Well that was my best guess. I did delete the Operations Mode for the next ZW DB update because it is confusing.
You could probably work around this with a rule(s). I use time of day (or vacation, work) to change the setpoint. According to the manual both eco and heat have the same range.
Edit: also added the Manual option (0x1F) which should allow the dimmer to control the valve % and changed the power alarm to a battery alarm so it will work.
EDIT2: You could try overwriting this modified file to your Zwave binding, but I’m not optimistic since the test didn’t work.
EDIT: Readded a basic switch to maybe allow for Eco or Heat based on the manual options.
cometz_11_0.xml (9.3 KB)
