"No enum constan error" for new Comet Z-Wave Radiator controller
I am just wondering why the heck I have Dimmer channel for the heat controller?
I did connect other channels and try to operate with them.
  1. I am surprised about Dimming Channel in this Thing
  2. Setpoint Eco has following options (???):
  3. Activating Heat mode and changing the set temperature does not influence controller change. There is still the same set temp. displayed. And vice versa. Changing the temperature directly on the controller does not update Setpoint Heat value.
Is there something with the OH configuration files?
@apella12 the file you shared is this something related to the new Comet Z-Wave configuration?
The solution is a little bit complicated to mee. If this is going to be introduced in the new update I could wait…
2024-02-14 18:09:41.348 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Command received zwave:device:0f5fc641be:node49:basic_thermostat_mode --> 1 [DecimalType]
2024-02-14 18:09:41.349 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Received command zwave:device:0f5fc641be:node49:basic_thermostat_mode was converted --> ON [OnOffType]
2024-02-14 18:09:41.350 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 49: Creating new message for application command BASIC_SET
2024-02-14 18:09:41.350 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY NOT required on COMMAND_CLASS_BASIC
2024-02-14 18:09:41.351 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Command Class COMMAND_CLASS_BASIC is NOT required to be secured
2024-02-14 18:09:41.351 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Bump transaction 37268 priority from Set to Immediate
2024-02-14 18:09:41.352 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Adding to device queue
2024-02-14 18:09:41.352 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Added 37268 to queue - size 7
2024-02-14 18:09:41.354 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 49: Sending REQUEST Message = 01 0A 00 13 31 03 20 01 FF 25 FA D5
2024-02-14 18:09:41.357 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Polling initialised at 86400 seconds - start in 1500 milliseconds.
2024-02-14 18:09:41.365 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 49: sentData successfully placed on stack.
2024-02-14 18:09:41.366 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: TID 37268: Transaction not completed
2024-02-14 18:09:42.798 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 49: SendData Request. CallBack ID = 250, Status = Transmission complete and ACK received(0)
2024-02-14 18:09:42.798 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
2024-02-14 18:09:42.799 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Response processed after 1444ms
2024-02-14 18:09:42.799 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: TID 37268: Transaction completed
2024-02-14 18:09:42.800 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: notifyTransactionResponse TID:37268 DONE
2024-02-14 18:09:42.800 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2024-02-14 18:09:42.856 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Polling...
2024-02-14 18:09:42.857 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Polling skipped for zwave:device:0f5fc641be:node49:basic_thermostat_mode on COMMAND_CLASS_BASIC
2024-02-14 18:09:42.857 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Polling zwave:device:0f5fc641be:node49:sensor_temperature
2024-02-14 18:09:42.857 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 49: Generating poll message for COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
2024-02-14 18:09:42.858 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 49: Creating new message for command SENSOR_MULTILEVEL_GET
2024-02-14 18:09:42.858 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY NOT required on COMMAND_CLASS_SENSOR_MULTILEVEL
2024-02-14 18:09:42.859 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Command Class COMMAND_CLASS_SENSOR_MULTILEVEL is NOT required to be secured
2024-02-14 18:09:42.859 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Polling zwave:device:0f5fc641be:node49:thermostat_mode
2024-02-14 18:09:42.859 [DEBUG] [nverter.ZWaveThermostatModeConverter] - NODE 49: Generating poll message for COMMAND_CLASS_THERMOSTAT_MODE, endpoint 0
2024-02-14 18:09:42.860 [DEBUG] [lass.ZWaveThermostatModeCommandClass] - NODE 49: Creating new message for application command THERMOSTAT_MODE_GET
2024-02-14 18:09:42.860 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY NOT required on COMMAND_CLASS_THERMOSTAT_MODE
2024-02-14 18:09:42.860 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Command Class COMMAND_CLASS_THERMOSTAT_MODE is NOT required to be secured
2024-02-14 18:09:42.861 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Polling zwave:device:0f5fc641be:node49:thermostat_setpoint_heat
2024-02-14 18:09:42.861 [DEBUG] [ter.ZWaveThermostatSetpointConverter] - NODE 49: Generating poll message for COMMAND_CLASS_THERMOSTAT_SETPOINT, endpoint 0
2024-02-14 18:09:42.861 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Polling zwave:device:0f5fc641be:node49:thermostat_setpoint_furnace
2024-02-14 18:09:42.862 [DEBUG] [ter.ZWaveThermostatSetpointConverter] - NODE 49: Generating poll message for COMMAND_CLASS_THERMOSTAT_SETPOINT, endpoint 0
2024-02-14 18:09:42.862 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 49: Creating new message for application command THERMOSTAT_SETPOINT_GET (Furnace)
2024-02-14 18:09:42.862 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY NOT required on COMMAND_CLASS_THERMOSTAT_SETPOINT
2024-02-14 18:09:42.863 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Command Class COMMAND_CLASS_THERMOSTAT_SETPOINT is NOT required to be secured
2024-02-14 18:09:42.863 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Polling zwave:device:0f5fc641be:node49:battery-level
2024-02-14 18:09:42.863 [DEBUG] [rnal.converter.ZWaveBatteryConverter] - NODE 49: Generating poll message for COMMAND_CLASS_BATTERY endpoint 0
2024-02-14 18:09:42.864 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY NOT required on COMMAND_CLASS_BATTERY
2024-02-14 18:09:42.864 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Command Class COMMAND_CLASS_BATTERY is NOT required to be secured
2024-02-14 18:09:42.865 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Bump transaction 37269 priority from Get to Immediate
2024-02-14 18:09:42.865 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Adding to device queue
2024-02-14 18:09:42.865 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Added 37269 to queue - size 7
2024-02-14 18:09:42.867 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 49: Sending REQUEST Message = 01 0B 00 13 31 04 31 04 01 00 25 FB 38
2024-02-14 18:09:42.868 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Bump transaction 37270 priority from Get to Immediate
2024-02-14 18:09:42.869 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Adding to device queue
2024-02-14 18:09:42.869 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Added 37270 to queue - size 7
2024-02-14 18:09:42.870 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Bump transaction 37271 priority from Get to Immediate
2024-02-14 18:09:42.870 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Adding to device queue
2024-02-14 18:09:42.871 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Added 37271 to queue - size 8
2024-02-14 18:09:42.872 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Bump transaction 37272 priority from Get to Immediate
2024-02-14 18:09:42.872 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Adding to device queue
2024-02-14 18:09:42.872 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Added 37272 to queue - size 9
2024-02-14 18:09:42.878 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 49: sentData successfully placed on stack.
2024-02-14 18:09:42.878 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: TID 37269: Transaction not completed
2024-02-14 18:09:42.934 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 49: SendData Request. CallBack ID = 251, Status = Transmission complete and ACK received(0)
2024-02-14 18:09:42.935 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
2024-02-14 18:09:42.935 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: TID 37269: Transaction not completed
2024-02-14 18:09:43.015 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
2024-02-14 18:09:43.015 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
2024-02-14 18:09:43.016 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
2024-02-14 18:09:43.016 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY NOT required on COMMAND_CLASS_SENSOR_MULTILEVEL
2024-02-14 18:09:43.017 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_SENSOR_MULTILEVEL V10 SENSOR_MULTILEVEL_REPORT
2024-02-14 18:09:43.017 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 49: Sensor Type = Temperature(1), Scale = 0
2024-02-14 18:09:43.017 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 49: Sensor Value = 19
2024-02-14 18:09:43.018 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2024-02-14 18:09:43.018 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_MULTILEVEL, value=19
2024-02-14 18:09:43.019 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Updating channel state zwave:device:0f5fc641be:node49:sensor_temperature to 19 °C [QuantityType]
2024-02-14 18:09:43.021 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
2024-02-14 18:09:43.021 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@72406a.
2024-02-14 18:09:43.022 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@72406a.
2024-02-14 18:09:43.023 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: notifyTransactionResponse TID:37269 DONE
2024-02-14 18:09:43.023 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2024-02-14 18:09:43.029 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 49: Sending REQUEST Message = 01 09 00 13 31 02 40 02 25 FC 4D
2024-02-14 18:09:43.040 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 49: sentData successfully placed on stack.
2024-02-14 18:09:43.041 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: TID 37270: Transaction not completed
2024-02-14 18:09:43.149 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 49: SendData Request. CallBack ID = 252, Status = Transmission complete and ACK received(0)
2024-02-14 18:09:43.149 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
2024-02-14 18:09:43.150 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: TID 37270: Transaction not completed
2024-02-14 18:09:43.226 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
2024-02-14 18:09:43.226 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
2024-02-14 18:09:43.227 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_THERMOSTAT_MODE, endpoint 0
2024-02-14 18:09:43.227 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY NOT required on COMMAND_CLASS_THERMOSTAT_MODE
2024-02-14 18:09:43.227 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_THERMOSTAT_MODE V1 THERMOSTAT_MODE_REPORT
2024-02-14 18:09:43.228 [DEBUG] [lass.ZWaveThermostatModeCommandClass] - NODE 49: Thermostat Mode report, value = 1
2024-02-14 18:09:43.228 [DEBUG] [lass.ZWaveThermostatModeCommandClass] - NODE 49: Thermostat Mode Report, value = Heat
2024-02-14 18:09:43.228 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2024-02-14 18:09:43.229 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_THERMOSTAT_MODE, value=1
2024-02-14 18:09:43.229 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Updating channel state zwave:device:0f5fc641be:node49:thermostat_mode to 1 [DecimalType]
2024-02-14 18:09:43.230 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
2024-02-14 18:09:43.230 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1f02785.
2024-02-14 18:09:43.231 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1f02785.
2024-02-14 18:09:43.232 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: notifyTransactionResponse TID:37270 DONE
2024-02-14 18:09:43.232 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2024-02-14 18:09:43.237 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 49: Sending REQUEST Message = 01 0A 00 13 31 03 43 02 07 25 FD 4A
2024-02-14 18:09:43.248 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 49: sentData successfully placed on stack.
2024-02-14 18:09:43.249 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: TID 37271: Transaction not completed
2024-02-14 18:09:43.359 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 49: SendData Request. CallBack ID = 253, Status = Transmission complete and ACK received(0)
2024-02-14 18:09:43.359 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
2024-02-14 18:09:43.360 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: TID 37271: Transaction not completed
2024-02-14 18:09:43.439 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
2024-02-14 18:09:43.439 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
2024-02-14 18:09:43.440 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_THERMOSTAT_SETPOINT, endpoint 0
2024-02-14 18:09:43.440 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY NOT required on COMMAND_CLASS_THERMOSTAT_SETPOINT
2024-02-14 18:09:43.441 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_THERMOSTAT_SETPOINT V1 THERMOSTAT_SETPOINT_REPORT
2024-02-14 18:09:43.441 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 49: Thermostat Setpoint report Scale = 0
2024-02-14 18:09:43.442 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 49: Thermostat Setpoint Value = 0E+1
2024-02-14 18:09:43.442 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 49: Unknown Setpoint Type = 0, ignoring report.
2024-02-14 18:09:43.442 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
2024-02-14 18:09:43.443 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@39ba1.
2024-02-14 18:09:43.443 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@39ba1.
2024-02-14 18:09:43.444 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: notifyTransactionResponse TID:37271 DONE
2024-02-14 18:09:43.444 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2024-02-14 18:09:43.448 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 49: Sending REQUEST Message = 01 09 00 13 31 02 80 02 25 FE 8F
2024-02-14 18:09:43.459 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 49: sentData successfully placed on stack.
2024-02-14 18:09:43.460 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: TID 37272: Transaction not completed
2024-02-14 18:09:43.578 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 49: SendData Request. CallBack ID = 254, Status = Transmission complete and ACK received(0)
2024-02-14 18:09:43.579 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
2024-02-14 18:09:43.579 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: TID 37272: Transaction not completed
2024-02-14 18:09:43.655 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
2024-02-14 18:09:43.655 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
2024-02-14 18:09:43.656 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_BATTERY, endpoint 0
2024-02-14 18:09:43.656 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY NOT required on COMMAND_CLASS_BATTERY
2024-02-14 18:09:43.656 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_BATTERY V1 BATTERY_REPORT
2024-02-14 18:09:43.657 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 49: Battery report value = 100
2024-02-14 18:09:43.657 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2024-02-14 18:09:43.657 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_BATTERY, value=100
2024-02-14 18:09:43.658 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Updating channel state zwave:device:0f5fc641be:node49:battery-level to 100 [DecimalType]
2024-02-14 18:09:43.659 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
2024-02-14 18:09:43.660 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3a0106.
2024-02-14 18:09:43.660 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3a0106.
2024-02-14 18:09:43.661 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: notifyTransactionResponse TID:37272 DONE
2024-02-14 18:09:43.661 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2024-02-14 18:09:43.894 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
2024-02-14 18:09:43.895 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
2024-02-14 18:09:43.895 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_THERMOSTAT_MODE, endpoint 0
2024-02-14 18:09:43.895 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY NOT required on COMMAND_CLASS_THERMOSTAT_MODE
2024-02-14 18:09:43.896 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_THERMOSTAT_MODE V1 THERMOSTAT_MODE_REPORT
2024-02-14 18:09:43.896 [DEBUG] [lass.ZWaveThermostatModeCommandClass] - NODE 49: Thermostat Mode report, value = 1
2024-02-14 18:09:43.896 [DEBUG] [lass.ZWaveThermostatModeCommandClass] - NODE 49: Thermostat Mode Report, value = Heat
2024-02-14 18:09:43.897 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2024-02-14 18:09:43.897 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_THERMOSTAT_MODE, value=1
2024-02-14 18:09:43.897 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Updating channel state zwave:device:0f5fc641be:node49:thermostat_mode to 1 [DecimalType]
2024-02-14 18:09:43.898 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
2024-02-14 18:09:43.899 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@d747b.
2024-02-14 18:10:02.741 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Command received zwave:device:0f5fc641be:node49:thermostat_setpoint_furnace --> 23 °C [QuantityType]
2024-02-14 18:10:02.742 [DEBUG] [ter.ZWaveThermostatSetpointConverter] - NODE 49: Thermostat command received for 23 °C
2024-02-14 18:10:02.744 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 49: Creating new message for command THERMOSTAT_SETPOINT_SET
2024-02-14 18:10:02.745 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY NOT required on COMMAND_CLASS_THERMOSTAT_SETPOINT
2024-02-14 18:10:02.746 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Command Class COMMAND_CLASS_THERMOSTAT_SETPOINT is NOT required to be secured
2024-02-14 18:10:02.747 [DEBUG] [ter.ZWaveThermostatSetpointConverter] - NODE 49: Sending Message: org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@1834f98
2024-02-14 18:10:02.748 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 49: Creating new message for application command THERMOSTAT_SETPOINT_GET (Furnace)
2024-02-14 18:10:02.749 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY NOT required on COMMAND_CLASS_THERMOSTAT_SETPOINT
2024-02-14 18:10:02.750 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Command Class COMMAND_CLASS_THERMOSTAT_SETPOINT is NOT required to be secured
2024-02-14 18:10:02.751 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Bump transaction 37273 priority from Set to Immediate
2024-02-14 18:10:02.752 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Adding to device queue
2024-02-14 18:10:02.753 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Added 37273 to queue - size 7
2024-02-14 18:10:02.757 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 49: Sending REQUEST Message = 01 0C 00 13 31 05 43 01 07 01 17 25 01 A3
2024-02-14 18:10:02.761 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Bump transaction 37274 priority from Get to Immediate
2024-02-14 18:10:02.763 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Adding to device queue
2024-02-14 18:10:02.765 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Added 37274 to queue - size 7
2024-02-14 18:10:02.768 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Polling initialised at 86400 seconds - start in 1500 milliseconds.
2024-02-14 18:10:02.773 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 49: sentData successfully placed on stack.
2024-02-14 18:10:02.775 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: TID 37273: Transaction not completed
2024-02-14 18:10:04.134 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 49: SendData Request. CallBack ID = 1, Status = Transmission complete and ACK received(0)
2024-02-14 18:10:04.135 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
2024-02-14 18:10:04.136 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Response processed after 1376ms
2024-02-14 18:10:04.136 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: TID 37273: Transaction completed
2024-02-14 18:10:04.136 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: notifyTransactionResponse TID:37273 DONE
2024-02-14 18:10:04.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2024-02-14 18:10:04.139 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 49: Sending REQUEST Message = 01 0A 00 13 31 03 43 02 07 25 02 B5
2024-02-14 18:10:04.150 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 49: sentData successfully placed on stack.
2024-02-14 18:10:04.151 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: TID 37274: Transaction not completed
2024-02-14 18:10:04.217 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 49: SendData Request. CallBack ID = 2, Status = Transmission complete and ACK received(0)
2024-02-14 18:10:04.217 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
2024-02-14 18:10:04.218 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: TID 37274: Transaction not completed
2024-02-14 18:10:04.268 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Polling...
2024-02-14 18:10:04.269 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Polling skipped for zwave:device:0f5fc641be:node49:basic_thermostat_mode on COMMAND_CLASS_BASIC
2024-02-14 18:10:04.269 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Polling zwave:device:0f5fc641be:node49:sensor_temperature
2024-02-14 18:10:04.269 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 49: Generating poll message for COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
2024-02-14 18:10:04.270 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 49: Creating new message for command SENSOR_MULTILEVEL_GET
2024-02-14 18:10:04.270 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY NOT required on COMMAND_CLASS_SENSOR_MULTILEVEL
2024-02-14 18:10:04.271 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Command Class COMMAND_CLASS_SENSOR_MULTILEVEL is NOT required to be secured
2024-02-14 18:10:04.271 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Polling zwave:device:0f5fc641be:node49:thermostat_mode
2024-02-14 18:10:04.271 [DEBUG] [nverter.ZWaveThermostatModeConverter] - NODE 49: Generating poll message for COMMAND_CLASS_THERMOSTAT_MODE, endpoint 0
2024-02-14 18:10:04.272 [DEBUG] [lass.ZWaveThermostatModeCommandClass] - NODE 49: Creating new message for application command THERMOSTAT_MODE_GET
2024-02-14 18:10:04.273 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY NOT required on COMMAND_CLASS_THERMOSTAT_MODE
2024-02-14 18:10:04.273 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Command Class COMMAND_CLASS_THERMOSTAT_MODE is NOT required to be secured
2024-02-14 18:10:04.273 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Polling zwave:device:0f5fc641be:node49:thermostat_setpoint_heat
2024-02-14 18:10:04.274 [DEBUG] [ter.ZWaveThermostatSetpointConverter] - NODE 49: Generating poll message for COMMAND_CLASS_THERMOSTAT_SETPOINT, endpoint 0
2024-02-14 18:10:04.274 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Polling zwave:device:0f5fc641be:node49:thermostat_setpoint_furnace
2024-02-14 18:10:04.275 [DEBUG] [ter.ZWaveThermostatSetpointConverter] - NODE 49: Generating poll message for COMMAND_CLASS_THERMOSTAT_SETPOINT, endpoint 0
2024-02-14 18:10:04.275 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 49: Creating new message for application command THERMOSTAT_SETPOINT_GET (Furnace)
2024-02-14 18:10:04.275 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY NOT required on COMMAND_CLASS_THERMOSTAT_SETPOINT
2024-02-14 18:10:04.276 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Command Class COMMAND_CLASS_THERMOSTAT_SETPOINT is NOT required to be secured
2024-02-14 18:10:04.276 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Polling zwave:device:0f5fc641be:node49:battery-level
2024-02-14 18:10:04.276 [DEBUG] [rnal.converter.ZWaveBatteryConverter] - NODE 49: Generating poll message for COMMAND_CLASS_BATTERY endpoint 0
2024-02-14 18:10:04.277 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY NOT required on COMMAND_CLASS_BATTERY
2024-02-14 18:10:04.277 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Command Class COMMAND_CLASS_BATTERY is NOT required to be secured
2024-02-14 18:10:04.278 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Bump transaction 37275 priority from Get to Immediate
2024-02-14 18:10:04.278 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Adding to device queue
2024-02-14 18:10:04.278 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Added 37275 to queue - size 7
2024-02-14 18:10:04.279 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Bump transaction 37276 priority from Get to Immediate
2024-02-14 18:10:04.280 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Adding to device queue
2024-02-14 18:10:04.280 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Added 37276 to queue - size 8
2024-02-14 18:10:04.281 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Bump transaction 37277 priority from Get to Immediate
2024-02-14 18:10:04.281 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Adding to device queue
2024-02-14 18:10:04.281 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Added 37277 to queue - size 9
2024-02-14 18:10:04.282 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Bump transaction 37278 priority from Get to Immediate
2024-02-14 18:10:04.283 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Adding to device queue
2024-02-14 18:10:04.283 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Added 37278 to queue - size 10
2024-02-14 18:10:04.297 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
2024-02-14 18:10:04.297 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
2024-02-14 18:10:04.297 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_THERMOSTAT_SETPOINT, endpoint 0
2024-02-14 18:10:04.298 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY NOT required on COMMAND_CLASS_THERMOSTAT_SETPOINT
2024-02-14 18:10:04.298 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_THERMOSTAT_SETPOINT V1 THERMOSTAT_SETPOINT_REPORT
2024-02-14 18:10:04.298 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 49: Thermostat Setpoint report Scale = 0
2024-02-14 18:10:04.299 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 49: Thermostat Setpoint Value = 0E+1
2024-02-14 18:10:04.299 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 49: Unknown Setpoint Type = 0, ignoring report.
2024-02-14 18:10:04.299 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
2024-02-14 18:10:04.300 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@384ef7.
2024-02-14 18:10:04.300 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@384ef7.
2024-02-14 18:10:04.300 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: notifyTransactionResponse TID:37274 DONE
2024-02-14 18:10:04.301 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2024-02-14 18:10:04.303 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 49: Sending REQUEST Message = 01 0B 00 13 31 04 31 04 01 00 25 03 C0
2024-02-14 18:10:04.315 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 49: sentData successfully placed on stack.
2024-02-14 18:10:04.316 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: TID 37275: Transaction not completed
2024-02-14 18:10:04.429 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 49: SendData Request. CallBack ID = 3, Status = Transmission complete and ACK received(0)
2024-02-14 18:10:04.430 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
2024-02-14 18:10:04.431 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: TID 37275: Transaction not completed
2024-02-14 18:10:04.509 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
2024-02-14 18:10:04.509 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
2024-02-14 18:10:04.510 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
2024-02-14 18:10:04.510 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY NOT required on COMMAND_CLASS_SENSOR_MULTILEVEL
2024-02-14 18:10:04.510 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_SENSOR_MULTILEVEL V10 SENSOR_MULTILEVEL_REPORT
2024-02-14 18:10:04.511 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 49: Sensor Type = Temperature(1), Scale = 0
2024-02-14 18:10:04.511 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 49: Sensor Value = 19.5
2024-02-14 18:10:04.512 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2024-02-14 18:10:04.512 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_MULTILEVEL, value=19.5
2024-02-14 18:10:04.512 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Updating channel state zwave:device:0f5fc641be:node49:sensor_temperature to 19.5 °C [QuantityType]
2024-02-14 18:10:04.514 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
2024-02-14 18:10:04.514 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1bc341c.
2024-02-14 18:10:04.515 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1bc341c.
2024-02-14 18:10:04.516 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: notifyTransactionResponse TID:37275 DONE
2024-02-14 18:10:04.517 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2024-02-14 18:10:04.520 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 49: Sending REQUEST Message = 01 09 00 13 31 02 40 02 25 04 B5
2024-02-14 18:10:04.531 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 49: sentData successfully placed on stack.
2024-02-14 18:10:04.532 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: TID 37276: Transaction not completed
2024-02-14 18:10:04.649 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 49: SendData Request. CallBack ID = 4, Status = Transmission complete and ACK received(0)
2024-02-14 18:10:04.649 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
2024-02-14 18:10:04.650 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: TID 37276: Transaction not completed
2024-02-14 18:10:04.728 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
2024-02-14 18:10:04.729 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
2024-02-14 18:10:04.729 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_THERMOSTAT_MODE, endpoint 0
2024-02-14 18:10:04.730 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY NOT required on COMMAND_CLASS_THERMOSTAT_MODE
2024-02-14 18:10:04.731 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_THERMOSTAT_MODE V1 THERMOSTAT_MODE_REPORT
2024-02-14 18:10:04.732 [DEBUG] [lass.ZWaveThermostatModeCommandClass] - NODE 49: Thermostat Mode report, value = 1
2024-02-14 18:10:04.732 [DEBUG] [lass.ZWaveThermostatModeCommandClass] - NODE 49: Thermostat Mode Report, value = Heat
2024-02-14 18:10:04.733 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2024-02-14 18:10:04.734 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_THERMOSTAT_MODE, value=1
2024-02-14 18:10:04.735 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Updating channel state zwave:device:0f5fc641be:node49:thermostat_mode to 1 [DecimalType]
2024-02-14 18:10:04.736 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
2024-02-14 18:10:04.737 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@231f4d.
2024-02-14 18:10:04.739 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@231f4d.
2024-02-14 18:10:04.739 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: notifyTransactionResponse TID:37276 DONE
2024-02-14 18:10:04.740 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2024-02-14 18:10:04.746 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 49: Sending REQUEST Message = 01 0A 00 13 31 03 43 02 07 25 05 B2
2024-02-14 18:10:04.795 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 49: sentData successfully placed on stack.
2024-02-14 18:10:04.797 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: TID 37277: Transaction not completed
2024-02-14 18:10:04.872 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 49: SendData Request. CallBack ID = 5, Status = Transmission complete and ACK received(0)
2024-02-14 18:10:04.872 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
2024-02-14 18:10:04.873 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: TID 37277: Transaction not completed
2024-02-14 18:10:04.949 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
2024-02-14 18:10:04.949 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
2024-02-14 18:10:04.950 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_THERMOSTAT_SETPOINT, endpoint 0
2024-02-14 18:10:04.951 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY NOT required on COMMAND_CLASS_THERMOSTAT_SETPOINT
2024-02-14 18:10:04.951 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_THERMOSTAT_SETPOINT V1 THERMOSTAT_SETPOINT_REPORT
2024-02-14 18:10:04.952 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 49: Thermostat Setpoint report Scale = 0
2024-02-14 18:10:04.953 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 49: Thermostat Setpoint Value = 0E+1
2024-02-14 18:10:04.954 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 49: Unknown Setpoint Type = 0, ignoring report.
2024-02-14 18:10:04.954 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
2024-02-14 18:10:04.955 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@2df039.
2024-02-14 18:10:04.955 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@2df039.
2024-02-14 18:10:04.955 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: notifyTransactionResponse TID:37277 DONE
2024-02-14 18:10:04.956 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2024-02-14 18:10:04.960 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 49: Sending REQUEST Message = 01 09 00 13 31 02 80 02 25 06 77
2024-02-14 18:10:04.971 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 49: sentData successfully placed on stack.
2024-02-14 18:10:04.972 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: TID 37278: Transaction not completed
2024-02-14 18:10:05.090 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 49: SendData Request. CallBack ID = 6, Status = Transmission complete and ACK received(0)
2024-02-14 18:10:05.091 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
2024-02-14 18:10:05.092 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: TID 37278: Transaction not completed
2024-02-14 18:10:05.167 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
2024-02-14 18:10:05.168 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
2024-02-14 18:10:05.168 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_BATTERY, endpoint 0
2024-02-14 18:10:05.169 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY NOT required on COMMAND_CLASS_BATTERY
2024-02-14 18:10:05.169 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_BATTERY V1 BATTERY_REPORT
2024-02-14 18:10:05.169 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 49: Battery report value = 100
2024-02-14 18:10:05.170 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2024-02-14 18:10:05.171 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_BATTERY, value=100
2024-02-14 18:10:05.171 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Updating channel state zwave:device:0f5fc641be:node49:battery-level to 100 [DecimalType]
2024-02-14 18:10:05.172 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
2024-02-14 18:10:05.173 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@e6523d.
2024-02-14 18:10:05.173 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@e6523d.
2024-02-14 18:10:05.174 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: notifyTransactionResponse TID:37278 DONE
2024-02-14 18:10:05.175 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
