Hello! From the cloud, myopenhab unavailable (not loading) node-red. I can’t understand what is the reason. Who can help, tell me. Thank!
That’s a simple one to answer.
Node-RED runs on port 1880, which simply isn’t available via myopenhab.org
You’ll have to create a VPN or SSH (with tunnels) connection to your home network if you want to do more than look at your openHAB2 instance.
For example, you can’t save large HabPanel configurations via myopenhab.org either.
Thanks for the explanation!
