your rule here, because the only change is the syntax of telegram.Action
If item.state > x is still the same
Thanks for the answer.
I have a sensor (myitem) and when the temperature is over x I would receive a telegram message.
With the telegram action I had:
When the myitem changed then if myitem.state > x Telegram send message, but with the new binding not work.
Only with numeric variable not work because with the ON / OFF variable work correctly.
Thanks.
Again: please post your rule here.
Without seeing your syntax nobody is able to help
I try with this rule, but donāt work:
rule āNAME"
Item Sensor changed
if(Sensor.state > VALUE) {
val telegramActionā¦.
telegramAction.sendTelegramā¦.
Thanks.
Its only a part of your rule. How to check syntax if you donāt paste your rule.
Your item is which type?
Value written like 2 ? Or written like 2.0 or written like ā2ā ?
Because looks like you donāt want to show what you did in rule I only can give you the hint to check with loginfo if comparison works and your If gives a true or not.
I think you have some log entries too due to a type mismatch.
But unable to help anymore with cutted parts of rule.
Sorry.
Try if(Sensor.state as number > VALUE) {
Then Iām out. To heavy to guess what you written
Thanks for the suggestion, later I try.
I paste my syntax, but I write VALUE because I have 2 cases.
The first is a temperature sensor and I write 22.5 and the other case is a power consumption value and I write a integer value.
Both the Items are number type.
I didnāt check if I had error in the log file but after I will check.
Thanks.
I find the mistake, in the rules file I write Item Item (double) in a other rule, deleted the word āItemā extra and all rules work correctly without your syntax.
Thanks.
That was the reason I wanted to see the original code
Another question, I test a rule when the Bot receive a message and work correctly.
How can I do for receive into the answer the state or the value of items?
Do you have an example for me? For example when I write Temperature openhab sent a temperature of the sensor.
Thanks.
Hi, I upgrade to 2.5.3 and install the official Telegram binding.
The sendTelegram seems work but I have the following warn message:
[ng.telegram.internal.TelegramHandler] - Telegram exception: GetUpdates failed with error_code 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
With 2.4 and beta binding I never had.
Can you help understanding whatās wrong?
Regards
Lorenzo
