I am running the OH2.5 binding very well with the given version…
Now I am on “OH3.1 stable” with openhabian and on a Raspberry Pi 2 and would like to try the nibeuplinkrest binding given by the link in this post.
Unfortunately there is the following error when starting the bundle:
2021-09-12 21:14:03.746 [ERROR] [Events.Framework ] - FrameworkEvent ERROR
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.nibeuplinkrest [284]
Unresolved requirement: Import-Package: javax.measure; version="[1.0.0,2.0.0)"
at org.eclipse.osgi.container.Module.start(Module.java:463) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1845) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1838) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1781) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1743) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1665) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) [org.eclipse.osgi-3.16.200.jar:?]
And some seconds later:
2021-09-12 21:14:10.751 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab/addons/org.openhab.binding.nibeuplinkrest-3.1.0-SNAPSHOT.jar
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:440) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [bundleFile:3.6.8]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [bundleFile:3.6.8]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) [bundleFile:3.6.8]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) [bundleFile:3.6.8]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.6.8]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.6.8]
OH 3.1 updated the Units of Measurement library, but it seems like it’s trying to use the old version, which is strange. Perhaps the uploaded build is an older one, since before the change, but I don’t believe so. I’ll make a new build and upload it just to make sure, but it’ll have to wait until tomorrow.
I have made a new build against 3.2.0-SNAPSHOT, which hopefully should work in 3.1, don’t think there are any other changes in dependencies that could cause troubles. Let me know if it works!
I suspect that the old version is still there, which can cause the new one not to start. If that’s the case, note the bundle id (the first column) of the two versions and run
bundle:uninstall <old version id>
bundle:restart <new version id>
Then make sure to delete the old jar from the addons directory to prevent issues on the next reboot.
The binding is now published in the new Add-on Marketplace so it can be installed more easily!
Make sure you uninstall the old version first, (bundle:uninstall org.openhab.binding.nibeuplinkrest and remove the jar from the addons directory) otherwise the installation will fail.
Hi @pacive , thanks for the amazing add-on, I’ve managed to set it up successfully. Only, my setup is a SMO40 with a F2040 outdoor unit. The addon currently seems to only present the SMO40 as a Thing in OH. How could I add the outdoor unit as a separate Thing? I would love to be able to monitor the compressor start info that I can see in the Nibe Uplink UI, where it is presented as a slave unit to the SMO40.
A quick question. Does this binding support the S-series (I have a NIBE S1155) heat pumps or is there another way to connect to myuplink.com which as I understand it is a bit different from nibeuplink.com?
Unfortunately no, as you say they have a different API. It could probably be made to work, but I wouldn’t have any possibility to test it against a real system.
Let me know if you would be interested in some kind of collaboration. I have one in operation and another one soon to be installed so there are definitely pumps available to test on. I have some developer background but nothing around bindings. Is it complicated to set up a development environment?
There are good guides in the openhab docs for how to set everything up. What can be a bit of a learning curve is to learn how to use the oh core apis to make everything work, but once you get a hang of that it’s mostly like any other programming.
I have managed to get a developer account at myuplink, so I can see the different endpoints and such, but without a real system to test against it’s quite difficult to implement anything.
If you would like to try and add it to my binding you are very welcome, and I’ll help you with any questions and refactorings that might be necessary!
Is that when trying to access the page for the first time, or during the authorization flow? Is your openHAB instance accessible on port 8080? (if you remove nibeuplinkconnect from the url?)
